Hi
I want to optimize the Dimer system containing 72 atoms (per molecule 36 atoms). I put the job with the mentioned keywords. It already took 120 optimization cycles, and it is going on.
XYZ coordinates
This does not strike me as an egregiously large number, it depends on how good your guess geometry is. A couple of points to note:
(1) OpticalDielectric does not affect ground-state calculations (is ignored).
(2) There is not little justification to use Dunning basis sets for DFT, esp. for a functional such wB97X-D. I would suggest 6-31G* or def2-SV(P) for geometry optimizations.
(3) Diffuse basis functions can be extremely important for non-covalent interactions; see https://doi.org/10.1021/acs.jctc.2c00883
You may also want to try setting
$geom_opt
initial_hessian model
which should probably be the default setting in future versions.
