Error in TD-DFT optimization using STATE_FOLLOW
Hello. I came across an error message while trying to optimize the second triplet excited state
of thioxanthon at the TD-CAM-B3LYP-D3/6-31G(d,p) level of theory. As the same instruction used
to work seamlessly in QC5.4, I am suspicious of a bug in the latest release of QC.
I am attaching my QC input for your reference.
C -3.387898679 -0.047938516 1.918901858
C -2.646082575 0.247490346 3.077426413
C -3.116324491 0.563145004 0.710807635
H -4.186923706 -0.780344092 1.970484532
C -1.618905412 1.164214412 2.992833879
H -2.876220104 -0.236852641 4.019050051
C -1.319373012 1.771779311 1.762711938
H -1.035277544 1.420458313 3.872087395
C -2.056202869 1.481463311 0.572375724
S 0.008402330 2.857489590 1.747035835
H -3.677559552 0.309211655 -0.179378544
C -1.759895583 2.051905098 -0.716415305
C 0.291157096 3.289813284 0.115753032
C -0.563473560 2.839517434 -0.929134896
C 1.448719326 4.036716093 -0.136041945
O -2.451980741 1.777038486 -1.657407703
C -0.181543921 3.192511680 -2.236347071
C 1.795303875 4.354569668 -1.436794348
H 2.072966374 4.354460043 0.693715268
C 0.966394388 3.924976581 -2.482164440
H 2.690990853 4.929481198 -1.641230612
H 1.233688008 4.161788798 -3.507486196
H -0.813031116 2.856714504 -3.048594455
BASIS 6-31G(d,p)
JOB_TYPE OPTIMIZATION
METHOD CAM-B3LYP
DFT_D D3_ZERO
SYMMETRY FALSE
mem_total 400000
mem_static 4000
max_SCF_CYCLES 150
MAX_CIS_CYCLES 150
SOLVENT_METHOD PCM
CIS_N_ROOTS 4
SET_STATE_DERIV 2
STATE_FOLLOW TRUE
RPA 0
CIS_SINGLETS FALSE
CIS_TRIPLETS TRUE
Theory CPCM
DIELECTRIC 37.5
Please attach the error message and tell us at what point you encountered it during the job. I believe that the default optimizer changed in the 6.0 release, and you can use the old (v.5.4) optimizer by specifying GEOM_OPT_DRIVER = OPTIMIZE in $rem.
Dear John,
I thank you for your suggestion. As you anticipated,
GEOM_OPT_DRIVE=OPTIMIZER suppresses the
unusual termination and allows the optimization progress.
Attached below please find the error message, while using
the QC6.0 default optimizer.
All the best,
Jiyong
Q-Chem 6.0.1 for Intel X86 EM64T Linux
Parts of Q-Chem use Armadillo 9.900.5 (Nocturnal Misbehaviour).
http://arma.sourceforge.net/
Q-Chem begins on Fri Apr 14 23:08:17 2023
Host:
0
 Scratch files written to /mnt/lustre/ibs/pjy/.tmp/qchem908764//
Aug2322 |scratch|qcdevops|jenkins|workspace|build_RNUM 6470
Processing $rem in /opt/ibs_lib/apps/qchem/6.0.1/config/preferences:
Processing $rem in /mnt/lustre/ibs/pjy/.qchemrc:
Symmetry turned off for PCM/SM12/SMD calculation
Checking the input file for inconsistencies… …done.
