I am running a single point HSE calculation on a fairly large (2736 atoms) system, and it crashes when reaching the overlap matrix.
Relevant segments of the input and output are:
(In,P,H. 2736 atoms)
method HSE-HJS
BASIS LANL2DZ
ECP fit-LANL2DZ
scf_algorithm RCA
max_scf_cycles 3000
mem_static 250000
mem_total 500000
sym_ignore true
scf_final_print 1
thresh 10
scf_convergence 6
xc_grid 1
KS_gap_print true
BASISPROJTYPE OVPROJECTION
$external_charges
(on the H’s, used to implement pseudo-hydrogens)
Q-Chem warning in module libmdc/get_mega.C, line 171:
Allowed MEM_STATIC has been capped at MEM_STATIC=8191.
Reduce the value of MEM_STATIC to silence this warning.
Total QAlloc Memory Limit 500000 MB
Mega-Array Size 8007 MB
MEM_STATIC part 8191 MB
A cutoff of 1.0D-10 yielded2002662 shell pairs
There are 8280882 function pairs
Requested basis set is LANL2DZ
Compound shells will be simplified
There are 9792 shells and 18432 basis functions
FileMan error: End of file reached prematurely reading (570425360) bytes in file FILE_OVERLAP_MATRIX
Path: /scratch/nuritman/qchem//qchem54.9972959.pbs/320.1
The calculation is run on a 500 gb computer node (I get the same error while working with other nodes). I note that the same calculation on similar, smaller systems works fine.
I realize this is a memory issue, but I do not see how to solve it…
