aug-cc-pV5Z with external charges
I tried to do a single H2O molecule calculation at RIMP2/aug-cc-pV5Z level, and with external background point charges.
Below are my input and the corresponding error message. When I use aug-cc-pVQZ basis set (provided in external basis set format), the calculation terminates normally with external charges. However, the same setup fails when switching to aug-cc-pV5Z.
Does anyone know what might be causing this problem, or if there are specific considerations when using aug-cc-pV5Z with external point charges?
Thanks in advance.
Input and error message:
O     -1.5993985807    -3.1633090386    -2.3714226713
H     -2.1897310342    -3.0308319562    -1.5961618474
H     -1.6119979636    -2.3086961098    -2.8485563880
SYM_IGNORE        true
METHOD            RIMP2
BASIS             GEN
AUX_BASIS         GEN
THRESH            14
SCF_CONVERGENCE   8
H     0
S   1   1.00
1.283000D+00           1.000000D+00
S   1   1.00
4.655000D-01           1.000000D+00
S   8   1.00
4.020000D+02           2.790000D-04
6.024000D+01           2.165000D-03
1.373000D+01           1.120100D-02
3.905000D+00           4.487800D-02
1.283000D+00           1.422990D-01
4.655000D-01           3.309790D-01
1.811000D-01           4.362690D-01
7.279000D-02           1.764400D-01
S   1   1.00
1.811000D-01           1.000000D+00
S   1   1.00
7.279000D-02           1.000000D+00
S   1   1.00
0.0207000              1.0000000
P   1   1.00
4.516000D+00           1.000000D+00
P   1   1.00
1.712000D+00           1.000000D+00
P   1   1.00
6.490000D-01           1.000000D+00
P   1   1.00
2.460000D-01           1.000000D+00
P   1   1.00
0.0744000              1.0000000
D   1   1.00
2.950000D+00           1.000000D+00
D   1   1.00
1.206000D+00           1.000000D+00
D   1   1.00
4.930000D-01           1.000000D+00
D   1   1.00
0.1560000              1.0000000
F   1   1.00
2.506000D+00           1.000000D+00
F   1   1.00
8.750000D-01           1.000000D+00
F   1   1.00
0.2740000              1.0000000
G   1   1.00
2.358000D+00           1.0000000
G   1   1.00
0.5430000              1.0000000
O     0
S   14   1.00
1.642000D+05           2.600000D-05
2.459000D+04           2.050000D-04
5.592000D+03           1.076000D-03
1.582000D+03           4.522000D-03
5.161000D+02           1.610800D-02
1.872000D+02           4.908500D-02
7.393000D+01           1.248570D-01
3.122000D+01           2.516860D-01
1.381000D+01           3.624200D-01
6.256000D+00           2.790510D-01
2.776000D+00           6.355200D-02
1.138000D+00           1.063000D-03
4.600000D-01           1.144000D-03
1.829000D-01          -4.000000D-05
S   1   1.00
2.776000D+00           1.000000D+00
S   1   1.00
1.138000D+00           1.000000D+00
S   14   1.00
1.642000D+05          -6.000000D-06
2.459000D+04          -4.600000D-05
5.592000D+03          -2.440000D-04
1.582000D+03          -1.031000D-03
5.161000D+02          -3.688000D-03
1.872000D+02          -1.151400D-02
7.393000D+01          -3.043500D-02
3.122000D+01          -6.814700D-02
1.381000D+01          -1.203680D-01
6.256000D+00          -1.482600D-01
2.776000D+00           9.905000D-03
1.138000D+00           3.842860D-01
4.600000D-01           5.368050D-01
1.829000D-01           2.026870D-01
S   1   1.00
4.600000D-01           1.000000D+00
S   1   1.00
1.829000D-01           1.000000D+00
S   1   1.00
0.0655000              1.0000000
P   1   1.00
2.094000D+00           1.000000D+00
P   1   1.00
8.471000D-01           1.000000D+00
P   8   1.00
1.955000D+02           9.180000D-04
4.616000D+01           7.388000D-03
1.458000D+01           3.495800D-02
5.296000D+00           1.154310D-01