User input:
SCF_CONVERGENCE 8
BASIS 6-31G(d,p)
METHOD CAM-B3LYP
DFT_D D3_ZERO
SYMMETRY FALSE
mem_total 400000
mem_static 4000
max_SCF_CYCLES 150
MAX_CIS_CYCLES 150
SOLVENT_METHOD PCM
CIS_N_ROOTS 4
SET_STATE_DERIV 2
STATE_FOLLOW TRUE
RPA 0
CIS_SINGLETS FALSE
CIS_TRIPLETS TRUE
Theory CPCM
DIELECTRIC 37.5
Adding empirical dispersion correction
Doing -D3(0) with
s6 = 1.00000
s8 = 1.21700
rs6 = 1.37800
rs8 = 1.00000
-D3 energy without 3body term = -0.0136364624 hartrees
1      C      -3.3878986790    -0.0479385160     1.9189018580
2      C      -2.6460825750     0.2474903460     3.0774264130
3      C      -3.1163244910     0.5631450040     0.7108076350
4      H      -4.1869237060    -0.7803440920     1.9704845320
5      C      -1.6189054120     1.1642144120     2.9928338790
6      H      -2.8762201040    -0.2368526410     4.0190500510
7      C      -1.3193730120     1.7717793110     1.7627119380
8      H      -1.0352775440     1.4204583130     3.8720873950
9      C      -2.0562028690     1.4814633110     0.5723757240
10 S 0.0084023300 2.8574895900 1.7470358350
11 H -3.6775595520 0.3092116550 -0.1793785440
12 C -1.7598955830 2.0519050980 -0.7164153050
13 C 0.2911570960 3.2898132840 0.1157530320
14 C -0.5634735600 2.8395174340 -0.9291348960
15 C 1.4487193260 4.0367160930 -0.1360419450
16 O -2.4519807410 1.7770384860 -1.6574077030
17 C -0.1815439210 3.1925116800 -2.2363470710
18 C 1.7953038750 4.3545696680 -1.4367943480
19 H 2.0729663740 4.3544600430 0.6937152680
20 C 0.9663943880 3.9249765810 -2.4821644400
21 H 2.6909908530 4.9294811980 -1.6412306120
22 H 1.2336880080 4.1617887980 -3.5074861960
23 H -0.8130311160 2.8567145040 -3.0485944550
Nuclear Repulsion Energy = 1001.74869271 hartrees
There are 55 alpha and 55 beta electrons
Requested basis set is 6-31G(d,p)
There are 85 shells and 269 basis functions
Total QAlloc Memory Limit 400000 MB
Mega-Array Size 3911 MB
MEM_STATIC part 4000 MB
            STARTING GEOMETRY OPTIMIZER USING LIBOPT3
            by Peter F. McLaughlin, Yu Zhang, Evgeny Epifanovsky
          Initial Energy and Gradient Calculation
– Checking Topology for Ill-Behaving Coordinates –
Coordinate | Removed | Additions
Bonds                     0          0
Angles                    0          0
Torsions                  0          0
Co-Linear Type5s          0          0
Co-Linear Type6s          0          0
 Done Checking Topology
Doing -D3(0) with
s6 = 1.00000
s8 = 1.21700
rs6 = 1.37800
rs8 = 1.00000
Using C-PCM dielectric factor f(eps) = (eps-1)/eps = 0.973333
Discretize the solute cavity surface with Lebedev spheres
Using 110 Lebedev grid points for each H atom
Using 194 Lebedev grid points for other atoms
Atomic van der Waals radii (Bondi set) will be scaled by 1.20
Using smooth SwiG surface discretization
Remove points where switching function is < 1.0e-08
Keep 1538 surface tesserae and discard 2252 interior tesserae
Molecular Surface Area = 230.623 Angst**2
A cutoff of 1.0D-12 yielded 2624 shell pairs
There are 28769 function pairs
Smallest overlap matrix eigenvalue = 4.25E-04
Nucleus-field energy = 0.0000000287 hartrees
SAD guess density has 110.000000 electrons
Bang C. Huynh
Exchange: 0.1900 Hartree-Fock + 0.3500 B88 + 0.4600 muB88 + LR-HF
Correlation: 0.1900 VWN5 + 0.8100 LYP
Dispersion: Grimme D3
using 14 threads for integral computing
C-PCM solvent model [f = (eps-1)/eps], solve by matrix inversion
