ALMO-EDA with user-defined basis
Hi, I’m trying to run bonded ALMO-EDA with a user-defined basis but am running into issues. My system is singlet H2. Each fragment is a doublet H. The QChem version is 6.0.1. Below is my input:
--  An alpha spin H atom
   0 2
   H1
--  Another alpha spin H atom. Bonded ALMO-EDA does not need the multiplicities to sum to that of the molecule
   0 -2
   H2 H1 0.741
   JOBTYPE            eda                       # use almo-eda
   METHOD             wb97x-v                   # note: bonded eda examples only "EXCHANGE" instead of METHOD. Why?
   BASIS              gen              		# chosen because PySCF uses 'full' by default
   EDA2               10                        # EDA2 = 10 for bonded EDA. Use EDA2 = 2 otherwise
   BONDED_EDA         2                         # (1) Perform ALMO-EDA with non-orthogonal CI. (2) Perform ALMO-EDA with spin-projected formalism, which is more efficient
   SCF_CONVERGENCE    6                         # convergence in H = 10^SCF_CONVERGENCE
   MAX_SCF_CYCLES     200
   ROSCF              true                      # required for bonded EDA
   SCF_GUESS          fragmo
   DISP_FREE_X      HF                          # HF recommended for hybrid functionals (B97X-V), revPBE recommended for semi-local functionals (B97M-V)
   DISP_FREE_C      NONE                        # put PBE if DISP_FREE_X is revPBE, NONE if DISP_FREE_X is set to an exchange-correlation functional
   EDA_BSSE         true
   SCF_ALGORITHM      gdm_ls
   SCFMI_MODE         1                         # required for bonded EDA
   SCF_PRINT_FRGM     true
   FRZ_RELAX          true
   FRZ_RELAX_METHOD   2
   FRZ_ORTHO_DECOMP   1
$rem_frgm
   scf_convergence   7
   scf_algorithm     gdm_ls
   scf_guess         AUTOSAD
	H  0
	S  6  1.00
	23.103031490634763   0.006636413216534018
	4.235915530697191   0.03574833003218233
	1.1850565166493239   0.12205795626873055
	0.40709890088449535   0.26836711112905565
	0.1580884170135276   0.3016293830698489
	0.06510954084287202   0.0943898892708209
and the output:
    1      H       0.0000000000     0.0000000000     0.0000000000
 Nuclear Repulsion Energy =           0.00000000 hartrees
 There are        1 alpha and        0 beta electrons
 There are 1 shells and 1 basis functions
 Total QAlloc Memory Limit   8000 MB
 Mega-Array Size       188 MB
 MEM_STATIC part       192 MB
 A cutoff of  1.0D-10 yielded      1 shell pairs
 There are         1 function pairs
 Smallest overlap matrix eigenvalue = 1.00E+00
 Scale SEOQF with 1.000000e+00/1.000000e+00/1.000000e+00
 Guess MOs from core Hamiltonian diagonalization
  Bang C. Huynh
 Exchange:     0.1670 Hartree-Fock + 1.0000 wB97X-V + LR-HF
 Correlation:  1.0000 wB97X-V
 Nonlocal Correlation:  VV10 with C = 0.0100 and b = 6.00 and scale = 1.00000
 Grid used for NLC:  SG-1 standard quadrature
Printing hybrid method specification in gen_scfman_hybrid_algorithm
algorithm ALGO_ID will be run until the its iterations, ALGO_ITER, are exhausted
or until the gradient/residual is below the 1E-ALGO_CONV of the last algorithm
  ALGO_ID        ALGO_CONV         ALGO_ITER
  GDM_LS                  0           200
  GDM                     6           200
Energy prior to optimization (guess energy) = -0.500207110815
Begin Timing: Total SCF Calculation
Begin Timing: Algorithm 1
begin iterations for algorithm: GDM_LS
the SCF tolerance is set to 1.00e-06
GDM subspace size: 20
0 degrees of freedom in requested optimization
    1      -0.5002071108      0.00e+00     00000 Convergence criterion met
The entire SCF was completed on algorithm stage 1, with algorithm GDM_LS
Timing for Total SCF: 0.00s (wall), 0.03s (cpu)
<S^2> =          0.750000000
                    Orbital Energies (a.u.)
