CDFT block set up
I have a question regarding how to correctly define the CDFT constraint for my donor–acceptor system. My system consists of an OPP–TEA complex with a total of 54 atoms:
  • Atoms 1–32 correspond to the OPP fragment (acceptor)
  • Atoms 33–54 correspond to the TEA fragment (donor)
I am trying to model single-electron transfer from TEA to OPP (TEA → OPP), corresponding to OPP⁻ and TEA⁺.
In my current input, I used the following CDFT block:
   H      -3.15586000    -2.07760000    -0.59452000
   C      -3.66695000    -1.16159000    -0.31493000
   C      -2.90802000     0.00000000     0.00000000
   C      -3.66695000     1.16159000     0.31493000
   H      -3.15586000     2.07760000     0.59452000
   C      -5.05390000     1.15739000     0.31223000
   H      -5.58500000     2.07098000     0.56890000
   C      -5.77352000     0.00000000     0.00000000
   H      -6.85892000     0.00000000     0.00000000
   C      -5.05390000    -1.15739000    -0.31223000
   H      -5.58500000    -2.07098000    -0.56890000
   C      -1.45994000     0.00000000     0.00000000
   C      -0.68631000     1.20442000     0.00521000
   C       0.68631000     1.20442000    -0.00521000
   C       1.45994000    -0.00000000     0.00000000
   C       0.68631000    -1.20442000     0.00521000
   C      -0.68631000    -1.20442000    -0.00521000
   C       2.90802000    -0.00000000     0.00000000
   C       3.66695000     1.16159000    -0.31493000
   C       5.05390000     1.15739000    -0.31223000
   C       5.77352000    -0.00000000     0.00000000
   C       5.05390000    -1.15739000     0.31223000
   C       3.66695000    -1.16159000     0.31493000
   H      -1.19209000     2.16631000    -0.00708000
   H       1.19209000     2.16631000     0.00708000
   H       1.19209000    -2.16631000    -0.00708000
   H      -1.19209000    -2.16631000     0.00708000
   H       3.15586000     2.07760000    -0.59452000
   H       5.58500000     2.07098000    -0.56890000
   H       6.85892000    -0.00000000     0.00000000
   H       5.58500000    -2.07098000     0.56890000
   H       3.15586000    -2.07760000     0.59452000
   N       0.00039100     0.00467400     2.90192500
   C       1.37462100     0.46378100     2.91384600
   C       1.73135700     1.14866000     4.23998800
   C      -0.28865800    -1.41522700     2.91167600
   C       0.14265000    -2.07049000     4.23080600
   C      -1.08432100     0.96539700     2.92133400
   C      -1.87588000     0.90399600     4.23432200
   H       1.47514700     1.17701700     2.08789800
   H       2.02119500    -0.39382500     2.72656200
   H       1.10511000     2.02556700     4.41753600
   H       2.77091000     1.47525000     4.17632900
   H       1.62721100     0.45566700     5.07677800
   H       0.26954600    -1.85493600     2.07734200
   H      -1.35631400    -1.54746800     2.73539600
   H       1.21979500    -1.98432800     4.38704700
   H      -0.11647800    -3.12942700     4.17649800
   H      -0.38077200    -1.62152700     5.07709700
   H      -1.73900400     0.71339400     2.07891300
   H      -0.66270600     1.95782100     2.76177900
   H      -2.33516200    -0.07589500     4.37965500
   H      -2.66857300     1.65238400     4.17975800
   H      -1.23259100     1.13162800     5.08662500
   JOB_TYPE              Optimization
   METHOD                wB97X-D
   BASIS                 6-31G**
   SCF_CONVERGENCE       8
   SCF_MAX_CYCLES        800
   SCF_ALGORITHM         DIIS_GDM
   GEOM_OPT_MAX_CYCLES   200
   UNRESTRICTED          TRUE
   SYMMETRY              FALSE
   SYM_IGNORE            TRUE
   CDFT                  TRUE
   CDFT_PRINT            TRUE
   CDFT_BECKE_POP        TRUE
   CDFT_THRESH           8
   BECKE_SHIFT           UNSHIFTED
   XC_GRID               000099000590
   SOLVENT_METHOD        PCM
   THEORY                CPCM
   heavypoints           590
   method                swig
   radii                 bondi
   solver                inversion
   DIELECTRIC  37.5
   OPTICALDIELECTRIC  1.8068
$cdft
2
1 1 32
   JOB_TYPE              Freq
   METHOD                wB97X-D
   BASIS                 6-31G**
   SCF_CONVERGENCE       8
   VIBMAN_PRINT          4
   UNRESTRICTED          TRUE
   SYMMETRY              FALSE
   SYM_IGNORE            TRUE
   SOLVENT_METHOD        PCM
   CDFT                  TRUE
   CDFT_PRINT            TRUE
   CDFT_BECKE_POP        TRUE
   CDFT_THRESH           8
   MEM_TOTAL             248000
   MEM_STATIC            4000
   THEORY                CPCM
   heavypoints           590
   method                swig
   radii                 bondi
   solver                inversion
   DIELECTRIC  37.5
$cdft
2
1 1 32
After convergence, this enforced +2 excess electrons on the first fragment (OPP). This seems to result in a two-electron transfer state rather than the intended single-electron transfer.
But when I tried with the following CDFT block I am getting convergence issue.
$cdft
1
1 1 32
Could anyone please guide me how to correctly set up CDFT block?
My reading of the manual,
https://manual.q-chem.com/latest/Ch5.S11.SS1.html
suggests that your first format is supposed to result in a two-electron transfer. You might try implementing this with a charge and a spin constraint, as in Example 5.26.
If that fails, and in light of some recent discussion amongst Q-Chem developers, you might try a single-state CDFT-CI calculation. The reason is that CDFT-CI uses a somewhat different convergence algorithm that at least one person thought to be more robust than the Becke partition that you are using in this example.
