I tried to calculate FSM, but i ended up an error
Q-Chem fatal error occurred in module 0, line 59:
** crntIShl .ne. lastIShl.**
I’m unaware of this kind of error. Could you please give some suggestions on how to sort it out?
Thanks in advance!
Thanks in advance!
Please supply a complete input file that exhibits this issue, preferably as small of a molecule and as few input options as possible.
This is my input
C -0.9205131173653825 -3.2540241249284008 -0.1715246081068169
C -0.7467317598927196 -1.8880327951932419 -0.0339320975085207
C -1.8859809329520270 -0.9824387843783272 0.2005237368903191
C -1.9382051629514481 -3.0117718224180630 0.1428897892687866
C -1.4169303185542068 -1.7087061319775527 0.0275783545844644
C -2.2591720640790753 -0.5349569894849315 0.0453769128720703
jobtype fsm
METHOD wB97X-D
BASIS 6-31+G(d,p)
FSM_NGRAD 3
FSM_NNODE 20
FSM_MODE 2
FSM_OPT_MODE 2
SYMMETRY FALSE
SYM_IGNORE TRUE
THRESH 12
What version of Q-Chem are you using? Can you please also attach the end of your output? With Q-Chem 6.2, this job crashes after 200 iterations with the following:
STARTING FREEZING STRING ITERATION # 200
The distance between the innermost nodes (Angstroms): 0.452
-Adding two new nodes
