Does BrianQC support CDFT-CI / legacy SCF engine in Q-Chem7?
Hey guys,
Does BrianQC support GPU acceleration for CDFT-CI calculations?
The Q-Chem 7.0 manual says in Section 4.3.1:
It should be noted that many special features (e.g. dual-basis SCF, CDFT, etc.) based on Q-Chem’s old SCF code are not yet supported in GEN_SCFMAN.
However, I couldn’t find a clear statement on whether BrianQC supports both the old and new SCF engines, or only GEN_SCFMAN. The release note mentioning BrianQC and GEN_SCFMAN = FALSE is also a bit unclear to me.
Has anyone tried running CDFT-CI with BrianQC, or could clarify whether this is supported?
Thanks!
I do not know for sure. However, that statement in the manual strongly suggests that the old SCF code is not supported by BrianQC. The $rem variable GEN_SCFMAN controls whether the old (=FALSE) or new (=TRUE) code is used. For the new code, you should see this title block:
  Bang C. Huynh
that does not appear for the old SCF code. In this way, you can decipher which features still use the old code.
