Facing large number of imaginary frequencies in LRC-wPBE functional
Hi, I recently performed geometry optimization followed by frequency analysis using the LRC-ωPBE functional, but I am obtaining multiple imaginary frequencies (around 20-25). However, when I carried out the same procedure using CAM-B3LYP, the optimization converged successfully with no imaginary frequencies. I’m wondering if this issue is specific to LRC-ωPBE or if there are particular settings or strategies I should adjust? I am sharing my input file here.
H 3.16448000 2.15377000 -0.15950000
C 3.67121000 1.19825000 -0.08353000
C 2.90948000 0.00000000 0.00000000
C 3.67121000 -1.19825000 0.08353000
H 3.16448000 -2.15377000 0.15950000
C 5.05577000 -1.19349000 0.08271000
H 5.58532000 -2.14066000 0.15117000
C 5.77640000 0.00000000 0.00000000
H 6.86140000 0.00000000 0.00000000
C 5.05577000 1.19349000 -0.08271000
H 5.58532000 2.14066000 -0.15117000
C 1.46255000 0.00000000 0.00000000
C 0.68551000 -1.20011000 0.00096000
C -0.68551000 -1.20011000 -0.00096000
C -1.46255000 -0.00000000 0.00000000
C -0.68551000 1.20011000 0.00096000
C 0.68551000 1.20011000 -0.00096000
C -2.90948000 -0.00000000 0.00000000
C -3.67121000 -1.19825000 -0.08353000
C -5.05577000 -1.19349000 -0.08271000
C -5.77640000 -0.00000000 0.00000000
C -5.05577000 1.19349000 0.08271000
C -3.67121000 1.19825000 0.08353000
H 1.18512000 -2.16375000 -0.00451000
H -1.18512000 -2.16375000 0.00451000
H -1.18512000 2.16375000 -0.00451000
H 1.18512000 2.16375000 0.00451000
H -3.16448000 -2.15377000 -0.15950000
H -5.58532000 -2.14066000 -0.15117000
H -6.86140000 -0.00000000 0.00000000
H -5.58532000 2.14066000 0.15117000
H -3.16448000 2.15377000 0.15950000
N -0.00171900 -0.00297200 2.93517500
C -1.43021400 -0.25815800 2.92412900
C -1.90959700 -0.91639900 4.22182800
C 0.49049800 1.36208300 2.92114100
C 0.15721100 2.10942700 4.21641500
C 0.93406700 -1.11227700 2.92837900
C 1.75956700 -1.18236500 4.21646500
H -1.61805800 -0.92629300 2.07592200
H -1.94150900 0.68806900 2.74915400
H -1.42562600 -1.88045700 4.38799700
H -2.98462200 -1.08351300 4.13331900
H -1.72474500 -0.26849100 5.08010500
H 0.00614000 1.85631300 2.07122100
H 1.56560500 1.33243200 2.74642500
H -0.91977800 2.15959500 4.38530600
H 0.53812600 3.12772800 4.12122800
H 0.63388200 1.63495700 5.07562700
H 1.59611300 -0.95039000 2.06986100
H 0.36835600 -2.02991900 2.77043500
H 2.35388000 -0.27909700 4.36473500
H 2.44078800 -2.03046500 4.12840700
H 1.11708400 -1.33672600 5.08481000
JOB_TYPE Optimization
METHOD LRC-wPBE
OMEGA 300
BASIS 6-31G(d,p)
SCF_CONVERGENCE 8
SCF_MAX_CYCLES 200
GEOM_OPT_MAX_CYCLES 200
UNRESTRICTED TRUE
SYMMETRY FALSE
SYM_IGNORE TRUE
GUI 2
CDFT TRUE
CDFT_PRINT TRUE
CDFT_BECKE_POP TRUE
CDFT_THRESH 8
BECKE_SHIFT UNSHIFTED
SOLVENT_METHOD PCM
MEM_TOTAL 248000
MEM_STATIC 4000
THEORY CPCM
method swig
radii bondi
solver inversion
$cdft
2
-1 1 32
1 33 54
JOB_TYPE Freq
METHOD LRC-wPBE
OMEGA 300
BASIS 6-31G(d,p)
SCF_CONVERGENCE 8
UNRESTRICTED TRUE
SYMMETRY FALSE
SYM_IGNORE TRUE
SOLVENT_METHOD PCM
CDFT TRUE
CDFT_PRINT TRUE
CDFT_BECKE_POP TRUE
CDFT_THRESH 8
MEM_TOTAL 248000
MEM_STATIC 4000
THEORY CPCM
method swig
radii bondi
solver inversion
$cdft
2
-1 1 32
1 33 54
This is constrained DFT, so it’s not guaranteed that solution is a minimum, is it? Are you obtaining what looks to be the same SCF solution with both methods?
I checked the charge distribution for both methods, and in both cases the CDFT constraints are satisfied. However, the final SCF energies differ significantly. With CAM-B3LYP, the energy is −986.17821808 Hartree and no imaginary frequencies are observed, whereas with LRC-ωPBE, the energy is −985.86775647 Hartree and the structure shows 20–25 imaginary frequencies.
You can’t rely on those numbers because different functionals give different energies. For example, that molecule in the gas phase, normal SCF, gives the following:
    8    -986.1753858447      2.44e-06  Convergence criterion met (CAM-B3LYP)
    7    -985.8605171264      7.65e-06  Convergence criterion met (LRC-wPBE)
So when I say “did both reach the same SCF solution”, you need to examine that in a more qualitative way (orbitals, energy levels, etc.) Or just try to perturb the LRC-wPBE calculation away from the saddle point.
