Force_field_params section
We are trying to use the oniom method of Q-Chem. Specifically, we placed small water cluster in a carbon nanotube. We specify small water cluster as QM part using the wb97x level of theory and also specify nanotube as MM part using oplsaa force field. In particular, The carbon and hydrogen atom types in nanotubeuse use benzene model, as shown in the attached letter, while oxyen and hydrogen atom types in the small water cluster is based on TIP3P model. out file as follows:
**** Step 1: MM calculation on the entire system ****
OPLSAA force field loaded.
Determining angles, torsions, etc. from user defined input
imptor test 0: 5-6-5-6
imptor test 0: 6-5-5-6
imptor test 0: 6-6-5-5
imptor test 0: 6-6-5-5…
Therefore,we added force_field_params. However, how are these parameters set, especially force constant and epsilon?
I’m not sure that I completely understand your question, but all of the parameters (including bond-stretching force constants and LJ epsilon parameters) can be user-defined via the $force_field_parameters section. Please see the section in the manual, 11.3.3 Using the Stand-Alone QM/MM Features‣ 11.3 Stand-Alone QM/MM Calculations ‣ Chapter 11 Molecules in Complex Environments: Solvent Models, QM/MM and QM/EFP Features, Density Embedding ‣ Q-Chem 6.0 User’s Manual. Here is a screen cap that shows the format of the $force_field_parameters section:
