I am writing to update an discrepancy I came across when calculating energies for an ionic liquid-based dianion system. The QM region was modeled using wb97x-D/def2-SVPD, while 25 pairs of ionic liquid ions were modeled using the EFP approach. EFP parameters were computed as recommended in the Q-Chem and GAMESS manuals.
I observed unphysical polarization energy values in my system, which resulted in improper SCF convergence and incorrect molecular orbital eigenvalues. Despite trying several different approaches, including changing basis sets, altering initial guesses, and modifying the creation of EFP parameters, the underlying problem persisted.
The issue was traced back to the use of Gaussian-type polarization damping. According to literature, it is advisable to reduce the damping parameters (α and β) from the standard 0.6 for systems with ionic nature. However, in Q-Chem, these parameters are hardcoded.
To address this, I turned off the polarization damping. This led to quicker SCF convergence and correct molecular orbital calculations. The effect of damping was compared across different numbers of EFP pairs (1, 5, 10, and 25), showing that the impact of damping increases drastically with the number of EFP pairs.
Below is a comparison of the polarization energy with and without damping for 25 pairs of ionic liquid ions.
with EFP_POL_DAMP true
Compute EFP polarization integrals
44 -22872.5430533622 1.38E-06 Convergence criterion met
SCF time: CPU 640396.65 s wall 76330.02 s
EFP ENERGY COMPONENTS (ATOMIC UNITS)
ELECTROSTATIC ENERGY -4.1780488440
POLARIZATION ENERGY 52804.0805454944
DISPERSION ENERGY -0.7397106719
EXCHANGE-REPULSION ENERGY 9.0921589672
OVERLAP-BASED CHARGE PENETRATION -1.8540906348
QM-NUC/EFP ELECTROSTATIC ENERGY -57.2059254920
QM/EFP DISPERSION ENERGY 0.0000000000
QM/EFP EXCHANGE-REPULSION ENERGY 0.0000000000
TOTAL EFP ENERGY 52749.1949288189
EFP CORRECTION TO SCF ENERGY -54.8856166756
SCF energy = -22872.54305336
Total energy = -22872.54305336
Orbital Energies (a.u.)
Alpha MOs
-- Occupied --
-673.83778 -545.17285 -469.79332 -397.40559 -354.75212 -333.93041
-318.93038 -306.57508 -298.05127 -279.46761 -270.53063 -263.54706
-259.24247 -255.45852 -249.18515 -242.20049 -238.18967 -229.70989
-227.23305 -221.39125 -219.97045 -213.47327 -212.23343 -209.91795
-206.95313 -205.58516 -203.44355 -202.67708 -200.49162 -199.10233
-197.14041 -195.90925 -194.65548 -192.30848 -192.16222 -188.02439
-187.32685 -186.99037 -185.58730 -182.60919 -180.24186 -179.55960
-177.04247 -175.89665 -174.94050 -172.76140 -170.94657 -169.45529
-167.74927 -166.23647 -165.96357 -164.01991 -162.15817 -161.58569
-160.17025 -159.67263 -158.91274 -157.52205 -157.00040 -155.76835
-155.61514 -154.21065 -154.04698 -152.57195 -151.48568 -150.14844
-149.95352 -148.70560 -147.78328 -147.49485 -146.99516 -146.61645
-145.61395 -144.78558 -143.50388 -143.02028 -142.37614 -141.67867
-140.48427 -140.15604 -139.29513 -138.83377 -138.57593 -137.38393
-136.55325 -136.27050 -135.12164 -134.83167 -133.53131 -133.12865
-132.67962 -132.54281 -132.01357 -131.40612 -130.85856 -129.88070
-129.39048 -128.41683 -128.14975 -127.42676 -127.24884 -126.30083
-125.39247 -125.00921 -123.95623 -123.33874 -123.17791 -122.77375
-122.45697 -121.95809 -121.95030 -120.83411 -120.70580 -120.42082
-119.82009 -119.35116 -119.17663 -118.63768 -118.44757 -117.60057
-117.29418 -117.16854 -116.63224 -116.17088 -116.07994 -115.89663
-115.45975 -114.82612 -114.59704 -114.19701 -113.69750 -113.38761
-113.28695 -112.83132 -112.65047 -112.34064 -111.86567 -111.55104
-111.05577 -110.96100 -110.48779 -109.96099 -109.63875 -109.11249
-108.94568 -108.50007 -108.43995 -107.76076 -107.53973 -107.19465
-106.58253 -105.94816 -105.64261 -105.53019 -105.19811 -104.85686
-104.58387 -104.32349 -103.82586 -103.61029 -103.48507 -103.27297
