Global density dependent (GDD) tuning procedure
Hi
I would like to know about the GDD tuning procedure.
I am familiar with IP and EA tuning methods but very new to GDD. In the IP and EA tuning procedure, we perform neutral optimization and single-point energy calculations for cationic and anionic geometry. We put all the values in the J(ω) equation to the minimum error omega value.
Can anyone tell me about the GDD tuning procedure? I want to try it for conjugated systems.
I want to know the technical things. Is it also an optimization method? How can we proceed with this method?
I checked the Q-chem manual example. From there, it is not clear to me.
It is described here:
with references to the original literature
Hi
I tried to run a job with the GDD tuning procedure.
BASIS = cc-pvdz
EXCHANGE = LRC-wPBEh
MAX_CIS_CYCLES = 400
MAX_SCF_CYCLES = 400
sts_mom = true
THRESH = 14
UNRESTRICTED = true
SPIN_FLIP = true
JOB_TYPE = optimization
omega = 200
omega_gdd = true
lrc_dft = true
CIS_N_ROOTS = 5
cis_state_derivative = 1
SYMMETRY_IGNORE = true
SYMMETRY = false
SOLVENT_METHOD = PCM
DIELECTRIC 7.5
OPTICALDIELECTRIC 1.40
but in output job ended with no error:
Cartesian Multipole Moments
Charge (ESU x 10^10)
             0.0000
Dipole Moment (Debye)
     X      -0.0002      Y       0.0001      Z       0.0003
   Tot       0.0003
    XX    -170.2931     XY     -11.5858     YY    -153.0227
    XZ      -2.0189     YZ      -5.0246     ZZ    -163.5121
   XXX   -1943.7921    XXY     -88.1646    XYY    -582.2261
   YYY       0.0022    XXZ   -1454.1026    XYZ    -117.0075
   YYZ   -1292.8328    XZZ    -656.2634    YZZ     -84.9065
   ZZZ   -4144.4214
  XXXX  -20025.7595   XXXY     281.6123   XXYY   -3369.2753
  XYYY     812.3797   YYYY   -2195.8264   XXXZ  -16769.0481
  XXYZ    -835.1369   XYYZ   -4916.9071   YYYZ      47.0203
  XXZZ  -16547.8607   XYZZ    -884.3330   YYZZ  -12229.7039
  XZZZ  -16050.6184   YZZZ   -1000.2364   ZZZZ  -75579.0995
Calculating analytic gradient of the CIS energy
PCM in get_w_cis.C
CIS relaxed dipole moment
1
1 -0.0000070
2 0.0000152
3 -0.0001037
Magnitude: 0.000 au 0.000 Debye
Is it an optimization method? Can you please help me with how I will proceed with this method?
Probably some of these options are incompatible. When you encounter a problem like this, it’s helpful if you can strip down your example and isolate what clash of input options are causing the problem, rather than having so many different things turned on at once. That’s also a good idea because you don’t seem to understand what kind of a calculation you have requested.
As an example of what I mean by isolating the problem, I created this stripped-down input file:
jobtype           opt
method		  b3lyp
basis             6-31G
lrc_dft           true
omega             300
omega_gdd         true
!cis_n_roots       1
!cis_state_deriv   1
O
H 1 0.95
H 1 0.995 2 104.5
As written, this runs w/o problem but if I uncomment the two CIS keywords, it fails in the manner that you described. This tells me there is a conflict between excited-state optimization and wGDD. (Specifically optimization, or rather the gradient, because a single-point excited-state calculation runs fine with wGDD.)
I will submit a bug ticket to document this, but I think what you are (seemingly) trying to do is not a good idea, namely, changing the omega parameter at each step of an optimization w/o putting any thought into it. I suggest that you reconsider your computational strategy.
