MRSF-TDDFT triplet-state calculation does not converge
Hi everyone,
I am trying to perform an MRSF-TDDFT calculation using Q-Chem 6.4. I optimized the geometry using ωB97X-V/aug-cc-pVTZ (triplet state) and then performed MRSF-TDDFT calculations for both singlet and triplet states at the optimized geometry.
The singlet-state calculation completed successfully, but the triplet-state calculation did not converge, even after setting MAX_CIS_CYCLES 600.
I have attached the input and output files for the triplet-state calculation.
Could anyone suggest which additional keywords or changes to the input settings might help resolve this convergence issue?
Any suggestions or insights would be greatly appreciated.
Thank you!
input:
  C    1.4653593    0.7897008    0.0339171
  C    2.9378186    0.3927376   -0.0391290
  N    3.8357300    1.2485534    0.7254606
  H    0.8503762    0.1070538   -0.5589672
  H    1.1033999    0.7623716    1.0658302
  H    1.3143750    1.8023296   -0.3515393
  H    3.0722736   -0.6297143    0.3243880
  H    3.2829205    0.4027901   -1.0765322
  H    3.8426807    2.2080993    0.4076749
  H    3.6767579    1.2128121    1.7229954
  O    5.8400046    0.4483486    0.2981949
JOBTYPE sp
method WB97X-V
BASIS aug-cc-pVTZ
scf_algorithm diis_gdm
thresh 14
UNRESTRICTED          false
MR_SPIN_FLIP  1
MRSF_DUMP  false
print_orbitals  true
cis_singlets false
cis_triplets true
CIS_N_ROOTS 2
state_analysis true
max_scf_cycles  600
max_cis_cycles  600
MEM_TOTAL 750000
INTEGRAL_SYMMETRY FALSE
POINT_GROUP_SYMMETRY FALSE
output:
 579         1           1      0.000846    0.000467
 580         1           1      0.000845    0.000466
 581         1           1      0.000845    0.000466
 582         1           1      0.000847    0.000468
 583         1           1      0.000849    0.000469
 584         1           1      0.000850    0.000469
 585         1           1      0.000850    0.000469
 586         1           1      0.000850    0.000470
 587         1           1      0.000851    0.000470
 588         1           1      0.000851    0.000470
 589         1           1      0.000851    0.000470
 590         1           1      0.000851    0.000471
 591         1           1      0.000851    0.000471
 592         1           1      0.000852    0.000471
 593         1           1      0.000852    0.000471
 594         1           1      0.000852    0.000471
 595         1           1      0.000852    0.000471
 596         1           1      0.000852    0.000471
 597         1           1      0.000853    0.000471
 598         1           1      0.000853    0.000471
 599         1           1      0.000853    0.000472
 600         1           1      0.000854    0.000472
 601         1           1      0.000854    0.000472
  Maximum number of CIS/TDDFT iterations has been reached
  This limit can be increased using CIS_MAX_CYCLES
 Q-Chem fatal error occurred in module /home/data/root/qchem6.4/setman/iter.F, line  123:
 CIS/TDDFT calculation failed to converge
This input converges nicely with the latest version of Q-Chem, v.7. I think the defaults for restricted open-shell jobs may have been changed. Do you see the following immediately prior to the beginning of the SCF cycles?
 ROSCF diagonal coefficients according to McWeeny and Diercksen:
        DD      AA      BB      VV
Fa    0.333   0.333   0.000   0.667
Fb    0.667   0.333   0.000   0.333
 See [McWeeny and Diercksen, JCP 49, 4852 (1968)]
 (DOI:10.1063/1.1669970) for details.
If not, you may need to play around with different versions of RO. In our experiences, the DODS version exhibits best convergence behavior. See the Supporting Info for this paper,
https://doi.org/10.1021/acs.jctc.5c01578
which includes Q-Chem input files, or this one:
https://doi.org/10.26434/chemrxiv.15008165/v1
Yes, I see the following immediately prior to the beginning of the SCF cycles:
        DD      AA      BB      VV
 Orthonormalizing orbitals
 using 16 threads for integral computing
 A restricted open-shell SCF calculation will be
 performed using DIIS, GDM
 SCF converges when RMS gradient is below 1.0e-08
 User-specified cutoff of 10e-14
 used for neglect of 2-electron integrals.
 A cutoff of 10e-14
 used for neglect of overlap integrals.
 Incremental Fock algorithm is on at the start.
