Hello, I am trying to calculate some excited states using eom-sf-ccsd calculation in Q-Chem 5.4.0. But I can’t calcute more then 5 states. Can anybody give some hints?
From this snippet it looks like Q-Chem is solving for 6, not 5, states. Does this problem occur every time you try this job? Does it crash at the same exact spot? Have you tries using a different number of threads (qchem -nt N)? I would also suggest sending your full output to support@q-chem.com for further investigation.
Yes, this problem occurs every time when I am submitting the job and exits at the same spot. I have also tried with different number of threads too but the result is same. I am sending the full output file at the given mail id. Please check.
We received the files you sent, thank you. I don’t know what may be causing the crash, but in the input file you are asking for 480GB of memory for a very small job. It shouldn’t be a problem in itself (unless your workstation doesn’t in fact have that much memory), but replacing your memory settings with defaults makes the job complete in seconds:
Thanks for your response. Actually I thought that problem may occur due to memory so I had used maximum available memory. I have also tried according to your suggestions but the problem didn’t resolved.
