Calculate the nonadiabatic coupling with external charge
Hi there,
When I did the nonadiabatic coupling with an extra keyword $external charges,
the calculations interrupted as follows:
  •         CIS Derivative Couplings*
  •          between states 0 and 1*
NCharge is 392
  • get_w_dc time: CPU 298.52 s wall 15.52 s*
  • … ESP will be evaluated on a read-in grid points from file ESPGrid.*
  • … The data will be saved in the file plot.esp*
On top of that, the error message indicates that
Fortran runtime error: Cannot open file ‘ESPGrid’: No such file or directory
May I know what’s going wrong with this?
Thanks in advance.
can you please provide a minimal input file that exhibits this problem?
Hi there,
Thank you for attention.
Despite omitting the details of coordinates and charges (the position unit of external charge is A),
it basically looks like as follows:
H -4.658 0.087 3.438
H 2.511 -1.022 -4.204
C 3.797 -0.064 -2.778
jobtype sp
basis 6-31G**
method pbe0
cis_n_roots 4
cis_triplets true
rpa true
CIS_DER_NUMSTATE 3
CALC_NAC true
set_quadratic false
set_iter 100
$derivative_coupling
comment
0 1 2
$external_charges
-2.150 -4.349 0.012 0.594
-0.195 -3.584 0.690 0.062
-3.059 -4.814 -0.723 -0.497
Please post a complete input file that exhibits the problem, and I will look into it. If it’s a problem with $external_charges then you might only need one charge, and small molecules are easier for debugging and testing.
Thank you for the feedback.
I tried a simple molecule, but same error occured.
C -0.959750 0.241930 -0.011920
C 0.446990 0.242050 -0.011870
C 1.151170 1.459990 -0.012690
C 0.446830 2.676860 -0.013680
C -0.958870 2.676710 -0.013970
C -1.663570 1.459890 -0.012720
H -1.506840 -0.705280 -0.012170
H 0.994350 -0.704990 -0.011840
H 2.244630 1.457710 -0.011690
H 0.987530 3.625980 -0.013980
H -1.499650 3.625710 -0.015380
H -2.757010 1.458500 -0.013820
jobtype sp
basis 6-31G**
method pbe0
cis_n_roots 3
cis_singlets true
cis_triplets false
rpa true
CIS_DER_NUMSTATE 3
CALC_NAC true
set_quadratic false
set_iter 100
comment
0 1 2
$external_charges
7.715147 7.223384 1.330103 -0.094319
7.779379 6.982973 -1.301776 -0.094733
6.658450 8.829292 -2.824952 -0.099668
5.460383 10.909124 -1.717081 -0.093927
5.397606 11.150537 0.914911 -0.101064
6.532443 9.311701 2.437614 -0.095811
8.579319 5.793390 2.509443 0.094976
8.693213 5.366879 -2.159485 0.095589
6.715350 8.646858 -4.860829 0.097792
4.582151 12.330652 -2.896289 0.096258
4.471149 12.759091 1.773262 0.097696
6.492589 9.502828 4.473038 0.097209
-1.559137 2.831074 6.516853 -0.096564
1.082341 2.928887 6.501338 -0.103902
2.317919 5.261413 6.358985 -0.090988
0.911358 7.496355 6.229898 -0.098731
-1.729629 7.398637 6.247529 -0.099416
-2.965415 5.065883 6.392169 -0.096897
-2.514904 1.025668 6.613701 0.098222
2.170067 1.199182 6.586470 0.099086
4.361337 5.334546 6.338576 0.095612
1.864309 9.301610 6.113170 0.097996
-2.814823 9.128417 6.145465 0.098029
-5.008738 4.987649 6.396005 0.097553
-8.667550 7.121376 1.197047 -0.089526
-8.605473 7.284724 -1.440803 -0.094618
-7.416268 9.335436 -2.609939 -0.099384
-6.272644 11.213503 -1.142661 -0.095371
-6.333682 11.049437 1.495321 -0.090760
-7.538439 9.007436 2.664608 -0.108992
-9.585900 5.534063 2.102396 0.094393
-9.475692 5.823815 -2.577076 0.095267
-7.377925 9.466980 -4.650068 0.097437
-5.341046 12.792841 -2.048463 0.095469
-5.448969 12.501597 2.631633 0.095322
-7.593430 8.884623 4.704946 0.100762
-2.048879 2.780732 -6.540607 -0.098389
0.590917 2.645087 -6.554742 -0.096001
2.028867 4.861302 -6.464772 -0.096021
0.826415 7.213368 -6.357152 -0.095485
-1.812871 7.348937 -6.340504 -0.097613
-3.251104 5.132515 -6.434291 -0.094529
-3.161115 1.065541 -6.599018 0.096727
1.520852 0.824960 -6.623868 0.096230
4.070886 4.753965 -6.467663 0.096493
1.935987 8.929013 -6.283661 0.095831
-2.739914 9.169235 -6.252631 0.096362
-5.293255 5.235033 -6.415299 0.096394
Thanks. This looks like a bug, reproducible with the latest version of Q-Chem. I will post a ticket.
