Checking the input file for inconsistencies... Error Debug
Hi, I am trying to compute ET coupling between OPP and TEA using GMH method but I am constantly encountering this error : “Checking the input file for inconsistencies…” and my job is getting terminated. This is my input file:
H 1.2945544 -1.3935578 -2.3741943
C 0.7009073 -0.6599476 -2.9101978
C -0.0347132 0.2901315 -2.1931721
C -0.7703337 1.2402106 -2.9101978
H -1.3639808 1.9738208 -2.3741943
C -0.7704486 1.2404896 -4.3000078
H -1.3536002 1.9821964 -4.8367939
C -0.0347132 0.2901315 -5.0010610
H -0.0347132 0.2901315 -6.0863461
C 0.7010222 -0.6602266 -4.3000078
H 1.2841738 -1.4019334 -4.8367939
C -0.0347132 0.2901315 -0.7088554
C -0.0352334 1.4879618 0.0130492
C -0.0341930 1.4879618 1.4005526
C -0.0347132 0.2901315 2.1224572
C -0.0352334 -0.9076988 1.4005526
C -0.0341930 -0.9076988 0.0130492
C -0.0347132 0.2901315 3.6067739
C 0.7009073 1.2402106 4.3237996
C 0.7010222 1.2404896 5.7136096
C -0.0347132 0.2901315 6.4146628
C -0.7704486 -0.6602266 5.7136096
C -0.7703337 -0.6599476 4.3237996
H -0.0237787 2.4346169 -0.5175733
H -0.0456477 2.4346169 1.9311751
H -0.0237787 -1.8543539 1.9311751
H -0.0456477 -1.8543539 -0.5175733
H 1.2945544 1.9738208 3.7877961
H 1.2841738 1.9821964 6.2503957
H -0.0347132 0.2901315 7.4999479
H -1.3536002 -1.4019334 6.2503957
H -1.3639808 -1.3935578 3.7877961
N 0.1014491 -0.8479077 -0.6499654
C -1.2840573 -0.4370145 -0.8921652
C -1.7365486 0.6990803 0.0165998
C 0.6787973 -1.5004962 -1.8278447
C 1.1072584 -0.5145835 -2.9075923
C 0.2011805 -1.7043235 0.5347859
C 1.5909372 -1.7018999 1.1589571
H -1.9711734 -1.2970434 -0.7959007
H -1.3627839 -0.0999236 -1.9285962
H -1.7005976 0.4214326 1.0734802
H -2.7673319 0.9826079 -0.2146951
H -1.0985353 1.5760655 -0.1232681
H -0.0230138 -2.2438042 -2.2474142
H 1.5600545 -2.0611516 -1.5063609
H 0.2651336 0.0621563 -3.2992401
H 1.5610640 -1.0468066 -3.7485357
H 1.8420416 0.1901880 -2.5087652
H -0.1070006 -2.7388988 0.2979623
H -0.5105538 -1.3381734 1.2788917
H 2.3529718 -2.0816052 0.4729771
H 1.6062189 -2.3348308 2.0508338
H 1.8753835 -0.6872430 1.4506745
BASIS = 6-31G(d,p)
METHOD = CIS
CIS_N_ROOTS 20
CIS_SINGLETS = TRUE
CIS_TRIPLETS = FALSE
CIS_STATE_DERIV = 1
STS_GMH = TRUE
SOLVENT_METHOD = PCM
MEM_TOTAL = 64000
MEM_STATIC = 6000
THEORY CPCM
heavypoints 590
method swig
radii bondi
solver inversion
DIELECTRIC 35.688
OPTICALDIELECTRIC 1.8068
Could anyone help me with this?
what does the end of the output file look like? That “checking for inconsistencies” is designed to catch incompatible keywords in the input file.
Job is consistently terminating during the initial setup stage, specifically at the “Checking the input file for inconsistencies” step, and exits with a segmentation fault (core dumped). The SCF does not start. I sharing the output file message:
Q-Chem begins on Tue Dec 23 11:00:02 2025
Host:
0
 Scratch files written to /scratch1/hsaha/scratch/qchem/2371421/qchem1233302//
May2125 |scratch|qcdevops|jenkins|workspace|build_RNUM -1
Processing $rem in /apps/generic/qchem/6.3.0/openmp/config/preferences:
Processing $rem in /home1/hsaha/.qchemrc:
Symmetry turned off for PCM/SM12/SMD calculation
Checking the input file for inconsistencies… /apps/generic/qchem/6.3.0/openmp/bin/qchem: line 129: 1233315 Segmentation fault (core dumped) ${QCPROG_S} ${inp} ${scr}
Error in Q-Chem run part 1
remove work dirs /scratch1/hsaha/scratch/qchem/2371421/qchem1233302.0 – /scratch1/hsaha/scratch/qchem/2371421/qchem1233302.0
rm -rf /scratch1/hsaha/scratch/qchem/2371421/qchem1233302.0
Error in the Q-Chem run
Are those actual blank lines in your PCM file? Those are not allowed. I can reproduce your behavior with those blank lines, but when I remove them the job runs normally (using Q-Chem 6.4).