  Cycle       Energy         DIIS error
    1    -205.9575420982      3.55e-02
    2    -188.2360726628      5.70e-02
    3    -207.7258838196      2.06e-02
    4    -209.2827675268      1.13e-02
    5    -209.9769815929      7.24e-03  Done DIIS. Switching to GDM
  Cycle       Energy        RMS Gradient
    1    -209.9769815929      4.93e-01   Descent step
    2    -210.1599365188      1.85e-01   Descent step
    3    -210.2203041363      5.69e-02   Normal BFGS step
    4    -210.2403527301      5.32e-02   Normal BFGS step
    5    -210.2487350269      1.28e-02   Normal BFGS step
    6    -210.2498684020      1.18e-02   Normal BFGS step
    7    -210.2500301455      7.46e-03   Normal BFGS step
    8    -210.2500554834      2.73e-03   Normal BFGS step
    9    -210.2500620689      5.13e-04   Normal BFGS step
   10    -210.2500632112      4.09e-04   Normal BFGS step
   11    -210.2500635595      2.92e-04   Normal BFGS step
   12    -210.2500638253      1.44e-04   Normal BFGS step
   13    -210.2500639075      1.04e-04   Normal BFGS step
   14    -210.2500639418      5.40e-05   Normal BFGS step
   15    -210.2500639536      2.94e-05   Normal BFGS step
   16    -210.2500639566      2.17e-05   Normal BFGS step
   17    -210.2500639580      2.02e-05   Normal BFGS step
   18    -210.2500639602      2.12e-05   Normal BFGS step
   19    -210.2500639659      3.12e-05   Normal BFGS step
   20    -210.2500639818      5.77e-05   Normal BFGS step
   21    -210.2500640207      9.62e-05   Normal BFGS step
   22    -210.2500641103      1.38e-04   Normal BFGS step
   23    -210.2500642652      1.55e-04   Normal BFGS step
   24    -210.2500644155      1.05e-04   Normal BFGS step
   25    -210.2500644914      1.05e-04   Normal BFGS step
   26    -210.2500644999      5.27e-05   Normal BFGS step
   27    -210.2500645026      1.07e-05   Normal BFGS step
   28    -210.2500645027      5.56e-06   Normal BFGS step
   29    -210.2500645028      1.14e-06   Normal BFGS step
   30    -210.2500645028      9.04e-07   Normal BFGS step
   31    -210.2500645028      9.38e-08   Normal BFGS step
   32    -210.2500645028      6.98e-08   Normal BFGS step
   33    -210.2500645028      2.14e-08   Normal BFGS step
   34    -210.2500645028      1.50e-08   Normal BFGS step
   35    -210.2500645028      2.60e-09  Convergence criterion met
The disked orbital energies are calculated using alpha and beta Focks
 SCF time:   CPU 14026.48s  wall 1536.00s
<S^2> =          2.000000000
 SCF   energy =  -210.25006450
 Total energy =  -210.25006450
 Integrated density by DFT XC:
   Number of electrons = 34
   Numerical integral  =    33.998218183725
   Relative error      =     0.0052406361 %
 CIS/TDDFT Memory Preview
 	O*V dim = 11844
 	Mem per subspace vector = 0.1 Mb
 	Max subspace size fits in available memory
 Mixed-Reference Spin-Flip TDDFT calculation will be performed
 CIS energy converged when residual is below 10e- 6
 Iter    Rts Conv    Rts Left    Ttl Dev     Max Dev
   1         0           2      0.001899    0.001044
   2         0           2      0.001096    0.000642
   3         0           2      0.001760    0.001360
   4         0           2      0.000445    0.000353
   5         0           2      0.000180    0.000162
   6         0           2      0.000145    0.000141
   7         1           1      0.000140    0.000139
   8         1           1      0.001918    0.001917
   9         1           1      0.000661    0.000661
  10         1           1      0.000223    0.000223
  11         1           1      0.000336    0.000335
  12         1           1      0.000340    0.000340
  13         1           1      0.000309    0.000308
  14         1           1      0.000300    0.000300
  15         1           1      0.000337    0.000337
  16         1           1      0.000322    0.000321
  17         1           1      0.000307    0.000307
  18         1           1      0.000305    0.000305
  19         1           1      0.000305    0.000304
  20         1           1      0.000306    0.000305
  21         1           1      0.000305    0.000305
  22         1           1      0.000305    0.000305
  23         1           1      0.000305    0.000305
  24         1           1      0.000305    0.000305
  25         1           1      0.000305    0.000305
  26         1           1      0.000306    0.000305
  27         1           1      0.000306    0.000306
  28         1           1      0.000307    0.000306
  29         1           1      0.000306    0.000306
  30         1           1      0.000307    0.000306
  31         1           1      0.000307    0.000306
  32         1           1      0.000307    0.000306
  33         1           1      0.000307    0.000306
  34         1           1      0.000307    0.000306
  35         1           1      0.000307    0.000306
  36         1           1      0.000307    0.000307
  37         1           1      0.000307    0.000307
  38         1           1      0.000307    0.000307
  39         1           1      0.000307    0.000307
  40         1           1      0.000307    0.000307
  41         1           1      0.000308    0.000307
  42         1           1      0.000308    0.000307
  43         1           1      0.000308    0.000308
  44         1           1      0.000308    0.000308
