Phase of NTO from hole.cube and elec.cube
Hi, I calculated NTO and got hole.cube and elec.cube. But when I visualized them, the their phase does not appear. It’s like density.
How can I get the phase information of NTO ? The input is following.
Many thanks,
C -1.64475700 0.27638500 0.11540100
C -1.61196100 -1.07266400 0.01776100
N -0.44494800 -1.75592600 -0.23209800
C 0.79255200 -1.13313100 -0.40451600
N 0.72215600 0.24599100 -0.29871600
C -0.41396500 1.04797700 -0.04634700
O -0.30905700 2.26000900 0.01843000
O 1.81397900 -1.75427800 -0.62421100
H -2.56750300 0.81773100 0.31289500
H -2.50219400 -1.69431000 0.13028500
H -0.42955200 -2.76658600 -0.30314000
H 1.60269900 0.74129200 -0.41779300
basis = 6-311(2+)G*
method = hf
cis_n_roots = 4
cis_singlets = true
cis_triplets = false
state_analysis = true
nto_pairs = 10
MAKE_CUBE_FILES = ntos
CUBEFILE_STATE = 2
$plots
NTO
100 -20 30
100 -20 20
100 -10 10
0 0 1 0
1
Please see examples in the manual for generation of volumetric data using cube files,
https://manual.q-chem.com/latest/sec_cubefiles.html
e.g., example 10.21. If you’re not seeing a phase, it’s probably not a NTO. I’m not 100% certain that NTO cube file printing is compatible with STATE_ANALYSIS = TRUE.
Hi, there are two ways to accesss NTOs. You can either turn off state_analysis and do as John says.
Or, if you want to keep state_analysis, then you’d have to go via
basis = 6-311(2+)G*
method = hf
cis_n_roots = 4
cis_singlets = true
nto_pairs = 10
make_cube_files = true
wfa_level = 4
wfa_orb_thresh = 3
following Example 10.9 as taken from 10.2.12 General Excited-State Analysis‣ 10.2 Wave Function Analysis ‣ Chapter 10 Molecular Properties and Analysis ‣ Q-Chem 6.3 User’s Manual
Generally speaking my recommendation is not to use cube files because they just take up huge amounts of space. Personally, I would generate molden files and look at them with Jmol. Alternatively, it also works well to write data to the fchk file and look at with IQmol.
Just to follow up: hole.cube is the hole density. So, this is what you get if you sum over the squares of all hole NTOs weighted by their amplitude
Thanks ! When STATE_ANALYSIS is FALSE, it works.
Is the situation same for EOM-CCSD case ?
Thanks! It is very helpful.
Hi, for EOM-CCSD you’ll have to use state_analysis. Then it works also there.
For Q-Chem v. 6.3.1, I have added backstops that should prevent use of STATE_ANALYSIS with incompatible TD-DFT analysis tools.
