ALMO_EDA job failure
Hi, I am encountering a reproducible crash in an ALMO-EDA calculation and would appreciate your guidance.
I am running an open-shell ALMO-EDA calculation for a donor–acceptor complex (OPP⁻ ⋯ TEA⁺), where both fragments are doublets. The calculation uses an unrestricted formalism and PCM solvation. When I specify SCF_GUESS = FRAGMO , the job aborts with a low-level memory error:
User-specified occupied guess orbitals will be used
double free or corruption (!prev)
Error in Q-Chem run
I am sharing my input file here.
– OPP
-1 2
H -3.16446 -2.15371 0.16024
C -3.67119 -1.19822 0.08394
C -2.90946 0.00000 0.00000
C -3.67119 1.19822 -0.08394
H -3.16446 2.15371 -0.16024
C -5.05575 1.19346 -0.08311
H -5.58529 2.14061 -0.15189
C -5.77637 0.00000 0.00000
H -6.86137 0.00000 0.00000
C -5.05575 -1.19346 0.08311
H -5.58529 -2.14061 0.15189
C -1.46254 0.00000 0.00000
C -0.68550 1.20010 -0.00097
C 0.68550 1.20010 0.00097
C 1.46254 0.00000 0.00000
C 0.68550 -1.20010 -0.00097
C -0.68550 -1.20010 0.00097
C 2.90946 0.00000 0.00000
C 3.67119 1.19822 0.08394
C 5.05575 1.19346 0.08311
C 5.77637 0.00000 0.00000
C 5.05575 -1.19346 -0.08311
C 3.67119 -1.19822 -0.08394
H -1.18509 2.16375 0.00449
H 1.18509 2.16375 -0.00449
H 1.18509 -2.16375 0.00449
H -1.18509 -2.16375 -0.00449
H 3.16446 2.15371 0.16024
H 5.58529 2.14061 0.15189
H 6.86137 0.00000 0.00000
H 5.58529 -2.14061 -0.15189
H 3.16446 -2.15371 -0.16024
– TEA
1 2
N -0.00172 -0.00297 3.56485
C -1.43021 -0.25813 3.57588
C -1.90962 -0.91634 2.27816
C 0.49053 1.36208 3.57886
C 0.15726 2.10941 2.28357
C 0.93405 -1.11230 3.57163
C 1.75952 -1.18240 2.28352
H -1.61810 -0.92627 4.42409
H -1.94151 0.68811 3.75086
H -1.42568 -1.88042 2.11198
H -2.98464 -1.08343 2.36665
H -1.72473 -0.26843 1.41989
H 0.00620 1.85634 4.42878
H 1.56564 1.33240 3.75358
H -0.91972 2.15962 2.11468
H 0.53821 3.12770 2.37874
H 0.63391 1.63492 1.42436
H 1.59613 -0.95043 4.43013
H 0.36833 -2.02993 3.72960
H 2.35386 -0.27916 2.13523
H 2.44072 -2.03051 2.37155
H 1.11702 -1.33676 1.41518
BASIS = 6-31G(d,p)
GUI = 2
JOB_TYPE = EDA
EDA2 = FALSE
METHOD = CAMB3LYP
MAX_SCF_CYCLES = 100
SCF_CONVERGENCE = 8
THRESH = 14
UNRESTRICTED = TRUE
SCF_GUESS = FRAGMO
FRGM_METHOD = STOLL
FRGM_LPCORR = RS_EXACT_SCF
EDA_BSSE = TRUE
DIIS_SEPARATE_ERRVEC = 1
MEM_TOTAL = 248000
MEM_STATIC = 4000
$pcm
THEORY CPCM
heavypoints 590
method swig
radii bondi
solver inversion
$solvent
DIELECTRIC 37.5
OPTICALDIELECTRIC 1.8068
Hello. I noticed the job sets EDA2 to false and uses the old EDA code, which does not support implicit solvent models. Even if the job runs, the results would not be correct.
Please refer to the manual page and examples here: 12.6.6 ALMO-EDA with Implicit Solvent Models‣ 12.6 Second-Generation ALMO-EDA Method ‣ Chapter 12 Fragment-Based Methods ‣ Q-Chem 6.4 User’s Manual
is it possible to claculate BSSE calculation in cpcm/water molde ? if so then How ?
thanks in advance
See response here: BSSE error input file - #6 by jherbert
