Potential energy scan with vertical excitations
Following the remark in the manual, saying:
" Potential scans with JOBTYPE = PES_SCAN are available for ground-state potential energy surfaces only, although one may compute excitation energies along the scanned coordinate(s) by including appropriate keywords for vertical excitation in the $rem section, e.g. , CIS_N_ROOTS for CIS/TDDFT excited states."
I am trying to do just that - perform a relaxed potential energy scan at the ground electronic state, which at each converged point is supplemented by a single point caculations of the vertical excitation energies (at the TDDFT level of theory). One may do it by hand, first obtaining the relaxed ground state geometries and compute TDDFT for each of them separately, but it is a tedious job and it seems pretty easy to be performed by the program, as the manual hints it should do.
Unfortunately, this does not seem to work. The input looks like this:
C 2.413597 -0.441168 1.147203
C 1.749464 0.013992 0.008578
C 2.491228 0.321590 -1.132347
C 3.871460 0.165029 -1.137171
C 4.526611 -0.290628 0.001453
C 3.794694 -0.589828 1.144740
C 0.272810 0.152503 0.009765
C -0.552931 -0.929936 0.251028
C -1.968441 -0.722871 0.237591
N -2.599378 0.408392 0.017379
C -1.800095 1.475322 -0.217541
C -0.359907 1.399838 -0.231161
C -0.396269 -2.338853 0.500151
N -1.576510 -2.902677 0.629399
N -2.531317 -1.937495 0.480104
C -2.415404 2.730734 -0.459629
C -1.666003 3.850049 -0.691850
C -0.253265 3.782525 -0.691196
C 0.377948 2.591150 -0.465647
C 0.852716 -3.144777 0.600262
C -3.933569 -2.265668 0.546017
H -3.495769 2.765343 -0.449803
H -2.154570 4.798150 -0.872905
H 0.326492 4.678401 -0.865765
H 1.457007 2.542455 -0.457966
H 1.981062 0.675621 -2.017867
H 4.434663 0.398774 -2.030459
H 5.601390 -0.410382 -0.002038
H 4.298308 -0.940433 2.035389
H 1.843031 -0.674902 2.035815
H 0.600212 -4.200895 0.667987
H 1.492811 -2.986498 -0.268251
H 1.436993 -2.867395 1.478384
H -4.176206 -2.701401 1.514648
H -4.494407 -1.345148 0.410257
H -4.198496 -2.972447 -0.240246
jobtype pes_scan
method b3lyp5
dft_d d3_bj
dft_d3_s6 100000
dft_d3_s8 198890
dft_d3_a1 39810
dft_d3_a2 442110
basis def2-tzvpp
MAX_SCF_CYCLES 500
SCF_CONVERGENCE 9
scf_final_print true
MEM_STATIC 2000
MEM_TOTAL 80000
solvent_method pcm
CIS_N_ROOTS 1
CIS_TRIPLETS false
CIS_RELAXED_DENSITY true
RPA 2
Theory iefpcm
NonEquilibrium
StateSpecific perturb
solventname cyclohexane
$scan
tors 8 7 2 1 80 120 3
and the claculations crash after completing TDDFT, with a message:
Calculating analytic gradient of the CIS energy
FileMan error: Error positioning pointer with offset 18446744073708642688 in file FILE_CIS_DENSITY
Path: /net/ascratch/people/plgjoannaz/slurm_jobdir/8454306/tmp/qchem3691991/74.0
which in my opinion suggests that the program started to calculate gradients for the excited state, instead of the ground state, as intended.
Please, point me at what I am doing wrong, or whether Qchem can do such a thing that I have described, or I misunderstood the manual and it is simply impossible.
Yours!
Marcin Andrzejak
It’s possible that the manual is wrong. Please provide a simplified example (small molecule, minimal number of REMs) and I will investigate.
For what you are trying to do, I would probably just write a script to grab geometries and then generate new Q-Chem input files.
