Correlation consistent basis sets and effective core potentials should be included?
I’d like to note that aug-cc-pV(n+d)Z (which are necessary for proper basis-set convergence for second-row main group elements) don’t appear to be listed in the Q-Chem library or manual. Also, I’ve noticed that the ECPs associated with aug-cc-pVnZ-PP and aug-cc-pwCVnZ-PP for the heavier elements are not listed by default. While it’s only slightly a bit more of a hassle to pull these from basis set exchange, it would be very nice if these were included by default considering how widely used they are…GAMESS (for example) doesn’t even let you use the old aug-cc-pVnZ basis sets for the second row atoms due to their erroneous convergence properties
The cc-pV(n+d)Z basis sets was addressed here,
They aren’t available by keyword but can certainly be included with BASIS=GEN (using a $basis input section). The same goes for ECPs - you can get the relevant info for a $ecp section from the Basis Set Exchange, in Q-Chem format, then use ECP = GEN. Q-Chem’s general philosophy is not to turn off method and basis-set combinations.
