How to set up a "water interaction" optimization calculation?
I want to set up a calculation to optimize water interaction with a H-bond donor/acceptor as described in the ffTK paper (Figure 2). The only free parameters in this type calculation are:
  1. The distance between the donor/acceptor and water oxygen
  2. The rotation of the water molecule about the line connecting the donor/acceptor and water H or O.
Below is one of my attempts at setting this calculation up,
7  -0.401486   -0.000100    0.480833
1  -0.252815    0.000299    1.492676
6   0.325308    1.147493   -0.079578
1   0.101163    2.058770    0.484604
1  -0.030824    1.296429   -1.104572
6   1.824777    0.773671   -0.082546
1   2.316036    1.161200    0.815739
1   2.350981    1.194025   -0.944243
6   1.824608   -0.773720   -0.082574
1   2.315572   -1.161590    0.815149
1   2.350881   -1.194077   -0.945300
6   0.324652   -1.147730   -0.079157
1   0.100616   -2.058030    0.484596
1  -0.031860   -1.296593   -1.104764
1  -2.339592    0.000077   -0.012871
8  -3.267170    0.000162   -0.249158
1  -3.728470    0.000609    0.589552
JOBTYPE          OPT
METHOD           HF
BASIS            6-31G*
SCF_CONVERGENCE  8
GEOM_OPT_MAX_CYCLES 100
GEOM_OPT_DRIVER OPTIMIZE
NO_REORIENT TRUE
SYM_IGNORE TRUE
$opt
FIXED
1:14 XYZ
ENDFIXED
CONSTRAINT
stre 15 16 0.9572
stre 16 17 0.9572
bend 15 16 17 104.52
ENDCONSTRAINT
where I have fixed the molecule and constrained the water parameters.
But this takes almost 95 steps to optimize, and I am wondering if there is a more elegant way to set up this type of calculation, maybe by considering the molecule and the water as separate fragments and optimizing only the distance and the rotation (about a bond) between the fragments.
Constrained optimizations often take a lot of steps, especially when using a lot of fixed atoms, so this may be unavoidable. You could consider the use of harmonic confining potentials in placed of the fixed-atom constraints, at least for a first pass at getting the geometry. Sometimes those converge faster.
https://manual.q-chem.com/latest/subsec_HarmonicConfiner.html
