Hello guys.
I have tried to make a python file that can import xyz coordinates from output file after geometry optimization and create a new input file automatically to do other jobs (like sp calculation) using the optimized coordinates.
So I wrote codes and got a new input file, but there was a problem.
When I submitted it to Qchem program and the calculation was proceeded, there was a change in coordinates represented by ‘Standard Nuclear Orientation’. You can check it below.
I think the input file is ok as the coordinates don’t need to be arranged clearly if there is a blank between the coordinates.
But I have never seen this situation when I made a new input file from the optimized output file by handmade.
So I wonder whether it is ok to continue the calculation.
A new input file by a python programming
N 6.0382993654 3.8132988997 -0.4555276482
C 4.9864438977 4.2990168568 -1.2164856476
C 3.9135235709 3.3203534079 -1.5135810805
C 6.2027919159 2.5279327012 0.0497140536
C 5.1058348486 1.5837543099 -0.2617172763
C 3.9948849765 1.9890998611 -1.0403906428
C 2.8320071623 3.7259003188 -2.2592401065
C 1.7886156335 2.8356409139 -2.516702544
C 1.8084135217 1.5375556778 -2.0293002957
C 2.9453649299 1.0716740171 -1.3135139273
C 5.1566983114 0.3067862381 0.2296411736
C 4.147074806 -0.6152445182 -0.0738308777
C 3.0423250546 -0.280151331 -0.8416821219
C 0.6727859737 0.6324026277 -2.217618243
C 1.9839069919 -1.2445207727 -1.2165475546
C 0.8211365828 -0.7516093271 -1.9044779455
C -0.5480608552 1.1057017094 -2.6701516749
C -1.6273484195 0.2504507052 -2.8872355459
C -0.256459703 -1.6222624821 -2.2082540885
C 1.9911248557 -2.6026791737 -0.90334138
C 0.9917942632 -3.4849244248 -1.3465030731
C -0.1292851681 -3.0112818308 -1.963350785
C -1.4814419795 -1.0986847745 -2.6820298962
C -2.6534304523 -1.9796217269 -2.8708260323
C -1.2568990353 -3.9339521378 -2.2299970739
N -2.4003588258 -3.3366134103 -2.7389833066
O 7.187457522 2.2366236716 0.6960901489
O 4.967767673 5.45368651 -1.5946968519
O -3.7720239694 -1.5729018426 -3.1167881429
O -1.2302107648 -5.1278477665 -2.0019698761
H 6.7815402338 4.4712601056 -0.2487632572
H 2.8072494334 4.7450428287 -2.6294787263
H 0.953608376 3.1836858311 -3.1091982696
H 5.9916045077 0.0173947697 0.8566145453
H 4.26728753 -1.611330997 0.3003439625
H -0.6987969327 2.164458991 -2.8268313571
H -2.5891984214 0.6291628631 -3.2093196846
H 1.0725828682 -4.5372402981 -1.1030151135
H -3.2132860161 -3.9363849536 -2.8190094683
O 2.9967859427 -3.1774228083 -0.1681547536
C 2.9372683697 -3.3648715769 1.2052601635
C 1.7907175585 -3.387381658 2.0124859029
C 4.1972117012 -3.5869911348 1.7617058802
C 1.9717044361 -3.6599645886 3.3749736509
C 3.2219346991 -3.8639567303 3.9364124897
C 4.346004339 -3.8255437963 3.1178826261
C 0.3895750229 -3.2152747694 1.5486932098
C -0.0975345503 -2.0018920797 1.0738562331
C -1.3965979842 -1.8952418142 0.6110191647
C -2.2815189885 -2.9712117596 0.6801562868
C -1.8028690037 -4.1755254266 1.2045059532
C -0.4855694029 -4.2998545915 1.6181275927
C -3.6856465848 -2.8876285565 0.2143649572
C -4.5110379454 -1.7725490266 0.407255902
C -5.8577209627 -1.7964586336 0.0661303734
C -6.400163198 -2.9129573339 -0.5527366147
C -5.5931029578 -4.0187472822 -0.7995955872
C -4.2641490095 -4.0043307753 -0.4046360805
H 5.0550568958 -3.5746533822 1.0975939804
H 1.0912466373 -3.6731930294 4.0071955709
H 3.3111621181 -4.0537454577 5.0011552236
H 5.3378681956 -3.984363941 3.528232073
H 0.5612381779 -1.1470785777 1.0125940681
H -1.7072505198 -0.9747473842 0.1463195757
H -2.4702067514 -5.0263979567 1.2858619407
H -0.123383932 -5.2498207328 1.9976248857
H -6.4700367876 -0.9313139214 0.2942544295
H -7.4468788649 -2.9172171802 -0.8371103543
H -6.0020525415 -4.8965600288 -1.2893789694
H -3.630734832 -4.8647852684 -0.5999721526
O -4.0060384309 -0.6515767656 1.0590036336
C -3.6756609604 0.4735514263 0.3516170311
C -2.5721098742 1.2233764147 0.7686032844
C -2.1567711881 2.3126692428 -0.0601552945
C -2.9726828614 2.7442412178 -1.1322928478
C -4.1284224047 1.9990542601 -1.4567505869
C -4.4361581255 0.8590041469 -0.7668496144
C -0.8817533227 2.9307454454 0.1109732704
C -0.558783657 4.0421946755 -0.6509298166
C -1.4166382679 4.5203097381 -1.6466942465
C -2.5925085829 3.8590501353 -1.9145855114
C -3.4352541736 4.3016834153 -3.0491560755
C -4.9963578036 2.4061340635 -2.5879080089
