Hi developers and users,
I am seeking to perform SS-PCM/TDDFT calculations to study the vertical excitation of the 4-Amino-4’-nitrobiphenyl molecule in various polar and non-polar solvents.
The input goes as follows:
read opt_BP.txt
METHOD wB97X-D
BASIS 6-31+G(d,p)
JOB_TYPE sp
max_scf_cycles 200
SCF_CONVERGENCE 8
THRESH 14
INCDFT FALSE
PRINT_GENERAL_BASIS TRUE
PRINT_ORBITALS 10
pcm_print 1
RPA 2
cis_singlets TRUE
cis_triplets FALSE
cis_n_roots 10
NTO_PAIRS 2
SYMMETRY_IGNORE TRUE
SYMMETRY FALSE
cis_state_deriv 10
CIS_DYNAMIC_MEM TRUE
CIS_RELAXED_DENSITY TRUE
CIS_MOMENTS TRUE
SOLVENT_METHOD PCM
TDDFT_PCM FALSE
Theory IEFPCM
NONEQUILIBRIUM TRUE
ChargeSeparation Pekar
StateSpecific Perturb
TdNonEq 1
Dielectric 78.4
OpticalDielectric 1.78
METHOD wB97X-D
BASIS 6-31+G(d,p)
JOB_TYPE sp
max_scf_cycles 200
SCF_CONVERGENCE 8
THRESH 14
INCDFT FALSE
PRINT_ORBITALS 10
pcm_print 1
RPA 2
cis_singlets TRUE
cis_triplets FALSE
cis_n_roots 10
NTO_PAIRS 2
SYMMETRY FALSE
cis_state_deriv 10
CIS_MOMENTS TRUE
SOLVENT_METHOD PCM
TDDFT_PCM FALSE
Theory IEFPCM
NONEQUILIBRIUM TRUE
TdNonEq 2
Dielectric 78.4
While performing the job,the molecule exhibits a CT state at the S10 state in vacuum. However, in water, this CT state shifts to the S9 state with a decrease in excitation energy. When performing the same calculation in n-Hexane, the CT state further shifts to the S8 state, showing an even lower excitation energy than in water. I have also conducted similar calculations in various other solvents such as benzene, ethanol, and formamide, and have observed a consistent trend: the red shift of the CT state is more pronounced in non-polar solvents compared to polar solvents, which is contrary to what is normally expected.
I am not sure if this discrepancy is due to errors or missing keywords in the input file causing this inconsistency in the results.
I would greatly appreciate any assistance or insights you might offer to help resolve this issue. Thank you for your time and consideration.
