Free energy in ptSS calculations
I did quite a lot of fluorescence calculations with ROKS or TDDFT coupled with External Iterations procedure. Both methods rely on ptSS correction to zeroth order free energy of ground state in excited state reaction field. If you set “PrintLevel” to 1 in $PCM section you will get Breakdown of Solute-Solvent Interaction for nonequilibrium ground state that will look like this:
----- Final ptSS ExEn Corrections (1st order (+PTD) terms) ------
 ptSS(PTE, with HF slow charges) = -0.373898 eV
------------- Breakdown of Solute-Solvent Interaction  -----------
 dG_solv (0th + 1st + 0.5*CS):      -0.391259 eV
 0th order IA:                      -1.184692 eV
 Interaction and polarization:      -2.352023 eV,  1.167331 eV
 Total 1th order contribution:       0.225587 eV
 Interaction and polarization:       0.318358 eV, -0.092771 eV
 Charge-separation correction:      -1.013429 eV
----------------- Components of ptSS terms  ----------------
0th order terms:
  <0|Q |0><i|V|i>   =  -0.086435 a.u. =  -2.352023 eV
  <0|Q |0><0|V|0>   =  -0.171595 a.u. =  -4.669326 eV
1st order terms:
  <i|Qf|i><i|V|i>   =   0.009733 a.u. =   0.264843 eV
  <0|Qf|0><i|V|i>   =  -0.001967 a.u. =  -0.053515 eV
  <0|Qf|0><0|V|0>   =  -0.003904 a.u. =  -0.106240 eV
Charge-separation terms:
  <i|Qf|i>*V(Qs,0)  =  -0.033532 a.u. =  -0.912443 eV
  <0|Qf|0>*V(Qs,0)  =   0.003711 a.u. =   0.100986 eV
---------------------- Charge Diagnostics ---------------------
  SUM of |qF(0)|    =   0.045473 or       2.28 % of q(0)
  SUM of |qS(0)|    =   1.953092 or      97.72 % of q(0)
  SUM of |qF(i)|    =   0.503542 or      25.20 % of q(0)
  S|qF(i)+qS(0)|    =   1.680396 or      84.08 % of q(0)
  S|qF(i)-qS(0)|    =   2.321728 or     116.17 % of q(0)
  SUM of q(i)       =  -0.000744 or      -0.04 % of q(0)
### RF-ptSS: Non-eq. corr. for transition from EqS-Ref state ####
    => ptSS (<i0|Ri^f - R0^f|i0>) term: -3.738984e-01 eV
 SCF time:   CPU 5812.60s  wall 297.00s
************** Final PCM Free Energy Summary **************
 G_electrostatic  =      -0.04321763 hartree =     -27.11947384 kcal/mol
 G_cavitation     =       0.00000000 hartree =       0.00000000 kcal/mol
 G_dispersion     =       0.00000000 hartree =       0.00000000 kcal/mol
 G_repulsion      =       0.00000000 hartree =       0.00000000 kcal/mol
 Non-electrostatic Free Energy =       0.00000000 hartree =       0.00000000 kcal/mol
 Total                         =      -0.04321763 hartree =     -27.11947384 kcal/mol
 SCF Energy (H0 + V/2)                       =    -863.13945745
 Solute Internal Energy (H0)                 =    -863.09623982
 Total Free Energy (H0 + V/2 + non-elec)     =    -863.13945745 hartree
                                             = -541628.18698963 kcal/mol
I have 2 questions regarding this breakdown:
  1. If you sum up “0th order IA”, “Total 1th order contribution” and “Charge-separation correction” (last one multiplied by 0.5) you will not get “dG_solv”:
    -1.184692 + 0.225587 - 0.5*1.013429 = -1.4658195
    If I understand article describing ptSS (https://doi.org/10.1063/1.4936357) correctly “dG_solv” should be calculated as:
    dG_solv = <0|Q |0><i|V|i> - 0.5*<0|Q |0><0|V|0> + (<i|Qf|i><i|V|i> - <0|Qf|0><i|V|i>) - 0.5*(<i|Qf|i><i|V|i> - <0|Qf|0><0|V|0>) + 0.5*(<i|Qf|i>*V(Qs,0)-<0|Qf|0>*V(Qs,0))
    I noticed that value 1.167331 from 0th order “Interaction and polarization” line (which I guess represents polarization work) corresponds to (minus) value of <0|Q |0><0|V|0> divided by 4:
    4.669326 / 4 = 1.167331
    which would represent half of polarization work. If you calculate manually both 0th and 1st order polarization works from values listed in “Components of ptSS terms” (and divide by 2 instead of 4) you will get “dG_solv” printed by Q-Chem:
    -2.352023 + 4.669326*0.5 + 0.318358 - (0.264843 + 0.106240)*0.5 - 1.013429*0.5 = -0.391259
    My first question is why Q-Chem prints polarization work divided by 2? Does this value have physical interpretation?
  2. From equation for “dG_solv” value:
    would correspond to 0th order solvation free energy of solute in frozen reaction field. In mentioned article after equation (34) it is written that 0th order polarization work is equal to equilibrium polarization work of initial state. The SCF solvation free energy listed at the “Final PCM Free Energy Summary” instead corresponds to:
    0.5*<0|Q |0><i|V|i> = <0|Q |0><i|V|i> - 0.5*<0|Q |0><i|V|i>
    Term representing polarization work is different because initial state potential is exchanged for final state potential. I want to ask what is the meaning of SCF free energy?
Keep in mind that I’m still learning the machinery of state specific solvation and I will be glad if someone would correct possible misunderstandings.
Tiopirfur
