FileMan error: Error reading bytes in file FILE_SET_TMP_SS
Dear QChem community,
I am having problems with TDDFT calculations, obtaining this error crashing the CIS cycle:
“FileMan error: Error reading (5963720) bytes in file FILE_SET_TMP_SS”
This is the general format of the input:
 READ test.molecule
!**REFERENCE***
JOBTYPE            SP
EXCHANGE           B3LYP
CORRELATION        NONE
BASIS              cc-PVTZ
CIS_N_ROOTS        100
MAX_CIS_CYCLES     200
CALC_SOC           TRUE
MEM_TOTAL          80000
MEM_STATIC         10000
Do you know what should I change to fix this error? Thank you very much in advance.
Hard to diagnose without a complete input file but it probably means you need more memory. (To test, see if the cc-pVDZ calculation works.) There may be a warning about memory immediately prior to the start of the TDDFT iterations. With CIS_DYNAMIC_MEM = TRUE (which I believe is the default), you shouldn’t need to set MEM_STATIC and you can instead increase MEM_TOTAL to the physical limit of your hardware.
I have made this change but it still fails at the same point. This is the complete input:
C1
O1 C1 1.2535
O2 C1 1.2535 O1 133.88
JOBTYPE            SP
EXCHANGE           B3LYP
CORRELATION        NONE
BASIS              cc-PVTZ
CIS_N_ROOTS        100
MAX_CIS_CYCLES     200
CALC_SOC           TRUE
RPA                FALSE
MEM_TOTAL          200000
!MEM_STATIC         10000
What version of Q-Chem are you using? This input runs to completion with Q-Chem v. 6.2.1. (Also, a job this small shouldn’t need all that memory; I made that comment before I had seen the $molecule section, just based on the basis set and the number of states requested.)
Try turning some things off, maybe starting with CALC_SOC, and see if you can isolate the problem.
It seems that there was a problem that is solved in Q-Chem v. 6.2.1. because using this version it does finish correctly. Thank you very much for your help!