  45         1           1      0.000308    0.000308
  46         1           1      0.000308    0.000308
  47         1           1      0.000308    0.000308
  48         1           1      0.000309    0.000309
  49         1           1      0.000309    0.000309
  50         1           1      0.000309    0.000308
  51         1           1      0.000309    0.000308
  52         1           1      0.000310    0.000310
  53         1           1      0.000310    0.000310
  54         1           1      0.000311    0.000310
  55         1           1      0.000310    0.000310
  56         1           1      0.000310    0.000310
  57         1           1      0.000311    0.000310
  58         1           1      0.000310    0.000310
  59         1           1      0.000310    0.000310
  60         1           1      0.000311    0.000310
  61         1           1      0.000311    0.000310
  62         1           1      0.000311    0.000311
  63         1           1      0.000311    0.000311
  64         1           1      0.000311    0.000311
  65         1           1      0.000311    0.000311
  66         1           1      0.000311    0.000311
  67         1           1      0.000799    0.000799
  68         1           1      0.000150    0.000150
  69         1           1      0.000082    0.000081
  70         1           1      0.000113    0.000113
  71         1           1      0.000094    0.000094
  72         1           1      0.000111    0.000110
  73         1           1      0.000137    0.000137
  74         1           1      0.000124    0.000124
  75         1           1      0.000124    0.000124
  76         1           1      0.000131    0.000131
  77         1           1      0.000127    0.000127
  78         1           1      0.000132    0.000132
  79         1           1      0.000130    0.000130
  80         1           1      0.000132    0.000131
  81         1           1      0.000136    0.000136
  82         1           1      0.000147    0.000146
  83         1           1      0.000145    0.000144
  84         1           1      0.000143    0.000143
  85         1           1      0.000145    0.000145
  86         1           1      0.000146    0.000146
  87         1           1      0.000149    0.000149
  88         1           1      0.000148    0.000148
  89         1           1      0.000152    0.000152
  90         0           2      0.001717    0.001565
  91         0           2      0.000235    0.000152
  92         0           2      0.000180    0.000152
  93         0           2      0.000181    0.000154
  94         0           2      0.000203    0.000172
  95         0           2      0.000203    0.000168
  96         0           2      0.000211    0.000167
  97         0           2      0.000209    0.000167
  98         0           2      0.000210    0.000167
  99         0           2      0.000213    0.000169
 100         0           2      0.000222    0.000175
 101         0           2      0.000224    0.000178
 102         0           2      0.000226    0.000179
 103         0           2      0.000235    0.000188
 104         0           2      0.000238    0.000189
 105         0           2      0.000238    0.000188
 106         0           2      0.000242    0.000190
 107         0           2      0.000257    0.000194
 108         0           2      0.000276    0.000204
 109         0           2      0.000277    0.000205
 110         0           2      0.000283    0.000209
 111         0           2      0.000352    0.000216
 112         0           2      0.000309    0.000219
 113         0           2      0.000304    0.000220
 114         0           2      0.000319    0.000220
 115         0           2      0.000316    0.000220
 116         0           2      0.000332    0.000230
 117         0           2      0.000348    0.000240
 118         0           2      0.000355    0.000246
 119         0           2      0.000359    0.000252
 120         0           2      0.000370    0.000245
 121         0           2      0.000378    0.000253
 122         0           2      0.000383    0.000259
 123         0           2      0.000395    0.000266
 124         0           2      0.000390    0.000260
 125         0           2      0.000399    0.000262
 126         0           2      0.000399    0.000262
 127         0           2      0.000402    0.000265
 128         0           2      0.000405    0.000263
 129         0           2      0.000410    0.000268
 130         0           2      0.000409    0.000267
 131         0           2      0.000415    0.000267
 132         0           2      0.000425    0.000267
 133         0           2      0.000432    0.000271
 134         0           2      0.000431    0.000270
 135         0           2      0.000436    0.000270
 136         0           2      0.000438    0.000275
 137         0           2      0.000446    0.000277
 138         0           2      0.000453    0.000278
 139         0           2      0.000449    0.000278
 140         0           2      0.000452    0.000280
 141         0           2      0.000468    0.000293
 142         0           2      0.000476    0.000302
 143         0           2      0.000476    0.000300
 144         0           2      0.000474    0.000299