 Alpha MOs
 -- Occupied --
 -0.4265
          Ground-State Mulliken Net Atomic Charges
     Atom                 Charge (a.u.)    Spin (a.u.)
      1 H                     0.000000       1.000000
  Sum of atomic charges =     0.000000
  Sum of spin   charges =     1.000000
                    Cartesian Multipole Moments
    Charge (ESU x 10^10)
                 0.0000
    Dipole Moment (Debye)
         X       0.0000      Y       0.0000      Z       0.0000
       Tot       0.0000
        XX      -1.3450     XY       0.0000     YY      -1.3450
        XZ       0.0000     YZ       0.0000     ZZ      -1.3450
       XXX       0.0000    XXY       0.0000    XYY       0.0000
       YYY       0.0000    XXZ       0.0000    XYZ       0.0000
       YYZ       0.0000    XZZ       0.0000    YZZ       0.0000
       ZZZ       0.0000
      XXXX      -1.6945   XXXY       0.0000   XXYY      -0.5648
      XYYY       0.0000   YYYY      -1.6945   XXXZ       0.0000
      XXYZ       0.0000   XYYZ       0.0000   YYYZ       0.0000
      XXZZ      -0.5648   XYZZ       0.0000   YYZZ      -0.5648
      XZZZ       0.0000   YZZZ       0.0000   ZZZZ      -1.6945
 STANDARD THERMODYNAMIC QUANTITIES AT   298.15 K  AND     1.00 ATM
   Translational Enthalpy:        0.889 kcal/mol
   Rotational Enthalpy:           0.000 kcal/mol
   Vibrational Enthalpy:          0.000 kcal/mol
   gas constant (RT):             0.592 kcal/mol
   Translational Entropy:        26.014  cal/mol.K
   Rotational Entropy:            0.000  cal/mol.K
   Vibrational Entropy:           0.000  cal/mol.K
   Total Enthalpy:                1.481 kcal/mol
   Total Entropy:                26.014  cal/mol.K
 Total job time:  0.53s(wall), 4.39s(cpu)
 Wed May 15 11:32:02 2024
        *  Thank you very much for using Q-Chem.  Have a nice day.  *
 Done Job For Fragment 0
 calling putenv with: QCSCRATCH=/scratch/users/alannal2/11135968.v2GejzU/test/
 calling putenv with: QCTHREADS=40
 Time for running child jobs:  CPU 1.56 s  wall 0.64 s
 ============= Method Specific SAD Guess Constructed =============
 Guess from on-the-fly superposition of atomic densities
  Bang C. Huynh
 Orthonormalizing orbitals
The disked orbital energies are calculated using alpha and beta Focks
Timing for Total SCF: 0.00s (wall), 0.00s (cpu)
<S^2> =          0.750000000
 Alpha MOs
 -- Occupied --
 -0.4265
                 0.0000
       Tot       0.0000
       YYY       0.0000    XXZ      -0.4983    XYZ       0.0000
       YYZ      -0.4983    XZZ       0.0000    YZZ       0.0000
       ZZZ      -1.4950
      XXZZ      -0.7495   XYZZ       0.0000   YYZZ      -0.7495
      XZZZ       0.0000   YZZZ       0.0000   ZZZZ      -2.8023
 Total job time:  1.20s(wall), 6.68s(cpu)
 Done Job For Fragment 1
begin create_subspaces_scf
Doing Gen SCFMI
active_doubly_SS in ExtractFragmo
        0
        0
active_singlyA_SS in ExtractFragmo
        1
        0
active_singlyB_SS in ExtractFragmo
        0
        1
active_virt_SS in ExtractFragmo
        0
        0
NOrbSS in ExtractFragmo
        1
        1
 Q-Chem fatal error occurred in module libalmo/libalmo/scfmi/subrot_ross.C, line 250:
 There are no virtual orbitals for the entire systems
How do I go about correcting this issue? Single point energy calculations with the same basis found some occupancy in virtual orbitals.
To run a meaningful bonded-EDA calculation, the number of basis functions must exceed the number of electrons, i.e., for H the basis set must have >1 basis functions.
