How to use SGM method to calculate triplet excited states with ROKS?
Hi evergyone,
I am implementing the Square Gradient Minimization (SGM) method for excited-state calculations, as it is known to be more robust than the traditional Maximum Overlap Method (MOM) in avoiding variational collapse.
In the paper J. Chem. Theory Comput. 2020, 16, 1699, the authors presented results for both singlets (using the ROKS spin-purification functional) and triplets (calculated within the restricted open-shell framework). I am currently trying to reproduce these triplet energies using the SGM solver.
However, when I attempt to target the triplet state using SGM, I encounter convergence failures or unexpected program exceptions. For example, the following input file, which is slightly modified from the example in 7.8.3 Squared-Gradient Minimization‣ 7.8 Restricted Open-Shell and Δ SCF Methods ‣ Chapter 7 Open-Shell and Excited-State Methods ‣ Q-Chem 6.0 User’s Manual, cannot converge for Delta SCF calculations. Although this specific transition might be simple enough for standard methods, I am using it to verify my SGM setup for triplets before moving to more challenging systems.
N 0.0000 0.0000 0.0000
H 0.0000 -0.9377 -0.3816
H 0.8121 0.4689 -0.3816
H -0.8121 0.4689 -0.3816
F 0.0000 0.0000 6.0000
F 0.0000 0.0000 7.4120
METHOD pbe0
BASIS cc-pVDZ
SYMMETRY false
SCF_CONVERGENCE 8
The reorder section is superfluous here since the excitation is HOMO to LUMO
and thus the unpaired electron orbitals are already at the frontier.
0 3 # Targeting the Triplet state
METHOD pbe0
BASIS cc-pVDZ
SYMMETRY false
SCF_ALGORITHM sgm
ROKS true
SCF_GUESS read
$reorder_mo
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
A restricted open-shell singlet SCF calculation will be
performed using SGM with line-search. singlet observed!!
Delta = 1.116777789e+00
Using OS-ROSCF Gradient
50 -255.5445158135 4.04e-02 LineSearch Step
gen_scfman_exception: SCF failed to converge
Q-Chem fatal error occurred in module libgscf/gen_scfman/gen_scfman_main.C, line 244:
Error in gen_scfman
ROKS true
will request a restricted open-shell singlet calculation. Try
METHOD pbe0
BASIS cc-pVDZ
SYMMETRY false
SCF_CONVERGENCE 8
METHOD pbe0
BASIS cc-pVDZ
SYMMETRY false
SCF_ALGORITHM sgm
UNRESTRICTED false
SCF_GUESS read
$reorder_mo
or, even better,
METHOD pbe0
BASIS cc-pVDZ
SYMMETRY false
SCF_CONVERGENCE 8
DELTA_SCF true
$delta_scf
  triplet restricted
  triplet_SCF_algorithm SGM
Thanks a lot! Your first solution worked perfectly for the Delta SCF triplet calculation.
However, for the second solution, I have encountered error as
 Problem with processed rem input line:
DELTA_SCF TRUE
DELTA_SCF (rem variable) is not correct.
Please make sure the variable is legal and the spelling is correct.
 Q-Chem fatal error occurred in module qparser/new_read_rem.C, line 439:
 Illegal rem input in read_rem
I’m currently using version 6.2.1-1. Is DELTA_SCF a new keyword introduced in Q-Chem 6.3? That would explain why my parser isn’t recognizing it.
Thanks again for the help!
Logs indicate it was introduced to the manual on 10/29/2025, which would mean that it’s in 6.2.2. In any case, it’s in the present release (v. 6.4).
