Complex Scaling on Q-Chem
I want to calculate the Mg- resonance using the complex scaling eom-ea-ccsd method, but the calculation refuses to run.
More specifically, Q-Chem only performs the coupled-cluster calculation but completely ignores the eom-ea-ccsd part and the complex scaling part.
When I perform the eom-ea-ccsd calculation without complex scaling, Q-Chem produces the complete response.
I admit that I do not know how to solve this problem, as the qchem manual does not detail complex scaling.
Here is my input:
Mg- shape resonance using CS-EOM-EA-CCSD
Mg 0.0 0.0 0.0
METHOD EOM-CCSD
BASIS gen
EA_STATES [2,2,2,2,2,2,2,2]
CC_EOM_PROP true
COMPLEX_CCMAN 1
CC_MEMORY 4000
MEM_TOTAL 8000
$complex_ccman
CS_HF true
CS_CCSD true
CS_THETA 10
Mg 0
S 15 1.00
1.649000D+05 7.299290D-05
2.471000D+04 5.666520D-04
5.628000D+03 2.962690D-03
1.596000D+03 1.229620D-02
5.210000D+02 4.273240D-02
1.880000D+02 1.230130D-01
7.301000D+01 2.748320D-01
2.990000D+01 4.018180D-01
1.254000D+01 2.646970D-01
4.306000D+00 3.326120D-02
1.826000D+00 -4.413350D-03
7.417000D-01 2.060240D-03
1.457000D-01 -8.384700D-04
7.612000D-02 7.081950D-04
3.310000D-02 -2.006020D-04
S 15 1.00
1.649000D+05 -1.842480D-05
2.471000D+04 -1.435000D-04
5.628000D+03 -7.487100D-04
1.596000D+03 -3.144070D-03
5.210000D+02 -1.104810D-02
1.880000D+02 -3.360580D-02
7.301000D+01 -8.259460D-02
2.990000D+01 -1.593140D-01
1.254000D+01 -1.528880D-01
4.306000D+00 1.908490D-01
1.826000D+00 5.799640D-01
7.417000D-01 3.720290D-01
1.457000D-01 2.116910D-02
7.612000D-02 -1.193440D-02
3.310000D-02 2.773290D-03
S 1 1.00
1.457000D-01 1.000000D+00
S 15 1.00
1.649000D+05 3.551760D-06
2.471000D+04 2.764200D-05
5.628000D+03 1.444040D-04
1.596000D+03 6.057440D-04
5.210000D+02 2.135270D-03
1.880000D+02 6.499340D-03
7.301000D+01 1.614460D-02
2.990000D+01 3.157660D-02
1.254000D+01 3.163740D-02
4.306000D+00 -4.391400D-02
1.826000D+00 -1.510930D-01
7.417000D-01 -2.176680D-01
1.457000D-01 2.598070D-01
7.612000D-02 5.472450D-01
3.310000D-02 3.259100D-01
S 1 1.00
3.310000D-02 1.000000D+00
S 1 1.00
1.200000D-02 1.000000D+00
S 1 1.00
6.000000D-03 1.000000D+00
P 10 1.00
3.169000D+02 2.075320D-03
7.486000D+01 1.628690D-02
2.372000D+01 7.386970D-02
8.669000D+00 2.142970D-01
3.363000D+00 3.821540D-01
1.310000D+00 3.981780D-01
4.911000D-01 1.528780D-01
2.364000D-01 -4.375400D-03
8.733000D-02 6.295820D-03
3.237000D-02 -1.567690D-03
P 1 1.00
8.733000D-02 1.000000D+00
P 10 1.00
3.169000D+02 -3.297270D-04
7.486000D+01 -2.587540D-03
2.372000D+01 -1.191200D-02
8.669000D+00 -3.502270D-02
3.363000D+00 -6.399680D-02
1.310000D+00 -7.044360D-02
4.911000D-01 -3.758360D-02
2.364000D-01 1.770430D-01
8.733000D-02 5.667070D-01
3.237000D-02 3.961430D-01
P 1 1.00
3.237000D-02 1.000000D+00
P 1 1.00
9.000000D-03 1.000000D+00
P 1 1.00
4.400000D-03 1.000000D+00
D 1 1.00
2.998000D-01 1.000000D+00
D 1 1.00
1.285000D-01 1.000000D+00
D 1 1.00
4.440000D-02 1.000000D+00
D 1 1.00
2.200000D-02 1.000000D+00
F 1 1.00
2.417000D-01 1.000000D+00
F 1 1.00
8.650000D-02 1.000000D+00
F 1 1.00
4.325000D-02 1.000000D+00
Thank you in advance.
Translated with DeepL.com (free version)
Can you please give more details how the calculation progresses? Ideally, it would be most helpful to the output. You can upload file to a google drive and post a link in your response.
As a scientific recommendation, straight CS is not very good – CAP or CBF calculations are much more robust.
Here is what you need to use to run CAP-EOM-EA:
$complex_ccman
CS_HF 1
CAP_TYPE 1
CAP_ETA 10000
CAP_X 2000
CAP_Y 2500
CAP_Z 2500
And for CBF:
$complex_ccman
cs_theta = 0
cs_alpha = 100
There are examples for such jobs in the $QC/samples/ccman2 directory.
I figured out – your input will work with this modification:
$complex_ccman
CS_HF 1
CS_CCSD 1
CS_THETA 10
Within complex_ccman section, you cannot substitute integers by boolean.
My advice about CS vs CBF or CAP still stands.
