Dear developers,
I have a sudden crash due tu a CCMAN error when trying to compute excited states using EOM-CC(2,3) in Q-Chem V 6.1.1
Here is a copy of the input:
C -1.857461 0.424587 0.000000
C -0.605213 -0.299251 0.000000
H -0.656663 -1.386648 0.000000
H -1.798219 1.510280 0.000000
C 1.857452 -0.424581 0.000000
C 0.605217 0.299281 0.000000
H 0.656667 1.386676 0.000000
H 1.798173 -1.510272 0.000000
C 3.060973 0.170339 0.000000
H 3.148824 1.251092 0.000000
H 3.976390 -0.406881 0.000000
C -3.060965 -0.170367 0.000000
H -3.976397 0.406829 0.000000
H -3.148790 -1.251122 0.000000
METHOD eom-cc(2,3)
JOBTYPE SP
BASIS def2-SVP
MEM_STATIC 2048
CC_MEMORY 250000
MEM_TOTAL 280000
SYMMETRY true
POINT_GROUP_SYMMETRY true
SYM_TOL 4
CC_SYMMETRY true
EE_STATES [2,0,0,2]
STATE_ANALYSIS true
EOM_PRECONV_SD 10
EOM_PRECONV_SD 20
cc_eom_prop true
cc_trans_prop true
NTO_PAIRS 8
molden_format true
print_orbitals 10
plots true
MAKE_CUBE_FILES NTOS
WFA_LEVEL 4
WFA_ORB_THRESH 4
$plots
grid_points 70 75 75
natural_transition_orbital 1-4
And the last part of the output
Beginning Lambda iterations
Itr|Var|D|Delta_L|Comments
1|Lam|-|5.4E-02|
2|Lam|-|9.6E-03|
3|Lam|-|4.1E-03|
4|Lam|+|1.7E-03|
5|Lam|+|6.6E-04|
6|Lam|+|2.8E-04|
7|Lam|+|1.1E-04|
8|Lam|+|5.1E-05|
9|Lam|+|1.6E-05|
10|Lam|+|6.3E-06|
11|Lam|+|2.3E-06|
12|Lam|+|8.3E-07|
13|Lam|+|2.9E-07|
14|Lam|+|1.1E-07|
15|Lam|+|5.4E-08|
16|Lam|+|2.5E-08|
17|Lam|+|1.2E-08|
18|Lam|+|5.4E-09|
Lambda calculation converged, 18 iterations
Largest T amplitudes
Largest singles amplitudes:
Value i -> a
0.0316 15( Au ) B -> 53( Au ) B
0.0316 15( Au ) A -> 53( Au ) A
0.0277 13( Bg ) B -> 38( Bg ) B
0.0277 13( Bg ) A -> 38( Bg ) A
0.0226 14( Au ) B -> 52( Au ) B
Largest doubles amplitudes:
Value i j -> a b
-0.1146 15( Au ) A, 15( Au ) B -> 36( Bg ) A, 36( Bg ) B
-0.0624 13( Bg ) A, 15( Au ) B -> 36( Bg ) A, 51( Au ) B
-0.0624 15( Au ) A, 13( Bg ) B -> 51( Au ) A, 36( Bg ) B
-0.0578 13( Bg ) A, 13( Bg ) B -> 51( Au ) A, 51( Au ) B
-0.0531 13( Bg ) A, 13( Bg ) B -> 36( Bg ) A, 36( Bg ) B
EHF = -231.641840433
EMP2 = -232.436364590
Correlation Energy = -0.855866020
CCSD Total Energy = -232.497706453
CCSD or (V)OO-CCD job: CPU 402.45 s wall 42.00 s
Adjusting EOM_EE_STATES
DOING EOM-CC(2,3) CALCULATIONS
Ints::Get() : integral not found
Integral type:
AB AOCC AB AOCC
CCMAN error!
I will appreciate any help you could give me to solve this issue.
Many thanks in advance
Federico
