Yuezhi
October 29, 2024, 1:53am
#1
On the Q-Chem manual, there is a sample job for geometry optimization with harmonic constrained potential applied on specific atoms: 9.4.7 Atomic Confining Potentials as Alternatives to Constrained Optimization⣠9.4 Constrained Optimization ⣠Chapter 9 Exploring Potential Energy Surfaces: Searches for Critical Points and Molecular Dynamics ⣠Q-Chem 6.2 Userâs Manual
I wonder if one wants to perform a harmonic frequency calculation at the optimized structure, what would be the recommended way to set up the input. Should one simply read in the optimized structure, change the jobtype to freq and keep all the other settings unchanged? Is it needed to update the coordinates of the confined atoms under $coords?
Hello Yuezhi,
Below is a sample of how you could set up an input to complete a geometry optimization followed by a frequency calculation. You do not (and should not) change the coordinates in the “$coords” section between the two calculations.
6 5.769900 -2.321232 4.072389
6 4.767069 -1.871617 3.005656
6 5.098441 -2.427805 1.616941
7 4.170381 -2.021473 0.544478
6 7.105935 -3.153945 -3.156034
6 6.491813 -2.652981 -1.864550
8 5.179075 -2.873690 -1.815239
8 7.135603 -2.116482 -0.976827
7 -1.588193 4.199762 -2.245353
6 -1.581097 5.082075 -3.395533
6 -8.865750 -1.562067 2.667196
7 -8.547199 -2.179029 1.390102
6 -7.278447 -2.225837 0.882184
7 -6.248145 -1.782039 1.588602
7 -7.078002 -2.753936 -0.322985
6 1.115307 5.142634 3.446943
6 1.667787 4.053650 2.556181
6 2.004402 4.302378 1.221306
6 1.841554 2.747373 3.037589
6 2.486355 3.291138 0.387444
6 2.319154 1.725483 2.222298
6 2.637277 1.997325 0.888494
8 3.103003 0.956591 0.120165
6 -1.353652 2.345154 0.158362
6 -1.672753 1.990278 -1.253894
6 -1.827970 2.846424 -2.406244
8 -2.200833 2.388893 -3.508889
7 -1.936449 0.691591 -1.556272
6 -1.895840 -0.407328 -0.828119
6 -2.441564 -1.701514 -1.335011
6 -3.794873 -2.047207 -0.667237
8 -4.694276 -2.524678 -1.407573
8 -3.873100 -1.813389 0.575888
6 1.312079 -1.012027 -1.427468
8 1.504964 -0.116299 -2.154358
8 1.141341 -1.918995 -0.709231
1 5.520154 -1.909719 5.055318
1 6.784913 -1.994564 3.821567
1 4.748571 -0.774081 2.956209
1 3.753606 -2.186659 3.292677
1 6.100009 -2.118553 1.302025
1 5.108070 -3.524367 1.648282
1 4.084949 -1.004914 0.519803
1 4.805935 -2.538974 -0.924604
1 3.232699 -2.376781 0.722947
1 6.955912 -4.234631 -3.241899
1 8.171291 -2.925572 -3.172639
1 -2.288132 4.686667 -4.124680
1 -1.032339 4.476446 -1.451029
1 -9.916933 -1.750319 2.890456
1 -8.270832 -2.017933 3.463972
1 -9.290572 -2.227570 0.710052
1 -5.236229 -1.838639 1.175748
1 -6.423311 -1.205084 2.395354
1 -7.824217 -3.265025 -0.767004
1 -6.101102 -2.710878 -0.773402
1 1.281440 6.133723 3.015260
1 1.582508 5.126882 4.437202
1 1.894098 5.306799 0.820221
1 1.595347 2.522950 4.072468
1 2.745111 3.510161 -0.645864
1 2.445657 0.716827 2.601837
1 3.149938 1.228552 -0.806761
1 -1.358357 3.425646 0.317828
1 -2.102992 1.919391 0.845027
1 -0.375022 1.969276 0.493667
1 -2.215187 0.634137 -2.547071
1 -1.640766 -0.310509 0.219050
1 -1.750518 -2.522893 -1.100232
1 -2.580625 -1.686751 -2.420159
1 -0.596734 5.147773 -3.882258
1 -1.890235 6.089306 -3.098428
1 -8.701526 -0.475564 2.674801
1 5.787885 -3.413069 4.164062
1 6.608807 -2.690698 -4.013518
1 0.035008 5.027369 3.598860
method b3lyp
basis 6-31G(d,p)
jobtype opt
GEOM_OPT_COORDS 0
GEOM_OPT_MAX_CYCLES 1500
SYMMETRY false
NO_REORIENT true
HARM_OPT 1 ! turns on the harmonic confiner
HOATOMS 5 ! No. of constrained atoms
HARM_FORCE 450 !force constant
$harmonic_opt
1 5 10 11 16
$coords
1 5.769900 -2.321232 4.072389
5 7.105935 -3.153945 -3.156034
10 -1.581097 5.082075 -3.395533
11 -8.865750 -1.562067 2.667196
16 1.115307 5.142634 3.446943
method b3lyp
basis 6-31G(d,p)
jobtype freq
SYMMETRY false
NO_REORIENT true
$harmonic_opt
1 5 10 11 16
$coords
Let me know if you have any other questions,
Paige
Yuezhi
October 29, 2024, 6:46pm
#3
Thank you, Paige! That is very helpful.
Best, Yuezhi
Yuezhi
February 7, 2025, 6:57pm
#4
Hi Paige,
A follow-up question: is GEOM_OPT_COORDS = 0 in the input required for optimization with harmonic confining potential?
Thanks,
Yuezhi
paige.bowling:
GEOM_OPT_COORDS
Technically, no. However, if you choose to use the default value (-1), you may notice that your optimization gets “stuck” oscillating (energy/structure). Using Cartesian coordinates (while slower/requires more steps) is more stable/dependable. I am working on a fix for this issue, which will be implemented in the new optimizer, but it is not available yet.
Please let me know if you have any other questions.