-103.12601 -102.78488 -102.40562 -101.85456 -101.69389 -101.19445
-101.10477 -101.02269 -100.70027 -100.63426 -100.42966 -100.01755
-99.75056 -99.40956 -99.12198 -98.95411 -98.70935 -98.57370
-98.19326 -97.98472 -97.77851 -97.66823 -97.40885 -97.07757
-96.90553 -96.57003 -96.32634 -96.21865 -96.11135 -95.94020
-95.66347 -95.36258 -94.97658 -94.91968 -94.14062 -93.98190
-93.69079 -93.56516 -93.43392 -93.26344 -93.16269 -93.07014
-92.98614 -92.78358 -92.52152 -92.47047 -92.39809
-- Virtual --
-92.17736 -92.07575 -91.88818 -91.35308 -91.17899 -91.17838
-91.00501 -90.92010 -90.64829 -90.33121 -90.31128 -90.20623
-90.09498 -89.75840 -89.72369 -89.70264 -89.50781 -89.46771
-89.21257 -89.10360 -88.90889 -88.88470 -88.72915 -88.57438
-88.47252 -88.29749 -88.28996 -88.18746 -88.11980 -87.91107
-87.75398 -87.60417 -87.41595 -87.35709 -87.01720 -86.94570
-86.86775 -86.79036 -86.60535 -86.46818 -86.39568 -86.14400
-86.06432 -85.97692 -85.87750 -85.58652 -85.34557 -85.16861
-85.13157 -84.89086 -84.85803 -84.80168 -84.64142 -84.41147
-84.21896 -84.19195 -84.09043 -84.01808 -83.68264 -83.53038
with EFP_POL_DAMP false
16 -3282.4883518808 9.15E-06 Convergence criterion met
SCF time: CPU 161699.89 s wall 19962.06 s
POLARIZATION ENERGY 13.0624874439
EXCHANGE-REPULSION ENERGY 9.0795985206
OVERLAP-BASED CHARGE PENETRATION -1.8506834187
TOTAL EFP ENERGY -41.8322824621
EFP CORRECTION TO SCF ENERGY -54.8947699061
SCF energy = -3282.48835188
Total energy = -3282.48835188
Alpha MOs
-- Occupied --
-89.1462 -89.0424 -19.2204 -19.1816 -19.1470 -19.1432 -19.1396 -19.1381
-19.1292 -19.0692 -19.0421 -19.0321 -14.4608 -14.4515 -10.3052 -10.2916
-10.2892 -10.2839 -10.2819 -10.2787 -10.2762 -10.2726 -10.2703 -10.2617
-10.2584 -10.2533 -10.2493 -10.2415 -10.2397 -10.2370 -10.2316 -10.2308
-10.2302 -10.2265 -10.2265 -10.2257 -10.2242 -10.2240 -10.2219 -10.2131
-10.2108 -10.1980 -10.1948 -10.1851 -10.1849 -10.1716 -10.1697 -10.1610
-10.1556 -10.1556 -10.1526 -10.1494 -10.1439 -10.1308 -10.1284 -10.1187
-8.1617 -8.0565 -6.1172 -6.1165 -6.1143 -6.0122 -6.0108 -6.0100
-1.8436 -1.1399 -1.0537 -1.0524 -1.0432 -1.0339 -1.0291 -1.0051
-1.0033 -0.9871 -0.9859 -0.8964 -0.8839 -0.8749 -0.8689 -0.8649
-0.8562 -0.8424 -0.8360 -0.8064 -0.7928 -0.7902 -0.7750 -0.7682
-0.7580 -0.7463 -0.7425 -0.7397 -0.7172 -0.7154 -0.7066 -0.6899
-0.6846 -0.6804 -0.6770 -0.6625 -0.6499 -0.6401 -0.6277 -0.6159
-0.6112 -0.6066 -0.5934 -0.5876 -0.5767 -0.5681 -0.5654 -0.5524
-0.5484 -0.5431 -0.5354 -0.5312 -0.5194 -0.5180 -0.5069 -0.4991
-0.4929 -0.4891 -0.4851 -0.4828 -0.4809 -0.4735 -0.4728 -0.4692
-0.4678 -0.4671 -0.4625 -0.4612 -0.4566 -0.4532 -0.4471 -0.4427
-0.4364 -0.4285 -0.4275 -0.4248 -0.4226 -0.4210 -0.4174 -0.4083
-0.4072 -0.4015 -0.3993 -0.3960 -0.3904 -0.3902 -0.3855 -0.3847
-0.3835 -0.3813 -0.3752 -0.3725 -0.3696 -0.3687 -0.3656 -0.3633
-0.3619 -0.3601 -0.3597 -0.3569 -0.3528 -0.3506 -0.3491 -0.3457
-0.3399 -0.3341 -0.3315 -0.3301 -0.3270 -0.3233 -0.3210 -0.3169
-0.3111 -0.3098 -0.3082 -0.3027 -0.2983 -0.2918 -0.2906 -0.2854
-0.2738 -0.2715 -0.2676 -0.2654 -0.2629 -0.2572 -0.2541 -0.2508
-0.2491 -0.2474 -0.2416 -0.2408 -0.2344 -0.2319 -0.2223 -0.2130
-0.2085 -0.2064 -0.1986 -0.1811 -0.1778 -0.1669 -0.1634 -0.1368
-0.1182
-- Virtual --
-0.0500 -0.0058 0.0368 0.0585 0.0761 0.0885 0.1027 0.1110
0.1222 0.1356 0.1479 0.1547 0.1594 0.1650 0.1696 0.1767
0.1776 0.1794 0.1858 0.1923 0.2065 0.2102 0.2113 0.2219
0.2235 0.2266 0.2273 0.2361 0.2366 0.2397 0.2440 0.2457
0.2476 0.2482 0.2553 0.2563 0.2581 0.2609 0.2681 0.2714
0.2725 0.2765 0.2768 0.2798 0.2836 0.2851 0.2899 0.2913
0.2923 0.2935 0.2948 0.2975 0.2999 0.3004 0.3044 0.3072
0.3093 0.3122 0.3144 0.3162 0.3185 0.3204 0.3216 0.3229
0.3268 0.3276 0.3284 0.3295 0.3301 0.3315 0.3357 0.3375
0.3382 0.3403 0.3440 0.3464 0.3500 0.3511 0.3521 0.3546
0.3555 0.3567 0.3589 0.3593 0.3623 0.3635 0.3646 0.3674
