we are trying to run qm-mm calculation using qchem for system with molecular probe inside active site of protein in water using default qchem CHARMM27 force field. Molecule (first 90 atoms in input) should be treated at QM level and environment at MM level. But there is a problem with this calculation, that it stops at the beginning without any error message.
So, the output looks like this:
**** Step 1: MM force contributions ****
CHARMM27 force field loaded.
Determining angles, torsions, etc. from user defined input
Determining VDW/Coulomb pairs… (useList = 0)
Time req’d to get MM system information: 0.3 s (CPU) 0.7 s (wall)
The input is here: QMM input - JustPaste.it
Please look at it.
When we tried to do the same but with only molecule (first 90 atoms in input) and 3 water molecule, it was working, but it’s not working for full system.
There is also XYZ file, if you would like to see this system in VMD or something.
Thanks you in advance!
Łukasz Milewski
l.milewski@cent.uw.edu.pl
