ELF Keyword EXCHANGE is uninitialized in rem vector
I have a problem qchem/6.0.1-smp
How resolve?
Q-Chem fatal error occurred in module libgen/rem_utils.C, line 52:
   O    -4.5320698567   0.2524215916      0.0130780103
   H    -3.5641829319   0.2173288989     -0.0173259969
   H    -4.8109190521  -0.4489616171     -0.5945943692
   JOBTYPE           opt
   METHOD            b3lyp
   BASIS             6-31g*
   PLOT_ELF          true
   MAKE_CUBE_FILES   true
$plots
water
50 -7 7
50 -4 4
50 -4 4
0 1 0 0
0
Try EXCHANGE = B3LYP instead of METHOD = B3LYP. The former is an older notation for hybrid functionals, I’m surprised it’s showing up here.
i changed
   JOBTYPE           opt
   METHOD            b3lyp
   BASIS             6-31g*
   PLOT_ELF          true
   geom_opt_driver optimize
$plots
water
50 -7 7
50 -4 4
50 -4 4
0 1 0 0
0
and worked geom_opt_driver optimize why?
That’s the old geometry optimizer, which is no longer the default. Not sure why you are having these problems, if you can’t figure it out then please contact Q-Chem support.
Thank you.
how can i visualize elf from qchem?
You can open the CUBE file (elf_alpha.0.cube) that you generate with the above output in IQmol, which is very well integrated with Q-Chem, for visualization. For more information, please refer to the IQmol User Guide (http://iqmol.org/downloads/IQmolUserGuide.pdf).