 145         0           2      0.000476    0.000298
 146         0           2      0.000476    0.000298
 147         0           2      0.000481    0.000302
 148         0           2      0.000488    0.000310
 149         0           2      0.000493    0.000310
 150         0           2      0.000492    0.000309
 151         0           2      0.000495    0.000310
 152         0           2      0.000495    0.000310
 153         0           2      0.000498    0.000311
 154         0           2      0.000499    0.000310
 155         0           2      0.000498    0.000311
 156         0           2      0.000513    0.000311
 157         0           2      0.000514    0.000314
 158         0           2      0.000513    0.000314
 159         0           2      0.000517    0.000318
 160         0           2      0.000525    0.000321
 161         0           2      0.000524    0.000321
 162         0           2      0.000530    0.000324
 163         0           2      0.000533    0.000322
 164         0           2      0.000533    0.000324
 165         0           2      0.000537    0.000325
 166         0           2      0.000537    0.000325
 167         0           2      0.000542    0.000329
 168         0           2      0.000544    0.000328
 169         0           2      0.000546    0.000329
 170         0           2      0.000549    0.000330
 171         0           2      0.000553    0.000330
 172         0           2      0.000554    0.000331
 173         0           2      0.000557    0.000335
 174         0           2      0.000557    0.000334
 175         0           2      0.000558    0.000335
 176         0           2      0.000560    0.000336
 177         1           1      0.000561    0.000336
 178         1           1      0.000561    0.000336
 179         1           1      0.000561    0.000336
 180         1           1      0.000562    0.000336
 181         1           1      0.000566    0.000336
 182         1           1      0.000565    0.000337
 183         1           1      0.000564    0.000336
 184         1           1      0.000565    0.000337
 185         1           1      0.000565    0.000337
 186         1           1      0.000565    0.000337
 187         1           1      0.000565    0.000337
 188         1           1      0.000567    0.000338
 189         1           1      0.000567    0.000338
 190         1           1      0.000567    0.000338
 191         1           1      0.000567    0.000338
 192         1           1      0.000568    0.000338
 193         1           1      0.000568    0.000338
 194         1           1      0.000568    0.000338
 195         1           1      0.000568    0.000338
 196         1           1      0.000569    0.000338
 197         1           1      0.000569    0.000338
 198         1           1      0.000569    0.000338
 199         1           1      0.000569    0.000338
 200         1           1      0.000569    0.000339
 201         1           1      0.000570    0.000339
 202         1           1      0.000572    0.000339
 203         1           1      0.000573    0.000339
 204         1           1      0.000572    0.000339
 205         0           2      0.000574    0.000339
 206         0           2      0.000576    0.000341
 207         0           2      0.000577    0.000341
 208         0           2      0.000582    0.000341
 209         0           2      0.000580    0.000341
 210         0           2      0.000583    0.000341
 211         0           2      0.000585    0.000344
 212         0           2      0.000584    0.000342
 213         0           2      0.000585    0.000343
 214         0           2      0.000586    0.000343
 215         0           2      0.000588    0.000345
 216         0           2      0.000591    0.000348
 217         0           2      0.000589    0.000346
 218         0           2      0.000593    0.000350
 219         0           2      0.000595    0.000350
 220         0           2      0.000595    0.000351
 221         0           2      0.000598    0.000351
 222         0           2      0.000599    0.000352
 223         0           2      0.000603    0.000357
 224         0           2      0.000604    0.000356
 225         0           2      0.000606    0.000356
 226         0           2      0.000606    0.000356
 227         0           2      0.000611    0.000358
 228         0           2      0.000615    0.000359
 229         0           2      0.000612    0.000359
 230         0           2      0.000614    0.000358
 231         0           2      0.000614    0.000359
 232         0           2      0.000616    0.000360
 233         0           2      0.000618    0.000360
 234         0           2      0.000616    0.000360
 235         0           2      0.000618    0.000360
 236         0           2      0.000619    0.000360
 237         0           2      0.000620    0.000361
 238         0           2      0.000626    0.000367
 239         0           2      0.000625    0.000365
 240         0           2      0.000626    0.000366
 241         0           2      0.000628    0.000367
 242         0           2      0.000629    0.000366
 243         0           2      0.000629    0.000367
 244         0           2      0.000630    0.000368