2.094000D+00           2.568030D-01
8.471000D-01           3.739380D-01
3.368000D-01           3.434470D-01
1.285000D-01           1.297060D-01
P   1   1.00
3.368000D-01           1.000000D+00
P   1   1.00
1.285000D-01           1.000000D+00
P   1   1.00
0.0446000              1.0000000
D   1   1.00
5.879000D+00           1.000000D+00
D   1   1.00
2.307000D+00           1.000000D+00
D   1   1.00
9.050000D-01           1.000000D+00
D   1   1.00
3.550000D-01           1.000000D+00
D   1   1.00
0.1310000              1.0000000
F   1   1.00
4.016000D+00           1.000000D+00
F   1   1.00
1.554000D+00           1.000000D+00
F   1   1.00
6.010000D-01           1.000000D+00
F   1   1.00
0.2370000              1.0000000
G   1   1.00
3.350000D+00           1.000000D+00
G   1   1.00
1.189000D+00           1.000000D+00
G   1   1.00
0.5170000              1.0000000
H   1   1.00
2.319000D+00           1.0000000
H   1   1.00
1.0240000              1.0000000
$aux_basis
H     0
S   1   1.00
23.3215                 1.0000000
S   1   1.00
4.92297                1.0000000
S   1   1.00
1.7751                 1.0000000
S   1   1.00
0.994218               1.0000000
S   1   1.00
0.506054               1.0000000
S   1   1.00
0.236911               1.0000000
S   1   1.00
0.110911               1.0000000
P   1   1.00
5.97458                1.0000000
P   1   1.00
2.05217                1.0000000
P   1   1.00
1.24866                1.0000000
P   1   1.00
0.805545               1.0000000
P   1   1.00
0.347892               1.0000000
P   1   1.00
0.196067               1.0000000
D   1   1.00
3.85816                1.0000000
D   1   1.00
1.71063                1.0000000
D   1   1.00
0.979237               1.0000000
D   1   1.00
0.625366               1.0000000
D   1   1.00
0.233601               1.0000000
F   1   1.00
3.10151                1.0000000
F   1   1.00
1.19811                1.0000000
F   1   1.00
0.572873               1.0000000
F   1   1.00
0.236155               1.0000000
G   1   1.00
2.9878                 1.0000000
G   1   1.00
1.23192                1.0000000
G   1   1.00
0.79632                1.0000000
H   1   1.00
3.24739                1.0000000
H   1   1.00
1.03498                1.0000000
O     0
S   1   1.00
488.561                  1.0000000
S   1   1.00
105.279                  1.0000000
S   1   1.00
28.7082                 1.0000000
S   1   1.00
14.8255                 1.0000000
S   1   1.00
5.83154                1.0000000
S   1   1.00
3.59537                1.0000000
S   1   1.00
1.94003                1.0000000
S   1   1.00
1.05859                1.0000000
S   1   1.00
0.474911               1.0000000
S   1   1.00
0.251005               1.0000000
S   1   1.00
0.0966305              1.0000000
P   1   1.00
94.2566                 1.0000000
P   1   1.00
25.4651                 1.0000000
P   1   1.00
11.0493                 1.0000000
P   1   1.00
4.70876                1.0000000
P   1   1.00
2.75688                1.0000000
P   1   1.00
1.27428                1.0000000
P   1   1.00
0.696641               1.0000000
P   1   1.00
0.416519               1.0000000
P   1   1.00
0.169976               1.0000000
D   1   1.00
21.9882                 1.0000000
D   1   1.00
7.27442                1.0000000
D   1   1.00
4.51878                1.0000000
D   1   1.00
2.71941                1.0000000
D   1   1.00
1.44213                1.0000000
D   1   1.00
0.719024               1.0000000
D   1   1.00
0.303063               1.0000000
D   1   1.00
0.140000               1.0000000
F   1   1.00
14.0987                 1.0000000
F   1   1.00
6.44291                1.0000000
F   1   1.00
