How to use ccsd to get analytical polarizability
I know analytic gradients are available for the CCSD, and the coupled-cluster package in Q-CHEM can calculate properties of target EOM states including permanent dipoles, angular momentum projections, static polarizabilities. So I want to know if I can get analytical polarizability from CCSD? I have tried to use the key word
   JOBTYPE                      POLARIZABILITY
   METHOD                       CCSD
   BASIS                            aug-cc-pVDZ
   MEM_TOTAL                120000
   RESPONSE_POLAR    0
but I find the output polarizability is actually the analytical polarizability from HF method. So can you give me an example of the input file if Q-chem can give analytical polarizability of CCSD?
See Section 7.10.20.8 of the manual. Examples are in Section 7.10.21.
https://manual.q-chem.com/latest/sec_EOMGRAD.html
I have tried to get the analytical polarizability using two methods. However, the results are different and neither is the same as the numerical results. So I am puzzled to use which method. Here are my input,
   METHOD            CCSD
   BASIS             aug-cc-pVDZ
   MEM_TOTAL         200000
   CC_REF_PROP       1
   CC_POL            2
   CC_DIIS_SIZE      15
   CC_FULLRESPONSE   1
   SYM_IGNORE        TRUE
   no_reorient       true
   METHOD            CCSD
   BASIS             aug-cc-pVDZ
   MEM_TOTAL         200000
   CC_REF_PROP       1
   CC_POL            3
   CC_DIIS_SIZE      15
   CC_FULLRESPONSE   0
   SYM_IGNORE        TRUE
   no_reorient       true
   METHOD            CCSD
   BASIS             aug-cc-pVDZ
   MEM_TOTAL         100000
   RESPONSE_POLAR    -1
   FDIFF_STEPSIZE    10
   SYM_IGNORE        TRUE
   no_reorient       true
the results are,
 Polarizability Tensor ALPHA_IJ, I,J=X,Y,Z (a.u.):
         44.82016642   -0.00040250   -0.00022886
         -0.00040209   46.87450347    0.00056227
         -0.00022878    0.00055402   33.88883125
 Isotropic polarizability: 1/3 * (a_xx + a_yy + a_zz)
 Isotropic polarizability in a.u. = 41.86116705
 Anisotropic polarizability: SQRT(0.5*((a_xx-a_yy)^2 + (a_yy-a_zz)^2 + (a_zz-a_xx)^2))
 Anisotropic polarizability in a.u. = 12.09012143
        -45.25278662    0.00049956    0.00022950
          0.00049956  -47.70229233   -0.00063772
          0.00022950   -0.00063772  -34.39252191
 Isotropic polarizability in a.u. = -42.44920029
 Anisotropic polarizability in a.u. = 12.26978843
and
 Polarizability tensor      [a.u.]
     43.9396279     -0.0007206     -0.0002346
     -0.0003291     45.8813873      0.0006981
     -0.0002276      0.0009505     33.3528175
  Principal components       [a.u.]
     33.3528175     43.9396276     45.8813876
  Isotropic polarizability   [a.u.]
     41.0579442
  Anisotropic polarizability [a.u.]
     11.6793846
I know the two analytical polarizability results should be different as the incomplete basis, but I want to ask if I can trust the numerical resut?
The CC_POL = 1/2 static polarizability results should be equivalent and these correspond to electric-field derivatives without orbital relaxation. Numerical equivalent of this approach would to compute MOs for your system without any electric-field perturbation, then use these “unperturbed” MOs to compute the CCSD dipole with MAX_SCF_CYCLES = 0 in the presence of electric-field pertubation.
The CC_POL= 3/4 approach would correspond to using “exact” sum-over-states expressions of these static polarizability components using EOM-CC wave functions, energies, and (transition) dipole moments.
These two approaches CC_POL=1/2 or 3/4 would be equivalent in the FCI limit. The choice is with the user to either use one or the another. CC_POL=1/2 is slightly more expensive and is size consistent; the other is not. The finite-difference results would incorporate orbital relaxation, which is why they are different from either of the analytical approaches. I don’t think there are papers comparing these approaches with experimental results beyond a handful of systems. The differences are minor though at the CCSD level (but can be large for EOM-CC target states), so you should be okay using either approach I think.
