DFT analytic frequency calculation with CPCM fails
I was running a harmonic frequency calculation using B3LYP-D3(BJ) with C-PCM. The CPSCF steps failed to complete with the error message as follows:
Calculating MO derivatives via CPSCF
CPSCF will be done in 2 segments to save memory.
Computing fast CPCM-SWIG hessian.
1 0 96 0.247260 0.005973
2 0 96 0.054413 0.001108
3 0 96 0.004706 0.000139
4 0 96 0.000774 0.000030
5 4 92 0.000115 0.000007
6 130 62 0.000016 0.000001 Collapsing Subspace
7 47 49 0.000011 0.000001
Warning: Singularity detected in AXeqB0 159 8 1
0.000000000000000E+000 207
Q-Chem fatal error occurred in module 0, line 118:
Unable to find relaxed density
The full input file is pasted below. I would like to know if there is a way around without going back to use finite-difference frequency. Thank you!
C   -2.7128894   -2.0096250    0.1997942
N   -1.8326014   -1.2847421   -0.5198038
C   -2.2658495   -0.6198602   -1.6106825
C   -3.5930199   -0.6542627   -2.0076481
C   -4.5285698   -1.3965554   -1.2727000
C   -4.0531550   -2.0840696   -0.1475304
Ru    0.2125423   -1.2826929    0.0413841
O   -0.2546832   -1.8152159    2.0524099
C   -0.7325794   -0.9873458    2.9385125
O   -1.0771371   -1.3126230    4.0711164
C    2.7932584   -0.1531389    1.2284850
C    4.1389037   -0.0948176    1.5602213
C    4.9882527   -1.1625689    1.2432210
C    4.4099472   -2.2630203    0.5935287
C    3.0609976   -2.2576197    0.2800820
O    0.2431934   -3.0122799    0.0528536
N   -0.3421476    0.5209780    1.1898694
C   -0.2742794    1.7423772    0.6170251
C   -0.6899501    2.9210807    1.2715084
C   -1.2073593    2.7793353    2.5796392
C   -1.2522503    1.5230938    3.1614186
C   -0.8027629    0.4121263    2.4322493
C   -0.5353466    4.1659157    0.5701906
C    0.0256871    4.2127623   -0.6771240
C    0.4726377    3.0172984   -1.3396028
C    0.2942060    1.7876710   -0.6735824
N    0.6582459    0.5916872   -1.1975669
C    1.2255412    0.5909604   -2.3966392
C    1.4714980    1.7528982   -3.1400382
C    1.0864316    2.9742222   -2.6115273
H    1.2495233    3.8923166   -3.1667487
H    1.9384309    1.6755412   -4.1151148
H   -1.5480442    3.6541643    3.1239876
H   -1.6181167    1.3703472    4.1698806
H   -2.3196293   -2.5433621    1.0553631
H   -4.7190109   -2.6900969    0.4576504
H   -1.5346822   -0.0635836   -2.1799719
H    2.5960077   -3.0903944   -0.2306766
H    5.0066435   -3.1278593    0.3226901
H    4.5155910    0.7863056    2.0682763
H    2.1311845    0.6645750    1.4784759
H    0.1482282    5.1604216   -1.1912166
H   -0.8639562    5.0760535    1.0609742
O    0.6492385   -1.8357159   -2.0631837
S    1.6097216   -1.0576295   -2.9853974
O    3.0283718   -1.3210227   -2.6976077
O    1.1797638   -1.1672072   -4.3877620
H   -3.8887642   -0.1074001   -2.8966287
C   -5.9760001   -1.4371516   -1.6677905
H   -6.4625356   -2.3414933   -1.2947379
H   -6.4989955   -0.5726321   -1.2403330
H   -6.0870322   -1.3860502   -2.7541102
C    6.4530387   -1.1335853    1.5713488
H    6.7413666   -2.0334224    2.1244306
H    7.0431916   -1.1180828    0.6478497
H    6.7111893   -0.2532886    2.1637391
N    2.2613660   -1.2155924    0.5926953
H   -2.0563182   -3.2462617   -3.2742947
O   -1.2552457   -3.7294465   -3.0261125
H   -0.6067303   -3.0451068   -2.7730937
H   -1.4963894   -4.7563675   -1.5393864
O   -1.5830728   -5.3028786   -0.7282977
H   -1.1023358   -4.8022463   -0.0539832
JOBTYPE FREQ
METHOD B3LYP
DFT_D D3_BJ
SCF_CONVERGENCE 8
UNRESTRICTED TRUE
BASIS GENERAL
ECP GENERAL
SYM_IGNORE  FALSE
PURECART 1
ECP_FIT TRUE
MAX_SCF_CYCLES 10000
SOLVENT_METHOD PCM
MEM_TOTAL 64000
MEM_STATIC 8000
THEORY  CPCM
DIELECTRIC  78.39
$van_der_waals
1
44  2.02
H     0
S   3   1.00
0.1873113696D+02       0.3349460434D-01
0.2825394365D+01       0.2347269535D+00
0.6401216923D+00       0.8137573261D+00
S   1   1.00
0.1612777588D+00       1.0000000
P   1   1.00
0.1100000000D+01       1.0000000
C     0
S   6   1.00
0.3047524880D+04       0.1834737132D-02
0.4573695180D+03       0.1403732281D-01
0.1039486850D+03       0.6884262226D-01
0.2921015530D+02       0.2321844432D+00
0.9286662960D+01       0.4679413484D+00
0.3163926960D+01       0.3623119853D+00
SP   3   1.00
0.7868272350D+01      -0.1193324198D+00       0.6899906659D-01
0.1881288540D+01      -0.1608541517D+00       0.3164239610D+00
0.5442492580D+00       0.1143456438D+01       0.7443082909D+00
SP   1   1.00
0.1687144782D+00       0.1000000000D+01       0.1000000000D+01