 245         0           2      0.000632    0.000369
 246         0           2      0.000632    0.000369
 247         0           2      0.000631    0.000369
 248         0           2      0.000632    0.000369
 249         0           2      0.000640    0.000371
 250         0           2      0.000638    0.000370
 251         0           2      0.000640    0.000370
 252         0           2      0.000642    0.000371
 253         0           2      0.000642    0.000370
 254         0           2      0.000642    0.000371
 255         0           2      0.000644    0.000371
 256         0           2      0.000645    0.000372
 257         1           1      0.000646    0.000373
 258         1           1      0.000646    0.000373
 259         1           1      0.000649    0.000373
 260         1           1      0.000648    0.000373
 261         1           1      0.000649    0.000374
 262         1           1      0.000648    0.000374
 263         1           1      0.000649    0.000374
 264         1           1      0.000649    0.000374
 265         1           1      0.000649    0.000375
 266         1           1      0.000650    0.000375
 267         1           1      0.000651    0.000375
 268         1           1      0.000651    0.000376
 269         1           1      0.000653    0.000376
 270         1           1      0.000653    0.000376
 271         1           1      0.000653    0.000376
 272         1           1      0.000653    0.000376
 273         1           1      0.000653    0.000376
 274         1           1      0.000653    0.000376
 275         1           1      0.000654    0.000376
 276         1           1      0.000655    0.000376
 277         1           1      0.000655    0.000376
 278         1           1      0.000655    0.000376
 279         1           1      0.000655    0.000376
 280         1           1      0.000655    0.000376
 281         1           1      0.000655    0.000376
 282         1           1      0.000656    0.000376
 283         1           1      0.000656    0.000377
 284         1           1      0.000658    0.000379
 285         1           1      0.000658    0.000378
 286         1           1      0.000658    0.000378
 287         1           1      0.000659    0.000378
 288         1           1      0.000661    0.000380
 289         1           1      0.000660    0.000379
 290         1           1      0.000663    0.000380
 291         1           1      0.000662    0.000380
 292         1           1      0.000663    0.000380
 293         1           1      0.000663    0.000380
 294         1           1      0.000663    0.000380
 295         1           1      0.000664    0.000382
 296         1           1      0.000665    0.000382
 297         1           1      0.000665    0.000382
 298         1           1      0.000666    0.000382
 299         1           1      0.000665    0.000382
 300         1           1      0.000665    0.000382
 301         1           1      0.000665    0.000383
 302         1           1      0.000666    0.000383
 303         1           1      0.000666    0.000383
 304         1           1      0.000668    0.000383
 305         1           1      0.000668    0.000384
 306         1           1      0.000667    0.000383
 307         1           1      0.000667    0.000383
 308         1           1      0.000668    0.000384
 309         1           1      0.000670    0.000384
 310         1           1      0.000671    0.000384
 311         1           1      0.000672    0.000384
 312         1           1      0.000671    0.000384
 313         1           1      0.000672    0.000385
 314         1           1      0.000673    0.000385
 315         1           1      0.000673    0.000385
 316         1           1      0.000674    0.000385
 317         1           1      0.000675    0.000385
 318         1           1      0.000675    0.000385
 319         1           1      0.000677    0.000386
 320         1           1      0.000677    0.000386
 321         1           1      0.000678    0.000387
 322         1           1      0.000678    0.000386
 323         1           1      0.000678    0.000386
 324         1           1      0.000678    0.000386
 325         1           1      0.000679    0.000387
 326         1           1      0.000679    0.000387
 327         1           1      0.000681    0.000389
 328         1           1      0.000680    0.000388
 329         1           1      0.000682    0.000389
 330         1           1      0.000683    0.000390
 331         1           1      0.000683    0.000390
 332         1           1      0.000684    0.000391
 333         1           1      0.000685    0.000391
 334         1           1      0.000684    0.000391
 335         1           1      0.000685    0.000392
 336         1           1      0.000686    0.000393
 337         1           1      0.000688    0.000392
 338         1           1      0.000689    0.000392
 339         1           1      0.000689    0.000392
 340         1           1      0.000689    0.000392
 341         1           1      0.000688    0.000392
 342         1           1      0.000689    0.000392
 343         1           1      0.000689    0.000392
 344         1           1      0.000689    0.000393
