Hi all,
I calculated MECP using a penalty-constrained optimization algorithm between S0 and S1 states. I used the SF-TDDFT method for this.
Here is my input:
coordinates
BASIS = cc-pVDZ
METHOD = wB97X-D
JOB_TYPE = optimization
MECP_OPT = true
mecp_methods = penalty_function
MAX_CIS_CYCLES = 400
MAX_SCF_CYCLES = 400
GEOM_OPT_MAX_CYCLES = 300
THRESH = 14
sts_mom = true
UNRESTRICTED = true
SPIN_FLIP = true
mecp_state1 = [0,1]
mecp_state2 = [0,2]
cis_s2_thresh = 120
CIS_N_ROOTS = 4
SYMMETRY_IGNORE = true
SYMMETRY = false
SOLVENT_METHOD = PCM
DIELECTRIC 32.613000
OPTICALDIELECTRIC 1.765709
and In output I got:
at the last optimization cycle:
Excited state 1: excitation energy (eV) = 0.4876
Total energy for state 1: -899.00611584 au
<S**2> : 0.1121
S( 2) → S( 1) amplitude = 0.9704 alpha
S( 2) → V( 2) amplitude = 0.1743 alpha
Excited state 2: excitation energy (eV) = 0.5069
Total energy for state 2: -899.00540911 au
<S**2> : 1.0957
S( 1) → S( 1) amplitude = 0.9881 alpha
Excited state 3: excitation energy (eV) = 0.8563
Total energy for state 3: -898.99256568 au
<S**2> : 0.9926
D( 67) → S( 2) amplitude = 0.1521
S( 2) → S( 2) amplitude = 0.9652 alpha
Excited state 4: excitation energy (eV) = 2.7267
Total energy for state 4: -898.92383098 au
<S**2> : 1.0458
D( 65) → S( 1) amplitude = -0.2151
D( 66) → S( 1) amplitude = -0.8870
D( 67) → S( 1) amplitude = -0.3176
D( 69) → S( 1) amplitude = 0.1715
and
– Optimization of the CI objective function (Cycle # 2) –
CI_Sigma (Lagrange multiplier) = 14.000
CI_Alpha (stability parameter) = 0.020 a.u.
Lower state energy (state 1) = -899.0061158375 a.u.
Upper state energy (state 2) = -899.0054091106 a.u.
Energy gap = 0.000707 a.u. (0.019 eV)
Value of F (objective function) = -899.00542478 a.u.
Value of sigma*G (penalty) = +0.00033769 a.u.
Convergence criteria value thresh cnvgd?
Component of F^x parallel to G^x: -0.00000606 0.00030000 YES
Component of F^x perpendicular to G^x: +0.00017731 0.00030000 YES
Change in the value of F: -0.00000013 0.00000100 YES
Energy gap: +0.00070673 0.00100000 YES
I want to ask here that In this it is considering E.S-1 and E.S-2 as S0 and S1 states respectively but E.S-2 S2 value is 1.09. I have given CIS_S2_THRESH = 120 which is why it is considered it singlet state but normally can we say that the calculated results are correct? This is the energy gap between S0 and S1 not between S0 and T1?
