I am trying to reproduce the (TOC) curve from this Q-Chem paper: https://onlinelibrary.wiley.com/doi/10.1002/anie.202312078
As a first step, I ran a single-point calculation at a large H–H distance to check whether I can correctly recover both the energy and the polarizability of the H₂ dimer.
Regarding the energy, everything looks fine — I obtain: -0.99867553 a.u.
However, the polarizability I get looks quite off:
=== Polarizability (a.u.) ===
= Frequency: 0.00000000 a.u. = 0.00000000 eV =
= = 0.00000000 x 10^-8 Hz =
= Wavenumber: 0.00000000 cm^(-1) =
ISOTROPIC: 8.65319129 ANISOTROPIC: 0.45031596
Trace = 25.95957388
Full Tensor:
8.50308598 -0.00000000 -0.00000000
-0.00000000 8.50308597 -0.00000000
-0.00000000 -0.00000000 8.95340194
This value does not match the expected polarizability, and when performing a PES scan, the polarizability curve I obtain does not resemble the Gaussian-like shape shown in the paper. In particular, at large separations, the polarizability tends to a constant value as I increase the H–H distance, instead of decreasing with distance as shown in your results.
I feel like I might be missing something essential to properly reproduce the results from your work.
For reference, here is my input:
H 0.000 0.000 0.0
H 0.000 0.000 4.0
UNRESTRICTED = true
METHOD = hf
BASIS = aug-cc-pvdz
SCF_ALGORITHM = diis_gdm
MAX_DIIS_CYCLES = 1
SCF_GUESS = gwh
SCF_GUESS_MIX = 2
MOPROP = 2
Thank you!
PS: The following code input was done using Q-chem 5.0 since my university does not provide the newest one
