How to calculate the adiabatic excitation energy difference between two state? I have calculate the ground state and excited state of one molecule, but I don’t know how to extract the difference between ground state and excited state.
Another question is about Electronic Transition Dipole Emission(ETDE) and Electronic Transition Dipole Absorption (EDMA), I don’t know how to extract those from output file of excited state.
User input:
C 2.01378700 -1.48849900 0.00000000
C 2.28995100 -0.11795300 0.00000000
C 1.39185800 0.95357400 0.00000000
C 0.78413700 -2.15418400 0.00000000
C 0.00000000 0.93285800 0.00000000
C -0.50398400 -1.61066000 0.00000000
C -0.89316500 -0.27406300 0.00000000
H 2.88919300 -2.13621800 0.00000000
H 3.34387200 0.15083300 0.00000000
H 1.84191300 1.94636000 0.00000000
H 0.83658300 -3.24058400 0.00000000
H -1.32037400 -2.33298500 0.00000000
C -0.84567300 2.05536600 0.00000000
H -0.51364900 3.08694100 0.00000000
C -2.17758700 1.61062700 0.00000000
H -3.04994500 2.25593900 0.00000000
C -2.21340000 0.20656500 0.00000000
H -3.10314400 -0.41207700 0.00000000
JOBTYPE opt
CIS_STATE_DERIV 1
CIS_N_ROOTS 3
CIS_TRIPLETS FALSE
EXCHANGE B3LYP
BASIS 6-31G(D)
JOBTYPE freq
CIS_STATE_DERIV 1
CIS_N_ROOTS 3
CIS_TRIPLETS FALSE
iprint 10000000
EXCHANGE B3LYP
BASIS 6-31G(D)
performed using DIIS
Cycle Energy DIIS error
1 -388.1119834981 6.18e-02
2 -385.6828076156 5.83e-03
3 -385.5331510776 8.14e-03
4 -385.7556380043 3.72e-03
5 -385.8208564936 4.47e-04
6 -385.8213018226 3.01e-04
7 -385.8216023140 7.51e-05
8 -385.8216234324 1.85e-05
9 -385.8216245684 4.61e-06
10 -385.8216246296 2.31e-06
11 -385.8216246482 3.78e-07
12 -385.8216246486 8.85e-08
13 -385.8216246487 8.02e-09 Convergence criterion met
SCF time: CPU 35.93s wall 5.00s
SCF energy in the final basis set = -385.8216246487
Total energy in the final basis set = -385.8216246487
TDDFT/TDA Excitation Energies
Excited state 1: excitation energy (eV) = 1.6706
Total energy for state 1: -385.76023236 au
Multiplicity: Singlet
Trans. Mom.: 0.0000 X 0.3394 Y -0.0000 Z
Strength : 0.0047155919
D( 34) --> V( 1) amplitude = 0.9900
Excited state 2: excitation energy (eV) = 3.5081
Total energy for state 2: -385.69270494 au
Trans. Mom.: -0.1205 X -0.0000 Y 0.0000 Z
Strength : 0.0012481775
D( 33) --> V( 1) amplitude = -0.6906
D( 34) --> V( 2) amplitude = 0.7072
Excited state 3: excitation energy (eV) = 4.7501
Total energy for state 3: -385.64706164 au
Trans. Mom.: 0.0000 X -0.2693 Y 0.0000 Z
Strength : 0.0084379229
D( 32) --> V( 1) amplitude = -0.5658
D( 33) --> V( 2) amplitude = 0.8002
Adiabatic excitation energy is the energy difference between the equilibrium structures in the ground and excited states. The energies must be computed with compatible levels of theory (i.e. HF/CIS, DFT/TDDFT) and could be corrected by ZPE. The steps are as follows:
- Optimize the geometry of the ground state, note the SCF energy of the equilibrium structure, E0.
- Optimize the geometry of the desired excited state, note the absolute CIS energy of the equilibrium structure, E1. This energy is printed under
Total energy for state Xin the CIS output. - Compute E(exc) = E1 - E0
If ZPE correction is desired, perform respective vibrational frequencies calculations at steps 1 and 2 and correct E0 and E1 for ZPE.
Thanks a lot, and can you help me explain the Electronic Transition Dipole Emission(ETDE) and Electronic Transition Dipole Absorption (EDMA) in output file of excited state?
Sorry I don’t have much experience computing those properties, but presumably they are just transition dipole moments at the two geometries.
The components of the transition electric dipole vector are given under Trans. Mom., in your output sample for state 1 for example:
|mu|2 = 0.00002 + 0.33942 + 0.00002 = 0.1152
These quantities are given in atomic units.
Methods for computing electronic couplings are described in the Q-Chem manual here:
https://manual.q-chem.com/4.3/sec-ElCoupl.html
and also in this webinar:
https://www.q-chem.com/webinars/6
