I want to perform a constrained geometry optimization job with an ethanol+water system, with the ethanol molecule fixed and the water geometry (bond lengths and angle fixed), so as to only optimize the ethanol water distance and rotation of water molecule. This is the input I am using,
JOBTYPE=OPT
METHOD=HF
BASIS=6-31G*
SCF_CONVERGENCE=8
GEOM_OPT_DRIVER=OPTIMIZE ! Use the old driver
GEOM_OPT_MAX_CYCLES=200
NO_REORIENT=TRUE
SYM_IGNORE=TRUE
HARM_OPT=1 ! Turn on harmonic confining potential
HOATOMS=9 ! Number of confined atoms
HARM_FORCE=450 ! Force constant of the potential
$harmonic_opt
1 2 3 4 5 6 7 8 9
$opt
CONSTRAINT
stre 10 11 0.9572
stre 10 12 0.9572
bend 11 10 12 104.52
ENDCONSTRAINT
C -0.02800000086426735 0.004999999888241291 -0.0010000000474974513
H -0.4950000047683716 0.9340000152587891 0.3449999988079071
H -0.3440000116825104 -0.7979999780654907 0.671999990940094
H -0.3970000147819519 -0.210999995470047 -1.00600004196167
C 1.4859999418258667 0.1379999965429306 -0.020999999716877937
H 1.8669999837875366 0.34200000762939453 0.9900000095367432
H 1.9470000267028809 -0.7919999957084656 -0.3630000054836273
O 1.9299999475479126 1.1319999694824219 -0.9440000057220459
H 1.5729999542236328 1.9830000400543213 -0.6399999856948853
O -1.347000002861023 2.630000114440918 0.9760000109672546
H -0.9129999876022339 3.440000057220459 1.2410000562667847
H -2.2809998989105225 2.812000036239624 1.0820000171661377
$coords
This job does not converge even after 200 steps and the problem is that the Hessian stop updating after a certain point, with the following warning,
Cartesian Hessian Update
Hessian updated using BFGS update
**WARNING** Hereditary positive definiteness endangered
due to small product of step size times gradient change
**WARNING** Small scalar product
Hessian update skipped this cycle
This is the gradient, displacement, and energy change at Step 200,
Maximum Tolerance Cnvgd?
Gradient 0.006739 0.000300 NO
Displacement 0.000002 0.001200 YES
Energy change 0.000000 0.000001 YES
I have never encountered this problem before and not sure how to overcome this issue. I have tried increasing the tolerances (gradient up to 350 and displacement up to 1800) but it does not work.
