ALMO-FODFT Compatibility with Double-Hybrid Functionals in Q-Chem
I am currently using the ALMO-FODFT approach to calculate electronic coupling, and I was wondering whether this method is compatible with double-hybrid density functionals in Q-Chem. Specifically, can ALMO-FODFT calculations be performed using a double-hybrid functional, or is the method currently limited to HF, conventional hybrid, or range-separated hybrid DFT functionals?If double-hybrid functionals are not supported, is there a theoretical or implementation-related reason for this limitation? I am sharing my inp file.
-1 2
   H       2.68969000    -0.43032000    -3.95257000
   C       2.25502000    -1.10849000    -5.23731000
   C       2.86195000    -2.28024000    -5.70775000
   C       2.51184000    -2.89033000    -6.90114000
   C       1.49063000    -2.36123000    -7.75622000
   C       0.86845000    -1.16919000    -7.25701000
   C       1.24358000    -0.58669000    -6.06126000
   C       1.13026000    -2.96401000    -9.00439000
   C       1.76750000    -4.15607000    -9.50475000
   C       1.42540000    -4.72201000   -10.71549000
   C       0.42558000    -4.16837000   -11.53855000
   C      -0.21976000    -3.00559000   -11.07355000
   C       0.10843000    -2.42497000    -9.86600000
   H       3.65193000    -2.72339000    -5.10508000
   H       3.04420000    -3.79173000    -7.18458000
   H       0.07370000    -0.69482000    -7.82243000
   H       0.73970000     0.32005000    -5.73762000
   H       2.55023000    -4.63476000    -8.92657000
   H       1.94854000    -5.61901000   -11.03937000
   H       0.16158000    -4.61930000   -12.48840000
   H      -1.00083000    -2.54787000   -11.67644000
   H      -0.43271000    -1.53311000    -9.56877000
   C       3.98512000     3.92483000    -3.83796000
   C       4.60107000     2.88168000    -3.18866000
   C       5.93417000     3.06007000    -2.73544000
   C       6.60441000     4.23815000    -2.93237000
   C       5.98146000     5.32208000    -3.60085000
   C       4.64782000     5.15772000    -4.06218000
   C       4.01666000     6.23849000    -4.73496000
   C       4.67893000     7.42024000    -4.93582000
   C       6.00761000     7.58332000    -4.47400000
   C       6.64256000     6.55893000    -3.82361000
   H       2.96408000     3.82194000    -4.19445000
   H       6.42676000     2.23911000    -2.22332000
   H       7.62405000     4.35505000    -2.57844000
   H       2.99819000     6.11065000    -5.08823000
   H       4.18740000     8.23897000    -5.44981000
   H       6.52005000     8.52499000    -4.63743000
   H       7.66155000     6.67853000    -3.46864000
   H       3.88564000     1.57227000    -2.93262000
   METHOD = wB97M(2)
   BASIS = 6-311+G**
   UNRESTRICTED = TRUE
   THRESH = 14
   FRAG_DIABAT_METHOD = fodft
   FRAG_DIABAT_DOHT = False
   FODFT_METHOD = 1
   SCFMI_MODE = 1
   INTEGRAL_SYMMETRY = FALSE
   POINT_GROUP_SYMMETRY = FALSE
   S2THRESH = 14
   SOLVENT_METHOD = PCM
   SCF_PRINT_FRGM = TRUE
   MEM_TOTAL = 248000
   MEM_STATIC = 4000
   THEORY  CPCM
   HEAVYPOINTS  590
   METHOD  SWIG
   RADII  BONDI
   SOLVER  INVERSION
   DIELECTRIC  7.5
   OPTICALDIELECTRIC  1.97
Thank you!
The construction of the FODFT method determines that it should not be used with double-hybrid functionals, as it is essentially calculating the coupling between two fragment orbitals through a supersystem Fock matrix, which is only well-defined at the mean-field level.
