Issue with FRAGMO Optimization: Structural Distortion
Hello, I am currently performing a geometry optimization of the (OPP•− + TEA•+) system using the FRAGMO approach. However, during the optimization, I observe that the TEA fragment becomes significantly distorted and does not retain a physically reasonable geometry. Could anyone help me with this? I am sharing my input file.
– OPP
-1 2
C 0.08350 -1.19830 -3.67120
C 0.08350 1.19830 3.67120
C 0.08270 1.19350 5.05580
C 0.08270 -1.19350 -5.05580
C 0.00100 1.20010 0.68550
C 0.00100 -1.20010 -0.68550
C 0.00000 0.00000 5.77640
C 0.00000 0.00000 -1.46260
C 0.00000 0.00000 -2.90950
C 0.00000 0.00000 -5.77640
C 0.00000 0.00000 2.90950
C 0.00000 0.00000 1.46260
C -0.00100 -1.20010 0.68550
C -0.00100 1.20010 -0.68550
C -0.08270 1.19350 -5.05580
C -0.08270 -1.19350 5.05580
C -0.08350 -1.19830 3.67120
C -0.08350 1.19830 -3.67120
H 0.15950 -2.15380 -3.16450
H 0.15950 2.15380 3.16450
H 0.15120 2.14070 5.58530
H 0.15120 -2.14070 -5.58530
H 0.00450 2.16370 -1.18510
H 0.00450 -2.16370 1.18510
H 0.00000 0.00000 -6.86140
H 0.00000 0.00000 6.86140
H -0.00450 -2.16370 -1.18510
H -0.00450 2.16370 1.18510
H -0.15120 -2.14070 5.58530
H -0.15120 2.14070 -5.58530
H -0.15950 -2.15380 3.16450
H -0.15950 2.15380 -3.16450
– TEA
1 2
H 6.56350 0.95253 1.86110
H 4.62250 2.55783 0.16630
H 7.05790 1.26503 -1.09220
C 3.82780 1.93963 0.58680
C 6.65850 -0.12397 1.71020
C 6.36450 0.82813 -1.81260
H 4.01380 1.79013 1.65190
H 5.61410 1.57203 -2.08570
H 7.47730 -0.31897 1.01550
H 2.87780 2.46553 0.47550
H 6.90060 -0.59257 2.66570
H 6.91880 0.55293 -2.71150
C 5.34050 -0.72747 1.21620
C 3.71520 0.60723 -0.16090
C 5.71960 -0.44387 -1.25270
N 4.93080 -0.17937 -0.06370
H 4.53500 -0.55687 1.92970
H 3.49760 0.76433 -1.21700
H 6.47150 -1.19117 -1.00070
H 2.91750 -0.00127 0.28010
H 5.03090 -0.86837 -1.99210
H 5.45850 -1.80667 1.06450
BASIS = 6-31G(d,p)
JOB_TYPE = Optimization
GEOM_OPT_MAX_CYCLES = 200
METHOD = CAMB3LYP
SCF_MAX_CYCLES = 200
SOLVENT_METHOD = PCM
MEM_TOTAL = 248000
MEM_STATIC = 4000
THEORY CPCM
heavypoints 590
method swig
radii bondi
solver inversion
FRAGMO is just an SCF guess, not an electronic structure model per se. You should verify that you think you’re finding the electronic state (Kohn-Sham solution) that you want, and if so then you need to think about what features of the electronic structure model might lead to the observed geometric distortions.
