I am receiving this error message:
terminate called after throwing an instance of ‘std::runtime_error’
what(): cuMemAlloc : CUDA error: CUDA_ERROR_OUT_OF_MEMORY
/work/qchem6p1p1/bin/qchem: line 129: 3424860 Aborted (core dumped) ${QCPROG_S} ${inp} ${scr}
Error in Q-Chem run part 1
Command line is:
qchem -gpu -nt 60 baseline_11240_HF_Notrunc_qc_job_DFT.inp baseline_11240_HF_Notrunc_qc_job_DFT.out baseline_11240_HF_Notrunc_qc_job_DFT
This calculation works fine for regular HF.
What is the memory limit in Q-Chem for the GPUs? Isn’t 24 Gbytes per GPU sufficient?
Pertinent info:
Q-Chem version 6.1.0. Linux RedHat 8.6 cuda 11.8 Four NVIDIA GeForce RTX 3090 GPUs each having 24576 MiB of RAM
There are 1046 atoms and 7436 external point charges.
The input file looks like this (abbreviated for sanity):
BASELINE md1 11240-bin0 all Na and DNA DFT
H 7.1776000000000044 16.2891640000000031 18.0170574499999994
O 7.7101413000000054 16.5243172000000058 17.2537059499999970
C 8.7841912000000075 15.6469254000000042 17.2647457499999959
H 9.3712455000000023 15.6766647000000034 18.1826686499999965
H 9.4123488000000020 15.8436340000000015 16.3959331499999976
C 8.2067262000000056 14.2460273999999991 17.0260829499999957
Na 3.3425744000000002 16.3165315000000071 27.5854167499999932
Na -8.8795172999999927 14.2412972000000018 7.9384593499999960
Na -4.2830044999999934 -2.6798703999999978 -7.7863656500000014
Na -1.3536274999999929 21.3721456000000067 -25.0405722500000074
$external_charges
-35.0406969 -10.6890833 -7.89040995 0.447585
-34.5123626 -19.7969214 -12.92697885 0.447585
-34.3356882 -14.6226479 -7.30517725 -0.89517
-34.3003434 -13.9265665 -15.38567975 -0.89517
-34.2419116 -17.6615407 -6.98659905 0.447585
38.050571 -1.8716919 -21.53536495 0.447585
38.0834691 16.9182408 5.56798585 0.447585
38.2569417 0.0537589 -24.93606715 0.447585
METHOD wB97M-V
SYMMETRY false
BASIS def2-SVP
MEM_STATIC 10000
GUI 2
MAX_SCF_CYCLES 100
Output looks like (also abbreviated for sanity):
Running Job 1 of 1 baseline_11240_HF_Notrunc_qc_job_DFT.inp
qchem baseline_11240_HF_Notrunc_qc_job_DFT.inp_3424847.0 /work/qcscratch/baseline_11240_HF_Notrunc_qc_job_DFT_2/ 1
/work/qchem6p1p1/exe/qcprog.exe_s baseline_11240_HF_Notrunc_qc_job_DFT.inp_3424847.0 /work/qcscratch/baseline_11240_HF_Notrunc_qc_job_DFT_2/
tid: 0x0 [2024.04.20-12:06:58.831] [INFO] Detected device: CUDA NVIDIA GeForce RTX 3090#0000:25:00.0
tid: 0x0 [2024.04.20-12:06:58.831] [INFO] Detected device: CUDA NVIDIA GeForce RTX 3090#0000:41:00.0
tid: 0x0 [2024.04.20-12:06:58.831] [INFO] Detected device: CUDA NVIDIA GeForce RTX 3090#0000:81:00.0
tid: 0x0 [2024.04.20-12:06:58.831] [INFO] Detected device: CUDA NVIDIA GeForce RTX 3090#0000:E1:00.0
tid: 0x0 [2024.04.20-12:06:58.833] [INFO] Allocating 3 threads for GPU: CUDA NVIDIA GeForce RTX 3090#0000:25:00.0 on node 0
tid: 0x0 [2024.04.20-12:06:58.834] [INFO] Allocating 3 threads for GPU: CUDA NVIDIA GeForce RTX 3090#0000:41:00.0 on node 0
tid: 0x0 [2024.04.20-12:06:58.836] [INFO] Allocating 3 threads for GPU: CUDA NVIDIA GeForce RTX 3090#0000:81:00.0 on node 0
tid: 0x0 [2024.04.20-12:06:58.838] [INFO] Allocating 3 threads for GPU: CUDA NVIDIA GeForce RTX 3090#0000:E1:00.0 on node 0
tid: 0x0 [2024.04.20-12:07:11.534] [INFO] Used GPU count: 4
tid: 0x0 [2024.04.20-12:07:12.454] [INFO] End BrianQC module initialization
tid: 0x0 [2024.04.20-12:07:12.457] [INFO] End brianAPIInit
tid: 0x0 [2024.04.20-12:07:12.457] [INFO] Running preliminary BrianQC license check...
tid: 0x0 [2024.04.20-12:07:12.458] [INFO] Preliminary BrianQC license check passed
Nuclear Repulsion Energy = 501801.73993400 hartrees
There are 2680 alpha and 2680 beta electrons
Requested basis set is def2-SVP
There are 5268 shells and 11500 basis functions
Q-Chem warning in module libmdc/get_mega.C, line 167:
Allowed MEM_STATIC has been capped at MEM_STATIC=8191.
Reduce the value of MEM_STATIC to silence this warning.
Total QAlloc Memory Limit 1000000 MB
Mega-Array Size 8007 MB
MEM_STATIC part 8191 MB
A cutoff of 1.0D-09 yielded 626466 shell pairs
There are 2558682 function pairs ( 2787687 Cartesian)
Smallest overlap matrix eigenvalue = 3.05E-04
Scale SEOQF with 1.000000e-03/1.000000e-03/1.000000e-03
Nucleus-field energy = -0.0000005877 hartrees
Adding 7436 external point charges to one-electron Hamiltonian
Nucleus-charge energy = 1045.4415667537 hartrees
Charge-charge energy = -909.4589444089 hartrees
SAD guess density has 5360.000004 electrons
Bang C. Huynh
Exchange: 0.1500 Hartree-Fock + 1.0000 wB97M-V + LR-HF
Correlation: 1.0000 wB97M-V
Nonlocal Correlation: VV10 with C = 0.0100 and b = 6.00 and scale = 1.00000
Grid used for NLC: SG-1 standard quadrature
using 60 threads for integral computing
---- BrianQC J/K successfully initialized ----
---- BrianQC K successfully initialized ----
---- BrianQC XC successfully initialized ----
Brianqc Computing J only
BrianQC JK build time 824.0000000000 (s)
Brianqc Computing K only
BrianQC JK build time 821.0000000000 (s)
That’s the end of the output file.
