With state_analysis = true and cc_trans_prop = 2, it is possible to calculate and visualize the transition densities between EOM-CCSD excited states. Is it possible to do that transition densities between TDDFT excited states?
I also need to calculate transition dipole moments between TDDFT excited states. The only way that I’m aware of is use the GMH diabatization code (sts_gmh = true). I wonder if any other approaches are available.
The state-to-state transition moments definitely exist; use STS_MOM = TRUE. I don’t know that state-to-state transition densities exist unless it’s possible through libwfa.
WFA_REF_STATE = N does work for normal TDDFT. Thank you very much.
For EOM-CCSD jobs, I noticed that cc_trans_prop = 2 will calculate transition density for all excited state pairs, which generates an excessive amount of data. Using cc_trans_prop = 1 and setting up the reference state using cc_state_to_opt might be a preferable option in some cases. It works in a similar way as WFA_REF_STATE. This is just for future reference.
Thanks Felix. Can we put this information into the manual, both with regard to TDDFT state-to-state transition densities and Yuezhi’s trick for EOM-CCSD?
I think the information is already in the manual (the keyword wfa_ref_state is there). It probably just needs to be discussed more in the text of 10.2.12.
I can add a note in the EOM-CCSD property section regarding how to set cc_trans_prop for state analysis.
The example I mentioned (Example 7.165) uses CC_TRANS_PROP = true. So, this should translate to CC_TRANS_PROP = 1. So, I think this is already what’s in the documentation. Actually, I modelled WFA_REF_STATE to reproduce the same functionality as cc_state_to_opt