Hi there,
May I know when this bug can be fixed normally?
Hard to say. In this case there is someone at Q-Chem looking at it.
Hi Steven, the Q-Chem Office is already working on this ticket. We will notify you as soon as we have an update. Thank you.
Hi there,
Sorry for taking your time.
It’s been almost one month now, any new updates, please?
A fix for this was committed on June 12, ticket #3381. Is available to developers now (in the trunk) and will ship with Q-Chem v. 6.2.1.
Hi, sorry for taking your time again.
I requested one developer of Q-Chem to test whether this bug has been fixed (same input file as before).
Unfortunately, the task was not successfully completed yet, and the error message is
qcprog.exe: malloc.c:4036: _int_malloc: Assertion `(unsigned long) (size) >= (unsigned long) (nb)’ failed.
Could you please check again?
Thanks in advance.
I also get a crash with the current Q-Chem trunk and your original input file. I will reopen the ticket.
Hi there,
Any progress so far?
The ticket is open but I don’t know the specifics. It is ticket #3381 if you have access to Q-Chem Trac site.
There has been a new fix checked in for this, and your sample seems to work. Please check it out and see if it works for you.
Thank you very much for the effort.
No problem, but this one’s on Q-Chem staff, I’m just the reporter.
Hi, I am truly sorry for taking your time again.
I requested one developer of Q-Chem to confirm this bug has been fixed (same input file as before).
However, when we examined the results carefully, the output seemed not to be correct.
Because the number of total atoms is only 12, but the CIS deriativce coupling with ETF also included the “dummy atoms” (positions of the 48 point charges), together 60 atoms (12+48), see below.
So there are supposed to be some minor errors left.
Could you please double check again?
Thank you.
CIS derivative coupling with ETF
Atom X Y Z
1 0.016288 -0.018610 -0.000106
2 0.019265 0.018557 -0.000143
3 -0.008832 -0.000659 -0.000030
4 -0.009819 0.005330 0.000041
5 -0.011745 -0.005969 0.000168
6 -0.006640 0.001304 0.000081
7 -0.005795 0.003535 0.000076
8 -0.005757 -0.003489 0.000074
9 0.000358 -0.007062 0.000013
10 0.006232 -0.003352 -0.000007
11 0.006185 0.003333 -0.000103
12 0.000263 0.007083 -0.000065
13 0.000000 0.000000 0.000000
14 0.000000 0.000000 -0.000000
15 0.000000 0.000000 -0.000000
16 0.000000 0.000000 -0.000000
17 0.000000 0.000000 0.000000
18 0.000000 0.000000 0.000000
19 -0.000000 -0.000000 -0.000000
20 -0.000000 -0.000000 -0.000000
21 -0.000000 -0.000000 0.000000
22 -0.000000 -0.000000 0.000000
23 0.000000 -0.000000 -0.000000
24 -0.000000 -0.000000 -0.000000
25 -0.000001 -0.000000 -0.000000
26 -0.000001 0.000000 0.000000
27 -0.000000 0.000000 0.000000
28 -0.000000 0.000000 0.000000
29 -0.000000 -0.000000 0.000000
30 -0.000000 -0.000000 -0.000000
31 0.000001 0.000000 0.000001
32 0.000000 -0.000000 -0.000001
33 -0.000000 -0.000000 -0.000000
34 0.000000 -0.000000 -0.000000
35 0.000000 0.000000 -0.000000
36 0.000000 0.000000 0.000000
37 0.000000 -0.000000 -0.000000
38 0.000000 -0.000000 0.000000
39 -0.000000 -0.000000 0.000000
40 -0.000000 -0.000000 0.000000
41 -0.000000 -0.000000 0.000000
42 -0.000000 -0.000000 -0.000000
43 -0.000000 0.000000 0.000000
44 -0.000000 0.000000 -0.000000
45 0.000000 0.000000 -0.000000
46 0.000000 0.000000 0.000000
47 0.000000 0.000000 -0.000000
48 0.000000 0.000000 0.000000
49 -0.000001 -0.000000 0.000001
50 -0.000001 -0.000000 -0.000000
51 -0.000000 0.000000 -0.000000
52 -0.000000 0.000000 -0.000000
53 -0.000000 -0.000000 -0.000000
54 -0.000000 -0.000000 0.000000
55 0.000000 0.000000 -0.000001
56 0.000000 -0.000000 0.000001
57 -0.000000 -0.000000 0.000000
58 0.000000 -0.000000 0.000000
59 0.000000 0.000000 0.000000
60 0.000000 0.000000 -0.000000
why don’t you just have that developer communicate directly with us on Trac? It’s ticket #3381. This would eliminate me having to act as go-between.