N -4.561764824 3.5244159522 -3.2896046009
C 0.0862196254 2.3003508685 1.0137024773
C -0.376377243 1.3048611061 1.9201057215
C -1.7350140657 0.8655530115 1.9244483001
C 1.4359670655 2.606124878 0.9751073821
C 2.3546851753 1.932718687 1.7860158936
C 1.9244045755 0.9897659275 2.6865885468
C 0.544781345 0.7049851198 2.812812949
C 0.0842354483 -0.2122601514 3.7861639736
C -1.25891923 -0.4763374659 3.8920462814
C -2.1631560113 0.0485179955 2.9593819057
C 2.9180279833 0.2193167106 3.46630488
C 1.0465523923 -0.9155681371 4.6608810778
N 2.3845223793 -0.6374805482 4.4182023313
O 4.1194220408 0.2972392573 3.2972314514
O 0.7252771632 -1.719289917 5.5159059343
O -3.179844293 5.2621980191 -3.7468752787
O -6.0152541218 1.8278608728 -2.9021629924
H -5.2757379615 0.2684747299 -1.1048659625
H 0.3879169386 4.5442279444 -0.4991948076
H -1.1542115704 5.383479677 -2.2486428283
H -5.1474486 3.8182642589 -4.0635256955
H 1.8151830895 3.3276087566 0.2638920674
H 3.4173518668 2.1215947442 1.6995979955
H -1.5965022542 -1.1540884994 4.6681488921
H -3.1989463728 -0.2459296266 3.0166902439
H 3.0522536717 -1.2148673956 4.9165386129
   BASIS  =  6-31G*
   JOB_TYPE  =  Optimization
   exchange  =  CAMB3LYP
   DFT_D  =  EMPIRICAL_GRIMME
   SCF_CONVERGENCE  =  8
   scf_algorithm rca_diis
   SCF_MAX_cycles 512
   MEM_TOTAL = 8000
   GUI = 0
   GEOM_OPT_MAX_CYCLES = 500
   XC_GRID = 75000302
   THRESH = 14
$empirical_dispersion
   S6 1.0
Standard Nuclear Orientation from a new calculation
    1      N       6.2330866618     3.5428516533    -0.5226915966
    2      C       5.1079073060     4.3448621955    -0.6328253476
    3      C       3.8540971913     3.6344975881    -0.9800258529
    4      C       6.3201953323     2.1666051493    -0.7039397154
    5      C       5.0451707248     1.4938942940    -1.0409107393
    6      C       3.8463988049     2.2339323956    -1.1828133053
    7      C       2.6920841508     4.3589102690    -1.1029298133
    8      C       1.4907940813     3.7080735005    -1.3872329381
    9      C       1.4335099651     2.3315155548    -1.5446652743
   10      C       2.6308522448     1.5663554748    -1.4902973716
   11      C       5.0218227922     0.1336487998    -1.1953605500
   12      C       3.8354917243    -0.5247452991    -1.5427960575
   13      C       2.6343895414     0.1478821688    -1.7079651408
   14      C       0.1603770115     1.6372726750    -1.7485645811
   15      C       1.3760877798    -0.5141589590    -2.1192552210
   16      C       0.1658052745     0.2625892744    -2.1303628552
   17      C      -1.0460688431     2.2889950531    -1.5510504061
   18      C      -2.2653193920     1.6512270880    -1.7749286215
   19      C      -1.0771705690    -0.3488251451    -2.4348527182
   20      C       1.2513310269    -1.8632877939    -2.4464120440
   21      C       0.0441681300    -2.4220743644    -2.8979936110
   22      C      -1.1107086856    -1.6960311299    -2.8700962947
   23      C      -2.2852272857     0.3573706864    -2.2322073968
   24      C      -3.5892605332    -0.3144928519    -2.4148205151
   25      C      -2.3996755393    -2.3697784354    -3.1503868413
   26      N      -3.5278262352    -1.5834490459    -2.9705454345
   27      O       7.3818595081     1.5911748036    -0.5857091857
   28      O       5.1724694381     5.5437925666    -0.4456029645
   29      O      -4.6543500376     0.1808495653    -2.1027466169
   30      O      -2.5024833261    -3.5342730246    -3.4842705780
   31      H       7.0987334806     4.0167760333    -0.2900486996
   32      H       2.7315747012     5.4340963850    -0.9659759937
   33      H       0.5947147989     4.3061056839    -1.4811637460
   34      H       5.9361724706    -0.4282967149    -1.0467224270
   35      H       3.8915025080    -1.5831039681    -1.6957205594
   36      H      -1.0637691351     3.3030405810    -1.1773724215
   37      H      -3.2058042066     2.1539407659    -1.5876219515
   38      H       0.0192664991    -3.4691864397    -3.1738886867
   39      H      -4.4171094035    -2.0630016030    -3.0491933781
   40      O       2.3116976022    -2.7314659755    -2.3825903078
   41      C       2.5883273260    -3.5309392106    -1.2829237860
   42      C       1.7071320012    -3.9021477761    -0.2570593401
   43      C       3.8990710560    -4.0086662209    -1.2953298363
   44      C       2.1962693395    -4.7765975869     0.7224878818