performed using DIIS
Cycle Energy DIIS error
1    -978.0598748457      4.80e-02
2    -973.1782858908      4.25e-03
3    -973.1093666271      5.67e-03
4    -973.3317975271      7.20e-04
5    -973.3357878339      2.96e-04
6    -973.3365646538      6.55e-05
7    -973.3366180802      2.35e-05
8    -973.3366271987      1.10e-05
9    -973.3366299269      3.12e-06
10 -973.3366302297 8.52e-07
11 -973.3366302582 4.44e-07
12 -973.3366302631 1.40e-07
13 -973.3366302638 7.22e-08
14 -973.3366302639 1.90e-08
15 -973.3366302639 7.77e-09 Convergence criterion met
SCF time: CPU 267.45s wall 21.00s
************** Final PCM Free Energy Summary **************
G_electrostatic = -0.01223071 hartree = -7.67488518 kcal/mol
G_cavitation = 0.00000000 hartree = 0.00000000 kcal/mol
G_dispersion = 0.00000000 hartree = 0.00000000 kcal/mol
G_repulsion = 0.00000000 hartree = 0.00000000 kcal/mol
Non-electrostatic Free Energy = 0.00000000 hartree = 0.00000000 kcal/mol
Total = -0.01223071 hartree = -7.67488518 kcal/mol
SCF Energy (H0 + V/2) = -973.33663026
Solute Internal Energy (H0) = -973.32439956
Total Free Energy (H0 + V/2 + non-elec) = -973.33663026 hartree
= -610777.95396184 kcal/mol
SCF energy in the final basis set = -973.3366302639
Total energy in the final basis set = -973.3366302639
MAX_CIS_SUBSPACE fits in available memory
Direct TDDFT/TDA calculation will be performed
Triplet excitation energies requested
Adding PCM contribution to the XC response (LR-PCM)
CIS energy converged when residual is below 10e- 6
1 0 4 0.001302 0.000375
2 0 4 0.000517 0.000150
3 0 4 0.000292 0.000116
4 0 4 0.000350 0.000159
5 0 4 0.000436 0.000310
6 0 4 0.000181 0.000112
7 1 3 0.000066 0.000038
8 1 3 0.000017 0.000010
9 3 1 0.000004 0.000002
10 4 0 0.000002 0.000001 Roots Converged
     TDDFT/TDA Excitation Energies
Excited state 1: excitation energy (eV) = 2.9986
Total energy for state 1: -973.22643290 au
Multiplicity: Triplet
Trans. Mom.: 0.0000 X 0.0000 Y 0.0000 Z
Strength : 0.0000000000
D( 53) → V( 1) amplitude = 0.2295
D( 55) → V( 1) amplitude = 0.9346
Excited state 2: excitation energy (eV) = 3.6048
Total energy for state 2: -973.20415465 au
D( 51) → V( 4) amplitude = -0.2601
D( 52) → V( 1) amplitude = 0.3593
D( 53) → V( 3) amplitude = 0.2322
D( 54) → V( 1) amplitude = 0.5129
D( 55) → V( 2) amplitude = 0.6166
Excited state 3: excitation energy (eV) = 3.6253
Total energy for state 3: -973.20340344 au
D( 52) → V( 1) amplitude = 0.8457
D( 52) → V( 6) amplitude = 0.2148
D( 55) → V( 2) amplitude = -0.3052
Excited state 4: excitation energy (eV) = 3.7439
Total energy for state 4: -973.19904402 au
D( 51) → V( 3) amplitude = -0.3352
D( 53) → V( 1) amplitude = 0.6940
D( 54) → V( 2) amplitude = 0.2675
D( 54) → V( 3) amplitude = 0.2267
D( 55) → V( 1) amplitude = -0.2519
D( 55) → V( 4) amplitude = -0.3521
Calculating Relaxed Density
1 0 4 0.000716 0.000255
2 0 4 0.000276 0.000133
3 0 4 0.000075 0.000032
4 0 4 0.000025 0.000011
5 0 4 0.000010 0.000005
6 3 1 0.000001 0.000001
7 4 0 0.000000 0.000000 Roots Converged
            Calling CISFollow
Q-Chem fatal error occurred in module 0, line 45:
Invalid job for state following
I have verified this crash using a pre-release v.6.1. I suspect that state-following is perhaps not yet implemented with the new optimizer and there should be a switch in place to reroute such jobs to the old optimizer. I will submit a bug ticket.
