2D- Excited state Scan
I want to do a 2D-PES Scan using the SF-TDDFT method, but in the user manual and from the error, I learned that it is only available for the ground state.
" Checking the input file for inconsistencies…
PES scan currently implemented only for the ground state.
Please remove CIS_STATE_DERIV from $rem."
Can anyone please let me know what its alternative will be using qchem software?
These were my inputs:
coordinates
BASIS = cc-pVDZ
EXCHANGE = omegaB97XD
JOB_TYPE = pes_scan
MAX_CIS_CYCLES = 700
MAX_SCF_CYCLES = 700
THRESH = 14
UNRESTRICTED = true
SPIN_FLIP = 1
CIS_N_ROOTS = 4
SYMMETRY_IGNORE = true
SYMMETRY = false
CIS_STATE_DERIVATIVE = 3
SOLVENT_METHOD = PCM
DIELECTRIC 32.613000
OPTICALDIELECTRIC 1.765709
$scan
tors 12 11 9 8 -50.00 -150.00 10
tors 11 9 8 2 -50.00 -150.00 10
It’s not implemented and could potentially be a morass, because excited-state geometry optimizations can be tricky and are not nearly as “black-box” as ground-state optimizations. (Note that the ground-state PES scan in Q-Chem relaxes the geometry in the other degrees of freedom.) If you want to try this, I suggest writing a script to generate a set of input files with different constrained values of the two torsional angles in question, then run each separate input file as its own constrained excited-state optimization.
