Frequency calculation stalls during CPSCF/CPCM-SWIG Hessian step
I am running a constrained-DFT frequency calculation using the opt geom for an 87-atom anionic doublet using Q-Chem 6.4. The calculation completes the SCF and population-analysis steps but then appears to stop progressing after printing:
Calculating MO derivatives via CPSCF
Computing fast CPCM-SWIG hessian.
It remains at this stage without producing any additional output. I tried increasing MEM_TOTAL , but this did not improve the calculation.I am sharing my inp file
C         -2.21094        2.98226        4.09810
C         -2.23850        3.79282        2.77652
C         -2.71646        2.96916        1.58272
C         -1.89204        1.66510        1.32889
C         -0.91542        1.46608        2.52605
C         -1.64147        1.55840        3.86619
C         -0.98259        1.79135        0.07731
C         -0.09936        0.53105       -0.10437
C          0.82035        0.32905        1.09883
C         -0.01738        0.23780        2.37981
C         -2.89144        0.50681        1.17517
C         -1.63253        2.12556       -1.26979
C         -0.56858        2.63349       -2.27588
C          0.80206        1.92207       -2.12112
C          0.55013        0.53364       -1.49990
C          1.84405       -0.23008       -1.75046
C          1.50234        1.53610       -3.44989
C          2.14757        0.12226       -3.23143
C          1.77890        2.79393       -1.30807
H         -1.52098        3.50951        4.76400
H         -1.23474        4.18084        2.57803
H         -2.88296        4.66840        2.90146
H         -3.76629        2.70355        1.74753
H         -2.70784        3.60573        0.69436
H         -0.22373        2.31857        2.48856
H         -2.43047        0.80282        3.91097
H         -0.94797        1.31383        4.67659
H         -0.32431        2.63391        0.31682
H         -0.77412       -0.33313       -0.10789
H          1.52576        1.16522        1.18307
H          1.41719       -0.58005        0.97395
H         -0.61469       -0.68225        2.36875
H          0.63905        0.17160        3.25453
H         -3.54469        0.43086        2.04749
H         -2.41536       -0.46538        1.04169
H         -3.53314        0.68685        0.30696
H         -2.41233        2.88412       -1.16517
H         -2.12644        1.23151       -1.66797
H         -0.94922        2.49246       -3.29272
H         -0.43545        3.71265       -2.13992
H         -0.19127        0.07501       -2.17032
H          2.63721        0.11410       -1.07948
H          1.74143       -1.30960       -1.60517
H          2.23311        2.29431       -3.74427
H          0.77258        1.47034       -4.26199
H          1.57184       -0.58797       -3.83950
H          1.37267        3.11072       -0.34708
H          2.01609        3.69763       -1.87932
H          2.72071        2.27643       -1.10542
C          3.60337       -0.01318       -3.61669
C          4.59708        0.84848       -3.11897
C          5.93878        0.69775       -3.40736
C          6.42808       -0.35684       -4.24746
C          5.40511       -1.21637       -4.76482
C          4.06610       -1.03785       -4.45207
C          7.81896       -0.53572       -4.53932
C          8.84818        0.30503       -3.98249
C         10.18582        0.11606       -4.26200
C         10.62776       -0.91330       -5.11643
C          9.64450       -1.74935       -5.67950
C          8.30215       -1.57706       -5.41056
H          4.28624        1.66744       -2.47646
H          6.63186        1.41345       -2.97845
H          5.66620       -2.03965       -5.42070
H          3.33489       -1.72866       -4.86704
H          8.58186        1.11314       -3.30980
H         10.91347        0.78356       -3.80595
H         11.68077       -1.05716       -5.33064
H          9.94281       -2.55335       -6.34858
H          7.60034       -2.25638       -5.88194
C         -3.56693        3.02431        4.77749
C         -4.59029        2.15756        4.48182
C         -5.86476        2.26505        5.09703
C         -6.09277        3.29301        6.04875
C         -5.02962        4.18469        6.34490
C         -3.81564        4.05272        5.72855
C         -7.36495        3.39217        6.66953
C         -8.36544        2.50969        6.35670
C         -8.14070        1.48614        5.40538
C         -6.92159        1.36710        4.79158
H         -4.44721        1.35965        3.76154
H         -5.19370        4.97221        7.07393
H         -3.01472        4.74564        5.96864
H         -7.53236        4.17844        7.39905
H         -9.33405        2.59031        6.83768
H         -8.93918        0.79241        5.16626
H         -6.74504        0.58230        4.06254
   JOB_TYPE              Freq
   METHOD                wB97X-D
   BASIS                 6-311G**
   SCF_CONVERGENCE       8
   VIBMAN_PRINT          4
   UNRESTRICTED          TRUE
   SYMMETRY              FALSE
   SYM_IGNORE            TRUE
   CDFT                  TRUE
   CDFT_PRINT            TRUE
   CDFT_BECKE_POP        TRUE
   CDFT_THRESH           8
   BECKE_SHIFT           UNSHIFTED
   SOLVENT_METHOD        PCM
   S2THRESH              14
   THRESH                14
   MEM_TOTAL             480000
   MEM_STATIC            4000
   THEORY                CPCM
   heavypoints           590
   method                swig
   radii                 bondi
   solver                inversion
   DIELECTRIC            7.5
   OPTICALDIELECTRIC     1.97
$cdft
1
1 50 70
Can anyone help me with that?
Be sure that MEM_TOTAL is set to the maximum memory available on your hardware, and also consider solving the CPSCF equations in segments. See CPSCF_NSEG in the manual.
https://manual.q-chem.com/latest/Ch10.S8.SS1.html
I actually don’t think analytic Hessian calculation for CDFT is a supported feature. The job should switch to numerical frequency calculation automatically.
You may want to rerun this calculation with ideriv = 1 and becke_shift = unshifted. The latter is needed to get the correct forces. Before doing that, you may consider reoptimizing your structure using CDFT with becke_shift = unshifted turned on.
Ah, sorry - that is correct. I didn’t look at the details of the job beyond the size of the molecule. This will be expensive. I suggest a smaller basis set like 6-31G*, which shouldn’t make too much difference for frequencies, and turning the PCM discretization down to something like
HeavePoints 110
HPoints 50
in addition to setting BECKE_SHIFT = UNSHIFTED as Yuezhi suggested.
