Within Q-Chem 6.3.1, I’ve been attempting to minimize partially hydrated systems in PCM (meant to represent implicit water) using B3LYP-D4/6-311+G(2df,2p), but obtaining the vibrational frequencies has been a bit of a challenge. Despite trying to use tight geometry convergence criteria, I’ve still been getting multiple relatively small imaginary frequencies for different systems (6 for the hydrated dimer below: -111.60, -72.58, -64.41, -52.57, -31.46, and -26.22 cm^-1). A couple tests displacing along the imaginary modes and re-optimizing have not yielded significant improvements, so I’m not sure I’m necessarily dealing with saddle points. As a representative input file, here’s a lactic acid dimer hydrated with 6 explicit water molecules:
Starting geometry
H -0.9181971136 -1.9997846085 -0.1161679999
C -0.7322553792 -1.4230385374 0.7865603861
O 0.6273762795 -0.9182391054 0.7260031896
C -1.7472591976 -0.2694087575 0.8495625025
O -2.9091782803 -0.5373085883 0.4604457081
O -1.3616714764 0.8400945142 1.2949129537
C -0.8109313312 -2.2988213608 2.0224213279
H -0.0964967345 -3.1174014111 1.9506353653
H -1.8113208174 -2.7181251450 2.1082153070
H -0.5954965013 -1.7172827649 2.9182486519
C 1.0048608286 -0.2908147187 -0.3724461249
O 0.3087024587 -0.1148550804 -1.3541509500
C 2.4343152943 0.2122856055 -0.2957551172
H 2.4723777969 0.9186435999 0.5381344627
O 2.7444822428 0.9048621354 -1.4997679024
H 1.9642667048 0.8521022405 -2.0732315713
C 3.4307225392 -0.9159708426 -0.0553581096
H 3.3635386243 -1.6617902185 -0.8474286966
H 3.2427942019 -1.3961798793 0.9027880322
H 4.4381094202 -0.5032660589 -0.0460613026
H -3.4913650196 -2.1665662795 0.0517089172
O -3.8582643324 -3.0563571070 -0.1385819978
H -3.9163892102 -3.1042379698 -1.0979499424
H -2.8307482101 -0.3027665030 -1.5244451640
O -2.4309968897 -0.1983588836 -2.4016142582
H -1.4828164416 -0.1942952046 -2.2076920979
H 0.0891147799 1.3085256175 2.1814607215
O 0.8659063865 1.7280231745 2.6139021849
H 0.5742247090 1.9591773060 3.5019611631
H -1.4429707566 2.2207404437 0.1638820325
O -1.3504402965 2.9963328328 -0.4281791267
H -1.1223856626 2.6279572884 -1.2886402759
H 2.3902404583 3.7991734398 -0.2216477647
O 3.1430291070 3.6770891022 -0.8337750071
H 3.0664352440 2.7539673184 -1.1253703681
H 0.1656151782 3.7300226832 0.3665092034
O 0.9528318229 3.9613817618 0.8968538914
H 1.0065193934 3.2413000429 1.5556532198
JOBTYPE OPT
GEOM_OPT_MAX_CYCLES 1000
GEOM_OPT_TOL_GRADIENT 15
GEOM_OPT_TOL_DISPLACEMENT 60
GEOM_OPT_TOL_ENERGY 100
SCF_CONVERGENCE 11
MAX_SCF_CYCLES 500
MEM_TOTAL 75000
INPUT_BOHR FALSE
METHOD b3lyp
BASIS 6-311+G(2df,2p)
DFT_D D4
XC_GRID 000099000590
SOLVENT_METHOD PCM
Theory CPCM
Method SWIG
Solver Inversion
HeavyPoints 194
HPoints 194
Radii Bondi
vdwScale 1.2
Dielectric 78.39
JOBTYPE FREQ
SCF_CONVERGENCE 11
MAX_SCF_CYCLES 500
MEM_TOTAL 75000
FDIFF_DER 2
INPUT_BOHR FALSE
METHOD b3lyp
DFT_D D4
SOLVENT_METHOD PCM
Theory CPCM
Method SWIG
Solver Inversion
HeavyPoints 194
HPoints 194
Radii Bondi
vdwScale 1.2
Dielectric 78.39
Removing the PCM from both steps of the procedure removes all the imaginary frequencies, and I tried quickly testing this with a double-zeta basis set (6-31G) as well as with HF double-zeta, both yielding the same result of PCM having multiple imaginary frequencies and of no PCM having all real frequencies; thus, I think my issue is the with the PCM part of the computation.
The manual seems to indicate this can be an issue with PCM, and I already based my input on samples within the manual, so I’m wondering if anyone can advise on some additional settings or changes to my existing ones to mitigate the number of imaginary frequencies?
I’m happy to provide more details if need be.
