Charge/Spin combination error CDFT-CI
Hello, I have a question regarding CDFT-CI. I need to calculate the coupling value between two diabatic states in a molecule AB* that exhibits charge transfer under certain external stimuli (i.e. changes in the polarity of the solvent), that cause an unpaired electron to go from subunit B to subunit A : AB* → [A+*B-] . My input looks like this:
A
B
GUI 2
METHOD B3LYP
BASIS def2-tzvp
MAX_SCF_CYCLES 300
becke_shift unshifted
cdftci = true
cdft_print = true
cdftci_print = 1
!unit A : from atom 1 to atom 13, unit B: from atom 14 to atom 50
$cdft
0
1 1 13
0
1 1 13 s
-1
1 1 13
1
1 1 13 s
but when I try to run the code I end up with the error
Bailing from block 0
Q-Chem fatal error occurred in module liblas/Fock2MOBlockCDFTCI.C, line 106:
Invalid charge/spin combination in CDFT-CI block
I tried a lot of different possibilities, but the only working ones were of the type
$cdft
0
1 1 13 s
1
1 14 50 s
1
1 1 13 s
0
1 14 50 s
but this isn’t enough to have the CT I need. Note that I didn’t have any problems performing a CDFT optimization under similar conditions
Thank you in advance for your attention,
LS
can you please provide a complete input file?
For sure, here you have the complete input:
H      11.8049784015     0.0579990310    -1.7495017840
H      10.3708062555     1.8136524306    -2.9496524800
C      10.0564707912     1.2463951564    -2.0863184691
C      10.8010607040     0.3343666756    -1.4636950342
S      10.1240892235    -0.4407381708    -0.0497499487
S       8.4698687716     1.5851657816    -1.4332440328
C       8.5277317765     0.2887301047    -0.2374330122
C       7.4491739466    -0.1035618152     0.4631320330
S       7.4905242900    -1.4099710661     1.6465057478
S       5.8616375671     0.6398508385     0.2820813667
C       4.9909898767    -0.6659491018     1.1051159496
C       5.7701872735    -1.5737876130     1.7289350996
H       5.3746160909    -2.3984396153     2.3045243498
C       3.5575161301    -0.6973480089     1.1059687088
H       3.1242322858    -1.5039403322     1.6866023760
C       2.7577642186     0.1655867250     0.4478911589
H       3.2165502081     0.9539989462    -0.1396434086
C       1.3106438970     0.1354972169     0.4092639907
H       1.0020633935    -1.5186409220     1.7692420681
C       0.5386997161    -0.7995265645     1.1111175554
H       1.1900177957     1.7997190497    -0.9480862045
C       0.6317817645     1.0681327010    -0.3809475839
C      -0.7417416826     1.0473985280    -0.4881443432
Cl     -1.4409623716     2.1878435356    -1.6037604594
C      -1.5472024418     0.0976802226     0.1772673586
C      -0.8304587827    -0.8081190491     0.9964310687
Cl     -1.6822546797    -1.9479815722     2.0038270892
C      -2.9821514072     0.0322053161     0.0130476267
Cl     -1.8146815439    -1.8133080966    -2.1688540792
C      -3.1649263924    -2.1905135426    -1.1398969824
C      -3.6350653875    -1.2556638818    -0.1965330139
C      -3.7782983680    -3.4097676430    -1.3605468663
H      -3.3905360006    -4.0860570762    -2.1065454609
C      -4.9098684869    -3.7323273929    -0.6305727242
Cl     -5.6969300564    -5.2565853413    -0.8997441684
C      -5.4228938659    -2.8566070436     0.3109544429
H      -6.2935691051    -3.1166238185     0.8927898206
C      -4.7849146264    -1.6469159455     0.5152136020
Cl     -5.4259463902    -0.6452415451     1.7841014435
Cl     -4.9466478655     0.4947404397    -2.3291196307
C      -4.7555284569     1.5315889571    -0.9461532038
C      -3.7899303507     1.2462340994     0.0374326266
C      -3.6683894346     2.2071371128     1.0589366511
Cl     -2.5785970464     1.9514291929     2.3894735425
C      -4.4397068383     3.3535694663     1.1089471045
H      -4.3218467578     4.0528590077     1.9222570922
C      -5.3768693319     3.5732441090     0.1135321885
Cl     -6.3600421145     5.0039501775     0.1640795460
C      -5.5428574024     2.6678618806    -0.9205050001
H      -6.2594760782     2.8509157149    -1.7061779091
GUI 2
METHOD B3LYP
BASIS def2-tzvp
MAX_SCF_CYCLES 300
cdftci = true
cdftci_print = 1
$cdft
0
1 1 13
0
1 1 13 s
-1
1 1 13
1
1 1 13 s
LS
hey again, I am still looking for a solution. I obtained some results with the keyword “CDFTCI_SKIP_PROMOLECULES true”, but I think I am in a situation where promolecule calculation could be useful…
