Qchem shell script not generated after installation
I have installed the trial version of Q-Chem in my computer (Linux) with the necessary steps required. Finally a message “Q-Chem installation/update has been completed” has appeared. Below it instruction to run calculation is provided :
For tcsh or csh:
source /home/raj/opt/qchem/qcenv.csh
For bash:
. /home/raj/opt/qchem/qcenv.sh
I have selected an input file from “sample” directory to make a test run.
According to the manual :
The qchem shell script can be used in either of the following ways:
qchem infile outfile
qchem infile outfile savename
qchem -save infile outfile savename
But I see no qchem command in my directory.
I do not understand what to do next after I have installed it. How can I run an input file ?
I have attached a screenshot for the same
In order to use the qchem command, ensure it’s available from your $PATH. The qcenv.sh script sets up appropriate environment variables, including $PATH, for running Q-Chem from the shell. Follow the instructions given by the installer:
  • Execute . /home/raj/opt/qchem/qcenv.sh (it is also recommended to add this line to your ~/.bashrc )
  • Run qchem from the command line
Related user manual entries:
Thanks for your reply.
This is the qcenv.sh screenshot. Where do I have to add “$PATH” in the script.
No need to make changes to this file, simply source it by running
$ . qcenv.sh
Yes now it is running…
But an “Error in Q-Chem run” is appearing
Thank You so much it is now fixed…
Thanks a lot
Hello, I recently started working on Q-chem. I’m also getting same error.
Can you please help me solve this issue.
Thank you.
exported envs: QC QCAUX QCSCRATCH QCRUNNAME QCFILEPREF QCPROG QCPROG_S GUIFILE
Error in Q-Chem run part 1
remove work dirs /tmp/qchem1921967.0 – /tmp/qchem1921967.-1
rm -rf /tmp/qchem1921967
Error in the Q-Chem run
do you get a Q-Chem output file? if so, what does it say?