 345         1           1      0.000689    0.000393
 346         1           1      0.000689    0.000393
 347         1           1      0.000689    0.000393
 348         1           1      0.000690    0.000393
 349         1           1      0.000690    0.000393
 350         1           1      0.000690    0.000393
 351         1           1      0.000690    0.000393
 352         1           1      0.000691    0.000393
 353         1           1      0.000693    0.000393
 354         0           2      0.000693    0.000393
 355         0           2      0.000699    0.000394
 356         0           2      0.000699    0.000395
 357         0           2      0.000700    0.000395
 358         0           2      0.000701    0.000395
 359         0           2      0.000701    0.000395
 360         0           2      0.000706    0.000396
 361         0           2      0.000707    0.000398
 362         0           2      0.000707    0.000397
 363         0           2      0.000708    0.000397
 364         0           2      0.000709    0.000397
 365         0           2      0.000708    0.000397
 366         0           2      0.000709    0.000397
 367         0           2      0.000710    0.000398
 368         0           2      0.000711    0.000399
 369         0           2      0.000714    0.000400
 370         0           2      0.000715    0.000401
 371         0           2      0.000716    0.000401
 372         0           2      0.000718    0.000404
 373         0           2      0.000718    0.000404
 374         0           2      0.000718    0.000404
 375         0           2      0.000719    0.000404
 376         0           2      0.000721    0.000404
 377         0           2      0.000721    0.000404
 378         0           2      0.000722    0.000405
 379         0           2      0.000724    0.000405
 380         0           2      0.000725    0.000405
 381         0           2      0.000726    0.000405
 382         0           2      0.000727    0.000405
 383         0           2      0.000729    0.000408
 384         0           2      0.000730    0.000409
 385         0           2      0.000730    0.000408
 386         0           2      0.000731    0.000408
 387         0           2      0.000733    0.000410
 388         0           2      0.000737    0.000409
 389         0           2      0.000737    0.000409
 390         0           2      0.000737    0.000409
 391         0           2      0.000739    0.000410
 392         0           2      0.000741    0.000410
 393         0           2      0.000742    0.000411
 394         0           2      0.000746    0.000411
 395         0           2      0.000750    0.000412
 396         0           2      0.000751    0.000415
 397         0           2      0.000751    0.000414
 398         0           2      0.000751    0.000414
 399         0           2      0.000751    0.000414
 400         0           2      0.000751    0.000415
 401         0           2      0.000753    0.000416
 402         0           2      0.000753    0.000415
 403         0           2      0.000753    0.000416
 404         0           2      0.000755    0.000417
 405         0           2      0.000756    0.000418
 406         0           2      0.000756    0.000418
 407         0           2      0.000757    0.000418
 408         0           2      0.000760    0.000421
 409         0           2      0.000762    0.000423
 410         0           2      0.000761    0.000422
 411         0           2      0.000762    0.000422
 412         0           2      0.000762    0.000423
 413         0           2      0.000762    0.000423
 414         0           2      0.000763    0.000423
 415         0           2      0.000765    0.000425
 416         0           2      0.000767    0.000426
 417         0           2      0.000768    0.000427
 418         0           2      0.000768    0.000427
 419         0           2      0.000768    0.000427
 420         0           2      0.000769    0.000427
 421         0           2      0.000769    0.000428
 422         0           2      0.000771    0.000428
 423         0           2      0.000772    0.000428
 424         0           2      0.000774    0.000428
 425         0           2      0.000775    0.000430
 426         1           1      0.000774    0.000429
 427         1           1      0.000774    0.000429
 428         1           1      0.000775    0.000430
 429         1           1      0.000776    0.000430
 430         1           1      0.000777    0.000430
 431         1           1      0.000779    0.000430
 432         1           1      0.000780    0.000430
 433         1           1      0.000779    0.000430
 434         1           1      0.000779    0.000430
 435         1           1      0.000779    0.000430
 436         1           1      0.000780    0.000430
 437         1           1      0.000780    0.000430
 438         1           1      0.000780    0.000430
 439         1           1      0.000780    0.000430
 440         1           1      0.000780    0.000430
So this is a TDDFT convergence problem, not a ground-state problem. Try increase the number of states requested. That increases the number of subspace vectors for the Davidson iterations, which can sometimes help.