3.72104                1.0000000
F   1   1.00
2.09374                1.0000000
F   1   1.00
1.18531                1.0000000
F   1   1.00
0.621013               1.0000000
F   1   1.00
0.238692               1.0000000
G   1   1.00
7.01407                1.0000000
G   1   1.00
3.88314                1.0000000
G   1   1.00
2.03825                1.0000000
G   1   1.00
1.00781                1.0000000
G   1   1.00
0.410343               1.0000000
H   1   1.00
5.42755                1.0000000
H   1   1.00
3.22312                1.0000000
H   1   1.00
1.72401                1.0000000
H   1   1.00
0.790781               1.0000000
I   1   1.00
3.26123                1.0000000
I   1   1.00
1.382920               1.0000000
$external_charges
4.2843534683 1.8052342452 1.4760163905 -0.834000000000
3.3438844170 2.0549247450 1.6179568868 0.417000000000
4.4304137566 1.9606272222 0.5197480401 0.417000000000
4.6580247943 -0.7602539140 1.6579443671 -0.834000000000
5.3609368244 -0.9175093105 2.3015843545 0.417000000000
4.4906322525 0.2375279861 1.6607144435 0.417000000000
2.1857500710 -1.8551174390 1.3488139880 -0.834000000000
2.2436931654 -1.8444965950 0.3584228837 0.417000000000
3.0867169855 -1.6066901649 1.6536935633 0.417000000000
    1      O      -1.5993985807    -3.1633090386    -2.3714226713
    2      H      -2.1897310342    -3.0308319562    -1.5961618474
    3      H      -1.6119979636    -2.3086961098    -2.8485563880
 Nuclear Repulsion Energy =           8.96961019 hartrees
 There are        5 alpha and        5 beta electrons
 There are 67 shells and 287 basis functions
 Total QAlloc Memory Limit   8000 MB
 Mega-Array Size       188 MB
 MEM_STATIC part       192 MB
                       Distance Matrix (Angstroms)
             O (  1)   H (  2)
   H (  2)  0.983398
   H (  3)  0.978866  1.556839
 There are 100 shells and 496 basis functions
 A cutoff of  1.0D-14 yielded   2278 shell pairs
 There are     42078 function pairs (     78876 Cartesian)
 Smallest overlap matrix eigenvalue = 1.51E-05
 Nucleus-field energy     =     0.0000000018 hartrees
 Adding external point charges to one-electron Hamiltonian
 Nucleus-charge energy    =    -0.0286243405 hartrees
 Charge-charge energy     =    -0.9756055260 hartrees
 ================ Generating on-the-fly SAD Guess ================
 Attempting to make child job directory: /jobfs/168187044.gadi-pbs/qchem90281//Frg1/
 Attempting to make child job directory: /jobfs/168187044.gadi-pbs/qchem90281//Frg2/
 Creating input file /jobfs/168187044.gadi-pbs/qchem90281/Frg1.input
 using default PutDataFrgm: nothing
 calling putenv with: QCSCRATCH=/jobfs/168187044.gadi-pbs/qchem90281/
 Spawning Job For Fragment 0
 Done Job For Fragment 0
 calling putenv with: QCTHREADS=8
 Creating input file /jobfs/168187044.gadi-pbs/qchem90281/Frg2.input
 Spawning Job For Fragment 1
 Set SCF_PRINT_FRGM to TRUE to get details
 Warning: SCF calculation for fragment 2 didn't converge
 Time spent on running child jobs:  CPU 1.82 s  wall 1.92 s
 Terminating AUTOSAD; using CORE guess instead
 Guess MOs from core Hamiltonian diagonalization
  Bang C. Huynh
 Hartree-Fock
gen_scfman_exception: hamiltonian: no capability for term external_charges:fock<D,D>
 Q-Chem fatal error occurred in module libgscf/gen_scfman/gen_scfman_main.C, line 244:
 Error in gen_scfman
Might be that the charge-density integrals aren’t available for that high of angular momentum. What happens if you deleted the highest angular momentum functions from aug-cc-pV5Z and the corresponding aux basis?
It works. Thanks, Herbert.
Ok. Error message is moderately cryptic but that’s what it’s trying to tell you.