   45      C       3.5019517717    -5.2403736860     0.7251693604
   46      C       4.3612806425    -4.8494185033    -0.2964505216
   47      C       0.2786261441    -3.5089038479    -0.1445645525
   48      C      -0.1187710767    -2.2044512857     0.1302488467
   49      C      -1.4602312186    -1.8716150789     0.1837557001
   50      C      -2.4537692199    -2.8409697723     0.0466055367
   51      C      -2.0499087007    -4.1600909308    -0.1797478139
   52      C      -0.7068902108    -4.4862147549    -0.2882071485
   53      C      -3.8996158154    -2.5252432641     0.1198613588
   54      C      -4.4579845429    -1.6100063950     1.0212192292
   55      C      -5.8332053946    -1.4482627966     1.1356747312
   56      C      -6.6890485613    -2.1422221511     0.2932008955
   57      C      -6.1609129579    -3.0239484362    -0.6441829832
   58      C      -4.7898365954    -3.2186415734    -0.7117376629
   59      H       4.5417765214    -3.7071408467    -2.1157610320
   60      H       1.5234830604    -5.0637566775     1.5224777334
   61      H       3.8381893008    -5.9021499587     1.5167847163
   62      H       5.3883492819    -5.1984819873    -0.3227014473
   63      H       0.6267676301    -1.4305786480     0.2474404030
   64      H      -1.7332865117    -0.8348840746     0.2856886843
   65      H      -2.7976660675    -4.9395888644    -0.2755831975
   66      H      -0.4119646187    -5.5106956913    -0.4909135533
   67      H      -6.2189810656    -0.7749410528     1.8928151332
   68      H      -7.7607655318    -1.9949212391     0.3721023147
   69      H      -6.8179653524    -3.5683964695    -1.3146613434
   70      H      -4.3745839095    -3.9033466815    -1.4455603648
   71      O      -3.6283739436    -0.9265620967     1.9049774370
   72      C      -3.3233271723     0.3916401351     1.6934405137
   73      C      -2.0448184152     0.8431315722     2.0333094425
   74      C      -1.6966556272     2.1840177328     1.6773419594
   75      C      -2.6880998677     3.0773019360     1.2077391361
   76      C      -3.9910868351     2.5881679819     0.9642576050
   77      C      -4.2815655667     1.2643838681     1.1475513940
   78      C      -0.3407507519     2.6290129748     1.6991350448
   79      C      -0.0593141717     3.9604063022     1.4377725204
   80      C      -1.0631422084     4.8604756299     1.0659394606
   81      C      -2.3570914703     4.4200142334     0.9130013825
   82      C      -3.3888156993     5.3524502714     0.4035871438
   83      C      -5.0514883467     3.4879757963     0.4500227678
   84      N      -4.6468613321     4.7955149243     0.2083164264
   85      C       0.7192363407     1.6348099329     1.8922066555
   86      C       0.3614278966     0.3421287118     2.3691877333
   87      C      -0.9994628799    -0.0238209335     2.5993216673
   88      C       2.0415429725     1.8983392513     1.5777818662
   89      C       3.0236184773     0.9093364880     1.6895526790
   90      C       2.7033099056    -0.3346743527     2.1744978840
   91      C       1.3790419848    -0.6195010954     2.5814145427
   92      C       1.0532221204    -1.8737620866     3.1484457670
   93      C      -0.2384535769    -2.1315216780     3.5359328857
   94      C      -1.2623646910    -1.2182777937     3.2520810087
   95      C       3.7330973729    -1.3967323976     2.1946848611
   96      C       2.0889185224    -2.9195744946     3.2878566924
   97      N       3.3417319773    -2.5861077867     2.7922280319
   98      O       4.8438153731    -1.2721828142     1.7163561517
   99      O       1.8822677134    -4.0211405570     3.7612504301
  100      O      -3.1785265683     6.5216317502     0.1517384814
  101      O      -6.1952324582     3.1395581337     0.2456693367
  102      H      -5.2629080709     0.9126941239     0.8626732478
  103      H       0.9607679247     4.3176478382     1.4935751675
  104      H      -0.8362397823     5.8989698912     0.8507252226
  105      H      -5.3622031159     5.4245904873    -0.1393561809
  106      H       2.3283355059     2.8594649441     1.1726171476
  107      H       4.0416917721     1.0967081991     1.3720289420
  108      H      -0.4615882050    -3.0846239780     4.0022492670
  109      H      -2.2792199229    -1.4863241190     3.4908317691
  110      H       4.0175783311    -3.3408603659     2.7581699923
