Error in RI-EA-CC2 calculation
I am running a RI-EA-CC2 but qchem throws an error when calculating the transition energies. Here is the input file:
aug-cc-pVTZ+3s3p3d
$aux_basis
aug-cc-pVTZ-RIFIT
MEM_STATIC = 1000
MEM_TOTAL = 64000
BASIS = GEN
AUX_BASIS = GEN
SCF_GUESS_ALWAYS = TRUE
SCF_ALGORITHM = DIIS
MAX_SCF_CYCLES = 100
IQMOL_FCHK = FALSE
JOB_TYPE = SP
METHOD = CC2
EA_STATES = [6,6,6,6]
POINT_GROUP_SYMMETRY = TRUE
SYM_TOL = 5
EOM_SINGLE_PREC = 1
CC_SINGLE_PREC = 1
Then, when qchem gets to the transition energies it prints:
 CC2  CPU 10994.83 s  wall 3157.90 s
        Solving for EOMEA-CC2/MP2 A1 transitions.
Running a single precision version
      RI-EOMEA-CC2/MP2 right amplitudes will be solved using Davidson.
        Amplitudes will be solved using standard  algorithm.
     Hard-coded thresholds:
     LinDepThresh=1.00e-15  NormThresh=1.00e-06  ReorthogonThresh=1.00e-02
      Roots     MaxVec    MaxIter   Precond   Conv      Shift
      6         120       60        1         1.00e-05  0.00e+00
 Q-Chem fatal error occurred in module /scratch/qcdevops/jenkins/workspace/build_qchem_lnxque_distrib/tags/qc631/qchem/ccman2/qchem/ccman2_main.C, line 26:
 std::bad_cast
What is causing this crash?
Please provide a complete input file with basis sets that can be run using standard Q-Chem.
I had found the issue. The EOM_SINGLE_PREC command is somehow incompatible with the CC2 method. Once I turned single precision off, the calculations ran fine. Devs should check this out.
please provide a complete input file and I will create a bug ticket.
I verified using my own sample that single precision RI-CC2 works for the ground state and crashes for EOM jobs. I will submit a ticket – it should be relatively easy to fix.
