Error in X-HCFF and CPCM calculations
Dear all,
I ran single point calculations with X-HCFF and CPCM on Qchem 6.0.0. The jobs fail right after the SCF Convergence criterion met. The error message I got is " Q-Chem fatal error occurred in module libmdc/newfileman.C, line 376:
FileMan error: End of file reached prematurely reading (54360) bytes in file FILE_PCM_NUKE_ESP."
Parts of input files are as follow:
JOBTYPE FORCE
METHOD TPSSh
UNRESTRICTED TRUE
SCF_MAX_CYCLES 450
SCF_CONVERGENCE 7
XC_GRID 1
BASIS Gen
ECP Gen
SOLVENT_METHOD PCM
SYM_IGNORE TRUE
SYMMETRY FALSE
use_libqints true
gen_scfman true
distort true
mem_static 5000
mem_total 80000
molden_format true
$distort
model XHCFF
pressure 9000
scaling 1.0
npoints_heavy 302
npoints_hydrogen 302
Theory CPCM
Method SWIG
Solver Inversion
HeavyPoints 194
HPoints 110
Radii Bondi
vdwScale 1.2
Dielectric 15.944 ! 2-butanol
What is making the error here? Thank you in advance for your help!
Do you know for certain that PCM is compatible with this method? What does the manual say? In general it is helpful if you can find a minimal example that fails, getting rid of extraneous $rem and $pcm variables.
