CVS_IP_ALPHA/BETA keyword seems missing
QChem 5.4. Manual mentions the possibility of selectively exciting alpha electrons (as opposed to beta, excited by CVS_IP_STATES by default). However, after trying to specify CVS_IP_ALPHA 1, I get the following error
Problem with processed rem input line:
CVS_IP_ALPHA 1
CVS_IP_ALPHA (rem variable) is not correct.
Please make sure the variable is legal and the spelling is correct.
Q-Chem fatal error occurred in module qparser/new_read_rem.C, line 431:
Illegal rem input in read_rem
Was the keyword removed or renamed? Or am I doing something wrong? Thanks in advance.
P.S. Running qchem 5.4.0
That $rem variable is accepted now (pre-release version of Q-Chem 6). Can you try CVS_EOM_IP_ALPHA instead? In the latest code, those are aliased to the same thing and that alas was added in June 2021, in between 5.4.0 and 5.4.1 releases.
It works indeed. Thank you!
Great. It looks like those two keywords are synonymous in versions later than 5.4.0.