SP   1   1.00
0.4380000000D-01       0.1000000000D+01       0.1000000000D+01
D   1   1.00
0.8000000000D+00       1.0000000
N     0
S   6   1.00
0.4173511460D+04       0.1834772160D-02
0.6274579110D+03       0.1399462700D-01
0.1429020930D+03       0.6858655181D-01
0.4023432930D+02       0.2322408730D+00
0.1282021290D+02       0.4690699481D+00
0.4390437010D+01       0.3604551991D+00
SP   3   1.00
0.1162636186D+02      -0.1149611817D+00       0.6757974388D-01
0.2716279807D+01      -0.1691174786D+00       0.3239072959D+00
0.7722183966D+00       0.1145851947D+01       0.7408951398D+00
SP   1   1.00
0.2120314975D+00       0.1000000000D+01       0.1000000000D+01
SP   1   1.00
0.6390000000D-01       0.1000000000D+01       0.1000000000D+01
D   1   1.00
O     0
S   6   1.00
0.5484671660D+04       0.1831074430D-02
0.8252349460D+03       0.1395017220D-01
0.1880469580D+03       0.6844507810D-01
0.5296450000D+02       0.2327143360D+00
0.1689757040D+02       0.4701928980D+00
0.5799635340D+01       0.3585208530D+00
SP   3   1.00
0.1553961625D+02      -0.1107775495D+00       0.7087426823D-01
0.3599933586D+01      -0.1480262627D+00       0.3397528391D+00
0.1013761750D+01       0.1130767015D+01       0.7271585773D+00
SP   1   1.00
0.2700058226D+00       0.1000000000D+01       0.1000000000D+01
SP   1   1.00
0.8450000000D-01       0.1000000000D+01       0.1000000000D+01
D   1   1.00
S     0
S   6   1.00
0.2191710000D+05       0.1869240849D-02
0.3301490000D+04       0.1423030646D-01
0.7541460000D+03       0.6969623166D-01
0.2127110000D+03       0.2384871083D+00
0.6798960000D+02       0.4833072195D+00
0.2305150000D+02       0.3380741536D+00
SP   6   1.00
0.4237350000D+03      -0.2376770499D-02       0.4061009982D-02
0.1007100000D+03      -0.3169300665D-01       0.3068129986D-01
0.3215990000D+02      -0.1133170238D+00       0.1304519994D+00
0.1180790000D+02       0.5609001177D-01       0.3272049985D+00
0.4631100000D+01       0.5922551243D+00       0.4528509980D+00
0.1870250000D+01       0.4550060955D+00       0.2560419989D+00
SP   3   1.00
0.2615840000D+01      -0.2503731142D+00      -0.1451048955D-01
0.9221670000D+00       0.6695676310D-01       0.3102627765D+00
0.3412870000D+00       0.1054506269D+01       0.7544824565D+00
SP   1   1.00
0.1171670000D+00       0.1000000000D+01       0.1000000000D+01
SP   1   1.00
0.4050000000D-01       0.1000000000D+01       0.1000000000D+01
D   1   1.00
0.6500000000D+00       1.0000000
Ru 0
S   3   1.00
2.5650000             -1.0431056
1.5080000              1.3314786
0.5129000              0.5613065
S   4   1.00
2.5650000              0.8770128
1.5080000             -1.2634660
0.5129000             -0.8384987
0.1362000              1.0637773
S   1   1.00
0.0417000              1.0000000
P   3   1.00
4.8590000             -0.0945755
1.2190000              0.7434798
0.4413000              0.3668144
P   2   1.00
0.5725000             -0.0880864
0.0830000              1.0283970
P   1   1.00
0.0250000              1.0000000
D   3   1.00
4.1950000              0.0485729
1.3770000              0.5105223
0.4828000              0.5730028
D   1   1.00
0.1501000              1.0000000
$ecp
RU     0
RU-ECP     3     28
f potential
5
0    554.3796303             -0.0515270
1    155.1066871            -20.1816536
2     48.4976263           -105.9966915
2     14.7701594            -42.2166788
2      5.2077363             -3.7675024
s-f potential
5
0     66.7118060              2.9578344
1     77.3503632             25.3748707
2     18.3571445            536.1262372
2     11.8404727           -651.2057221
2      8.1179479            381.3816943
p-f potential
5
0     54.9937915              4.9651557
1     13.9399212             23.8861501
2     15.2118246            464.4631344
2     10.5460691           -714.4451788
2      7.5539486            377.5503594
d-f potential
4
0     60.3444595              3.0352988
1     45.2100305             23.2901723
2     19.1190074            146.0926620
2      4.2712090             28.9129770
I noticed that if we turn off PCM, the gas-phase frequency calculation runs, and the calculation only had one segment rather than 2 (not sure why such a discrepancy would exist).
I then ran the original job with rem keyword CPSCF_NSEG = 1. That calculation was also able to finish.
After adding this keyword, my calculations were able to finish. Thank you very much!
Great. We are looking into the origins of this problem.
