For a linear triatomic of the type O-X-O in this calculation:
Eu
O 1 rXO1
O 1 rXO2 2 aOXO
rXO1 = 1.6615601209
rXO2 = 1.6615601209
aOXO = 180.0000000000
JOBTYPE FREQ
METHOD wB97M-V
BASIS def2-SVP
SYMMETRY TRUE
SYM_IGNORE FALSE
GEN_SCFMAN TRUE
SCF_ALGORITHM GDM
SCF_CONVERGENCE 9
MAX_SCF_CYCLES 400
MEM_TOTAL 8000
MEM_STATIC 250
INTERNAL_STABILITY TRUE
INTERNAL_STABILITY_ITER 250
VIBMAN_PRINT 6
THRESH 14
MOLDEN_FORMAT TRUE
I’m getting bend frequencies different by about 15 cm-1. There’s no spatial symmetry-breaking I can perceive when I look at the orbitals and symmetry is not the culprit here (calc. without symmetry gives the same result). Do you have any ideas as to why the bend frequencies (which ought to be degenerate, right?) are different?
** VIBRATIONAL ANALYSIS **
** VIBRATIONAL FREQUENCIES (CM**-1) AND NORMAL MODES **
** FORCE CONSTANTS (mDYN/ANGSTROM) AND REDUCED MASSES (AMU) **
** INFRARED INTENSITIES (KM/MOL) **
Mode: 1 2 3
Frequency: 353.69 367.63 883.94
Force Cnst: 1.3950 1.5071 7.3634
Red. Mass: 18.9268 18.9268 15.9949
IR Active: YES YES YES
IR Intens: 33.201 33.177 0.000
Raman Active: YES YES YES
X Y Z X Y Z X Y Z
Eu -0.103 -0.103 -0.001 -0.103 0.103 0.000 -0.000 -0.000 -0.000
O 0.495 0.495 0.007 0.495 -0.495 0.000 0.000 0.000 0.707
O 0.495 0.495 0.007 0.495 -0.495 -0.000 0.000 0.000 -0.707
TransDip -0.130 -0.130 -0.006 -0.130 0.130 -0.000 -0.000 -0.000 -0.000
Mode: 4
Frequency: 1079.15
Force Cnst: 12.9865
Red. Mass: 18.9268
IR Active: YES
IR Intens: 203.838
Raman Active: YES
X Y Z X Y Z X Y Z
Eu 0.001 0.001 -0.146
O -0.005 -0.005 0.699
TransDip 0.001 0.001 -0.457
